Axial 2D calculation in simpleFoam prblem with convergence
Old   May 11, 2005, 17:50
Default At first I make 2D planar case
Andriy Rybakov
rybakov is on a distinguished road
At first I make 2D planar case restangular geometry - everething OK.
Then I try to caclulate axial 2D geometry with help of simpleFoam (boundary condition is equivalent to planar). I use wedge, empty for axis etc., make with blockMesh geometry. (I can see it in paraFoam - everything is OK with geometry). But when I try to calculate, it don't converge. Some first steps are OK, then oops. I try to change relaxation factors - it is don't help.
In this case I see that program calculate Vz (but in 2D planar - don't).
Must I change some more parameters for axial case?
rybakov is offline   Reply With Quote
Old   May 12, 2005, 12:32
Default I have found where is the prob
Andriy Rybakov
I have found where is the problem. As usually, it was _my_ mistake in geometry. Now evrerything convergenced.
Old   May 12, 2005, 12:39
Default Nice to hear that FOAM is doin
Hrvoje Jasak
Nice to hear that FOAM is doing what it is supposed to be doing. :-) If you can put a few details about how you found the error in geometry in a message, some future users may benefit from your experience (if applicable).
Thanks,
Hrv
Hrvoje Jasak
Old   May 16, 2005, 02:00
Default Hi Andriy, Could you tell
Chalothon Thumthae
thumthae is on a distinguished road
Hi Andriy,
Could you tell me what is your mistake?
I ever try 2D axi-symetric case but it doesn't work.
If you can put detail, it will be useful for other FOAM user.
I agree with Hrv
Thanks
thumthae is offline   Reply With Quote
SimpleFoam convergence problems brahim OpenFOAM Running, Solving & CFD 20 June 9, 2015 09:09
SimpleFoam Convergence problem skabilan OpenFOAM Running, Solving & CFD 6 May 31, 2013 03:21
SimpleFoam solution convergence pattern philippose OpenFOAM Running, Solving & CFD 0 June 26, 2008 14:18
Axial Velocity Calculation Roux CFX 0 May 12, 2008 09:37
SimpleFoam convergence problems schnitzlein OpenFOAM Running, Solving & CFD 6 June 24, 2005 09:51
