Komega turbulent viscosity model
Old   May 17, 2006, 11:02
Default Hello all, First of all tha
guggi
Hello all,
First of all thank you very much for this great software!
Does someone know if there is a k-omega-model available in OpenFoam?
I need this model to simulate a hard wall as a turbulent viscosity model.
Any help is appreciated.
Daniel
Old   May 17, 2006, 17:57
Default Hi daniel did you take a lo
kumar
kumar2 is on a distinguished road
Hi daniel
did you take a look in the file turbulenceProperties under /constant directory
i was not able to see k-omega in that
regards
kumar
kumar2 is offline   Reply With Quote
Old   May 18, 2006, 15:31
Default Hello Kumar, thank you for
guggi
Hello Kumar,
thank you for the quick reply.
Yes I had a look in this file before posting this thread. The problem is, there is only a simple k-Epsilon model available, but I need the k-omega model instead because it`s better when simulating a hard wall turbulence situation.
But I also tried to use the LaunderGibsonRSTM but I have to figure out first which config files (k,epsilon, R) are exactly neccessary when using LaunderGibsonRSTM.
Daniel
Could someone give me hint?
Old   May 18, 2006, 20:07
Default Hi Daniel Please look in /O
kumar
Hi Daniel
Please look in /OpenFOAM-1.2/src/turbulenceModels/incompressible/LaunderGibsonRSTM ( or have you already done this ?? ).
looks like the model needs all the 3!
kumar
Turbulent viscosity Limited to viscosity ratio Adrian FLUENT 12 September 21, 2011 04:22
KOmega Turbulence model from wwwopenFOAMWikinet philippose OpenFOAM Running, Solving & CFD 30 August 4, 2010 10:26
best viscosity turbulent model? Greg FLUENT 2 October 5, 2007 08:59
Komega turbulence model jasonb OpenFOAM Running, Solving & CFD 6 August 29, 2006 08:46
turbulent viscosity limited to viscosity ratio mukkarum FLUENT 3 May 11, 2004 04:05
