Format to specify gammaContactAngle
Old   April 25, 2005, 10:10
Default Hello, I am trying to simul
Vinay Ramohalli Gopala
gopala is on a distinguished road
I am trying to simulate a bubble breakage problem (air bubble with water jet impinging on it).
As a first trial I used the "wallNoSurfaceTension" as the physicalType for walls in the polyMesh/boundary file and it works fine.
Now that I want to use the "gammaContactAngle" on the walls for the gamma field, I could not find the format to specify this. Could someone please help me on how to use it?
Thanks in advance.
/Vinay
gopala is offline   Reply With Quote
Old   April 26, 2005, 03:09
Default Try: impactWall
Hrvoje Jasak
Try:
impactWall
type gammaContactAngle;
theta0 93.5; // Equilibrium [Deg]
uTheta 0.5; // Velocity coeff [m/s]
thetaA 97.0; // Advancing [Deg];
thetaR 90.0; // Receeding [Deg];
value uniform 0;
Hrvoje Jasak
msh format Frank FLUENT 1 June 27, 2012 10:39
GammaContactAngle not implemented coastal593 OpenFOAM Running, Solving & CFD 5 November 9, 2010 05:21
The format of add new BC ivanyao OpenFOAM Pre-Processing 0 November 13, 2008 21:30
Calculated gradient boundary condition similar to gammaContactAngle adona058 OpenFOAM Running, Solving & CFD 0 September 26, 2007 15:23
help!!! 3ds format to DXF Pin Main CFD Forum 0 September 3, 2006 20:38
