Geometry Very basic question
Old   January 28, 2005, 08:02
Default I have not yet installed or r
Paul Wells (Wells)
I have not yet installed or run OpenFoam, and I couldn't find anything after a quick look through the documentation, so please forgive this very basic question:
How do I read in geometry to the mesher? Can I import iges or any CAD format? or do I have to output lists of points to format as an input file?
Old   January 28, 2005, 08:19
Default You need to generate complex m
Eugene de Villiers (Eugene)
You need to generate complex meshes for OpenFOAM in an external application like Harpoon, ICEM, Gridgen, Netgen, Gambit etc. each of which has its own import requirements. (Check mesh conversion in the manual). The current release of OpenFOAM only has a basic block based mesh generator.
Old   March 10, 2005, 00:54
Default Hi Eugene, You mentioned ab
tchavdarov's Avatar
tchavdarov is on a distinguished road
Hi Eugene,
You mentioned above Gridgen. Which utility converts Gridgen mesh to FOAM mesh?
Thanks,
Boyko
tchavdarov is offline   Reply With Quote
Old   March 10, 2005, 03:21
Default You either export a star or fl
Eugene de Villiers
eugene is on a distinguished road
You either export a star or fluent mesh and then convert that into Foam format.
eugene is offline   Reply With Quote
basic-question Antonio CFX 2 February 26, 2008 18:10
Basic Question Abhi FLUENT 1 August 4, 2007 08:07
Basic Turbine Blade Geometry Nathan Durley-Boot FLUENT 0 February 20, 2007 07:21
Basic LES question toyCFD Main CFD Forum 3 August 23, 2006 15:09
LES..Basic Question NIK Main CFD Forum 13 May 19, 2004 19:03
