modify laplacian: div(k*grad(a*u))
Old   August 5, 2011, 11:42
Default modify laplacian: div(k*grad(a*u))
gunnar2 is on a distinguished road
I am trying to solve a type of heat equation:
\partial u/ \partial t + \nabla\cdot\mathbf{v} u - \nabla\cdot k \nabla \alpha u =0
The difference to the standard heat equation is the scalar field alpha.
The problem is that the last term cannot be expressed as fvm::laplacian(k,alpha*u), because apparently alpha*u is not the right class for this argument, and the compiler fails.
How can this PDE be solved?
Thanks
Gunnar
Last edited by gunnar2; August 8, 2011 at 13:26. Reason: correction: replaced [math]\nabla\cdot\phi u[/math] with [math]\nabla\cdot\mathbf{v} u[/math]
gunnar2 is offline   Reply With Quote
Old   August 6, 2011, 05:00
ata
ata's Avatar
ata kamyabi
ata is on a distinguished road
Hi
I think you can define a new field newfield=alpha*u and use fvc::laplacian(k,new)
good luck
ata is offline   Reply With Quote
Old   August 6, 2011, 06:11
But I need the implicit (fvm::laplacian), not the explicit (fvc::laplacian) term.
If there is no such term, it should be possible to use something like fvm::laplacian(k,u)*diag(alpha) for \nabla\cdot k\nabla \alpha u.
diag(alpha) would be a sparse diagonal matrix with the entries of the field alpha on it's diagonal, but I don't think such matrix exists in Openfoam.
What do you think, does it make sense to implement it?
Thanks
Gunnar
Old   August 7, 2011, 05:10
ata
ata's Avatar
ata kamyabi
Hi
I do not know
Old   August 7, 2011, 11:42
Michael Roth
roth is on a distinguished road
How about a little chain rule? i.e. split into:
\nabla \cdot ( k \alpha \nabla u ) + \nabla \cdot ( k u \nabla \alpha )
Then treat the first term implicit (by defining a new diffusivity of k\alpha) and second term explicit.
roth is offline   Reply With Quote
Old   August 7, 2011, 12:29
ata
ata's Avatar
ata kamyabi
Hi
But you loose conservative form.
Old   August 8, 2011, 08:43
santiagomarquezd's Avatar
Santiago Marquez Damian
santiagomarquezd will become famous soon enough
First of all the equation appears to be not consistent, the first and last terms are vectorial, meanwhile the second one is scalar.
Regards.
Santiago MÁRQUEZ DAMIÁN, Ph.D.
Research Scientist
Research Center for Computational Methods (CIMEC) - CONICET/UNL
Tel: 54-342-4511594 Int. 7032
Colectora Ruta Nac. 168 / Paraje El Pozo
(3000) Santa Fe - Argentina.
http://www.cimec.org.ar
santiagomarquezd is offline   Reply With Quote
Old   August 21, 2011, 14:53
Mieszko Młody
ziemowitzima is on a distinguished road
Hi Gunnar,
If the only think you need is modification of the discretization matrix (by multiplying diag(alpha)), then you can change the matrix itself.
See the PISO algorithm from icoFoam:
http://openfoamwiki.net/index.php/IcoFoam
You can do similar and:
1. discretize alpha
2. UEqn.A() = UEqn.A()*alpha_discretized
maybe will work...
ZMM
ziemowitzima is offline   Reply With Quote
Old   August 21, 2011, 16:44
Kai
kaifu is on a distinguished road
\nabla\cdot (k \nabla \alpha \mathbf{u}) =\nabla \cdot (k\alpha\nabla \mathbf{u})+\nabla\cdot (k \mathbf{u} \nabla \alpha)=\nabla \cdot (k\alpha\nabla \mathbf{u})+(\nabla \cdot k \mathbf{u})\nabla \alpha
Kai
kaifu is offline   Reply With Quote
Old   August 21, 2011, 17:36
Mieszko Młody
Hi Kai,
Of course,
I would proceed using this transformation.
Currently I have some issues with laplacian operator in OFoam as well.
Could you see my post:
http://www.cfd-online.com/Forums/ope...n-problem.html
Maybe you will have some suggestions...
Thanks
ZMM
Modifying the laplacian operator mlawson OpenFOAM Running, Solving & CFD 22 July 16, 2018 04:56
[Other] Modify mesh runtime Daniele111 OpenFOAM Meshing & Mesh Conversion 8 December 19, 2010 15:43
"=" or "==" when I modify BC (fixedGradient) during run ? Cyp OpenFOAM Programming & Development 0 December 14, 2010 08:12
Crank Nicholson scheme for Laplacian failed Cyp OpenFOAM 3 July 19, 2010 07:58
