ChannelOodles Correcting driving force for a constant mass flow rate
Old   September 20, 2005, 10:39
Default channelOodles: I'm trying t
Maka Mohu
maka is on a distinguished road
channelOodles:
I'm trying to edit the channelOodles to use it for channelDNS. I found some part of the code that is about correcting driving force, this part does not exist in icoFoam, which means: it is either included because of the channel or because of LES? I'm a ware that the driving force in the channel enters in the non-periodic part of pressure gradient, but I do not know about such correction. Can any one explain why we need this part in the channel code or give any reference? Many thanks!
// Correct driving force for a constant mass flow rate
// Extract the velocity in the flow direction
dimensionedScalar magUbarStar =
(flowDirection & U)().weightedAverage(mesh.V());
// Calculate the pressure gradient increment needed to
// adjust the average flow-rate to the correct value
dimensionedScalar gragPplus =
(magUbar - magUbarStar)/rUA.weightedAverage(mesh.V());
U += flowDirection*rUA*gragPplus;
gradP += gragPplus;
Info<< "Uncorrected Ubar = " << magUbarStar.value() << tab
<< "pressure gradient = " << gradP.value() << endl;
/Maka
maka is offline   Reply With Quote
Old   September 20, 2005, 12:58
Default All to do with the 'channel' b
Mattijs Janssens
mattijs is on a distinguished road
All to do with the 'channel' bit, not with LES.
One specifies an average flow-rate (Ubar in constant/transportProperties) and the pressure gradient is (hopefully slightly) adjusted to keep the wanted flow-rate.
mattijs is offline   Reply With Quote
Old   September 21, 2005, 04:56
Default In my case, I'm interested
Maka Mohu
In my case,
I'm interested to keep the dimensionless driving pressure gradient (non-periodic part) (scaled by u_tau and half channel width) to be -1 while specifying Re_tau for the simulation. The Ubar can come as a result of the simulation. I think in this case, I do not need the correction step, am I right? On the other hand I was thinking to add this deriving pressure gradient as a source term in Su, what do you think? Many thanks for your help.
Best regards,
Maka.
Old   September 21, 2005, 05:18
Default Yes, you are correct, I have d
Eugene de Villiers
eugene is on a distinguished road
Yes, you are correct, I have done this myself.
The pressure gradient was excluded from the momentum matrix for a reason, I just cant remember why. It should be simple to try both options and see if there is a difference.
eugene is offline   Reply With Quote
periodic, unsteady, non-constant mass flow rate Lee FLUENT 42 October 5, 2011 15:20
maintain a constant flow rate in channel flow ? Lewis Main CFD Forum 2 September 28, 2010 11:35
Constant Volumetric Flow Rate Boundary Condition Hadley Main CFD Forum 0 October 20, 2005 23:13
Possible?: Periodic conditions with non-constant mass flow rate. Ray FLUENT 0 April 10, 2000 06:10
Constant mass flow rate / choking outlet bounardy condition Min Zhu Main CFD Forum 1 September 29, 1998 15:33
