October 13, 2006, 09:23 |
Hello again,
I have a case th
Dragos
Rep Power: 20 |
Hello again,
I have a case that runs well using the conjugateFoam solver. Though, if I try to set an inflow velocity boundary condition of type pressureVelocity, I get the following error: Starting time loopIt works very well with type fixedValue. Anyone can tell me what is wrong? Dragos |
October 13, 2006, 09:35 |
Can you explain more in detail
Daniele Panara
Can you explain more in detail your case?
geometry, BC, etc.. Daniele |
October 13, 2006, 10:03 |
I have an anular cylidrical do
Dragos
Rep Power: 20 |
I have an anular cylidrical domain (grey) closed at one side and opened at the other. It should resemble with a mug, a cup or a bottle. This is the solid region.
The fluid region is represented by another inner cylinder. Both the inlet (green surface) and the outlet (blue surface) are located at the opening. Though I don't think the geometry influences the error, since I have tried the same solver on other cases and behaves similarly. Dragos |
October 16, 2006, 08:46 |
I found the problem: the type
Dragos
Rep Power: 20 |
I found the problem: the type is pressureInletVelocity not pressureVelocity. It was in front of my eyes all the time.
I found this by searching all the libraries in OpenFOAM Dragos |
inlet velocity boundary condition | murali | CFX | 5 | August 3, 2012 08:56 |
boundary condition for derivative of velocity | Daiga | CFX | 2 | December 7, 2009 17:11 |
Pressure Velocity boundary condition problem | deepsterblue | OpenFOAM Running, Solving & CFD | 3 | September 24, 2008 07:19 |
On the velocity inlet boundary condition | mini | FLUENT | 2 | June 5, 2005 20:50 |
Outlet velocity boundary condition | Jay | FLUENT | 4 | December 15, 2002 08:27 |
