May 31, 2006, 10:02 |
If one generates all-Te
Pei-Ying Hsieh
Rep Power: 18 |
If one generates all-Tet elements first, then, decoposes each Tet into 4 Hex (this should not be difficult to do within OpenFOAM, I assume). What do you think about the quality of the Hex elements? Assuming the initial Tet elements have great quality. Has anyone done this? Pei |
May 31, 2006, 11:51 |
I haven't read the paper but i
Michael Prinkey
Rep Power: 25 |
I haven't read the paper but it seems this has been done before:
http://scitation.aip.org/getabs/servlet/GetabsServlet?prog=normal&id=APCPCS00071 2000001002210000001&idtype=cvips&gifs=yes Here some results from anl: http://www-unix.mcs.anl.gov/~csverma/tet2hex.html |
May 31, 2006, 13:09 |
Dear Michael:
Thanks for th
Pei-Ying Hsieh
Rep Power: 18 |
Dear Michael:
Thanks for the reply. The website I found mentioned that "most finite element analysts, because of the poor element quality that will in general result, have rejected this solution." I am wondering whethere there is any improvement in this area recently. Pei Website: http://www.andrew.cmu.edu/user/sowen...y/hexsurv.html |
May 31, 2006, 13:38 |
There are always smoothing alg
Michael Prinkey
Rep Power: 25 |
There are always smoothing algorithms that can be applied afterwards. I think that most tet generators have a smoothing pass following the base grid generation. I believe most are based on an elasticity analogy. I know Hrv mentioned doing something similar when doing mesh motion. That would likely improve mesh quality in most cases. The question is whether that would be in anyway superior to just using the polyhedral mesh extracted as the dual of the tet mesh. Unless you were using finite elements, I don't see why tet->hex would be a win over tet->poly.
How to generate good quality figures from cfx-post | Ken | CFX | 9 | April 4, 2016 04:41 |
Use Gambit to generate 3D mesh ! ! ! | yuanye | FLUENT | 0 | June 3, 2008 22:03 |
Need someone to generate mesh | RA | FLUENT | 7 | May 4, 2007 11:36 |
Element quality | Andreas | CFX | 2 | December 7, 2006 09:14 |
[Other] Problem when trying to generate a new mesh | gaottino | OpenFOAM Meshing & Mesh Conversion | 0 | June 30, 2006 07:51 |
