Problem calculate Y in compressible turbulence model
Old   May 31, 2006, 11:00
Default Hi all, May be It's a studp
Luca M.
luca is on a distinguished road
Hi all,
May be It's a studpid question but I've noticed in file "turbulence.C" in compressible turbulence models that OF calucalte Y+ like:
Yp = pow(Cmu.value(), 0.25)
*y_[patchNo]
*sqrt(k()().boundaryField()[patchNo].patchInternalField())
mu().boundaryField()[patchNo].patchInternalField()
*rho_.boundaryField()[patchNo]<---
I think that it's wrong because I need the Kinematic viscosity that is defined as
mu/rho. (I think that mu is refereed to Dynamic viscosity)
and so the right way to calculate Y+ is
*y_[patchNo]
/rho_.boundaryField()[patchNo]<---
I'm wrong ?!
Luca
luca is offline   Reply With Quote
Old   May 31, 2006, 11:41
Default Hi, In the calculation of Y
Pierre Le Fur
pierre is on a distinguished road
In the calculation of Yplus in wallViscosity.H and WallFunctions.H for compressible flow codes, it is written:
scalar yPlus =
Cmu25*turbulenceModel::y_[patchi][facei]*sqrt(k_[faceCelli])
/(muw[facei]/rhow[facei]);
which is as you suggest, so I guess you might be right. Thought that member function defined in turbulence.C is not used anywhere it seems.
Pierre
pierre is offline   Reply With Quote
Old   May 31, 2006, 11:58
Default Hi Pierre, So It's a bug..
Luca M.
Hi Pierre,
So It's a bug..
I use the function Yp in turbulence.C to check y+ for compressible turbulence model that I use. In detail I build the utility starting from "checkYPlus" incompressible utility where, I think, it uses Yp function.
So how do you suggest me to build my utility to check y+ without Yp function in turbulence compressible model?!
Thanks in advance
Luca
Old   May 31, 2006, 12:19
Default why don't you calculate Yplus
Pierre Le Fur
why don't you calculate Yplus directly as you wrote it above without using Yp function?
Pierre
Old   June 1, 2006, 05:16
Default Thanks Luca, it was a bug and
Mattijs Janssens
mattijs is on a distinguished road
Thanks Luca, it was a bug and has been fixed. Any more of these? If so please report them on the bugs list so we can keep track.
mattijs is offline   Reply With Quote
Old   June 1, 2006, 05:53
Default Ok,Mattijs!! Thanks for the
Luca M.
Ok,Mattijs!!
Thanks for the suggestion, and support.
Luca
Compressible Turbulence Model Implementations shaun OpenFOAM Running, Solving & CFD 4 October 21, 2009 11:55
compressible turbulence model shuo Main CFD Forum 3 December 22, 2007 09:51
Turbulence model problem? PattiMichelle Phoenics 0 July 11, 2007 19:35
Problem with LaunderSharma compressible turbulence model wrong formulation luca OpenFOAM Running, Solving & CFD 4 July 3, 2006 06:24
LES turbulence model problem-HELP James Willie FLUENT 2 August 23, 2005 04:54
