November 23, 2005, 11:21 |
I don't know the OpenFoam
merrouche djemai
Rep Power: 17 |
I don't know the OpenFoam very well, but I ask on the strategy used to impose boundary conditions within the code. If I generate my mesh with blockMesh utility and I have some boundary conditions to implement for my case, should I pass via the FoamX or I can try directly the boundary file? the problem here is with the number of patchs, when I start and when I stoped if I do it manually? please tel me if i'm wrong in the way. |
November 24, 2005, 13:53 |
You can change the patch types
Mattijs Janssens
Rep Power: 26 |
You can change the patch types by hand (as long as they're consistent with the field types).
You cannot change the number of faces or starting face. You can add/remove zero-sized patches to/from the end of the boundary list. However unless you really know what you're doing better stick with FoamX. |
setting boundary conditions on internal edges | Renate Stump | FLUENT | 4 | November 7, 2008 10:55 |
VOF and setting boundary conditions | dave00001 | FLUENT | 0 | January 25, 2008 12:37 |
Wall boundary conditions setting | Andrea | FLUENT | 2 | January 16, 2006 11:01 |
help setting up boundary conditions for combustor | Tomas | CFX | 2 | November 3, 2005 03:34 |
A problem about setting boundary conditions | lyang | Main CFD Forum | 0 | September 19, 1999 18:29 |
