Problem using PISO
Old   July 6, 2009, 13:20
Default Problem using PISO
Antonio Martins
titio is on a distinguished road
Send a message via MSN to titio Send a message via Skype™ to titio
Hi Foamers,
I am having some problems using PISO to simulate the flow of complex fluids, in particular polymers, where some extra stresses have to be considered. I can already simulate the flow in a simple system, infinite parallel, but when I compare the analytical solution with the predictions of OpenFoam, I manage to obtain the correct velocity profile but the predicted pressure gradient is smaller than expected. On possible problem is the analytical solution is wrong, but I doube check it and it is correct.
I am thinking on the the possibility of doing more PISO steps, to improve the calculation of the pressure field, or changing the PISO algorithm implemented in icoFoam, that I am using.
Has anybody any ideas of what is going on? Any help will be much appreciated.
Regards,
Titio
titio is offline   Reply With Quote
Old   July 7, 2009, 02:26
Alberto Passalacqua
Hi Antonio,
first, an elementary question: is the pressure gradient wrong or is the value of pressure simply different? I ask because if you use an incompressible solver in OF, the actual value of the pressure you find depends on the reference value. However in such a case the gradient should be OK.
About your specific case, without knowing more on the model you use to describe the non-Newtonian stress tensor, and how you implemented it, it is impossible to reply.
Best,
A.
Alberto Passalacqua
Old   July 7, 2009, 05:48
Antonio Martins
Originally Posted by alberto View Post
Hi Antonio,
Best,
A.
Thanks Alberto,
The pressure value is simply different, by at must 10%, I tried to change the mesh and the problem remains. I am testing the possibility of iterating several times in a PISO step, this time including the momentum predictor. Do you have more ideas?
Regards,
Titio
Incoherent problem table in hollow-fiber spinning Gianni FLUENT 0 April 5, 2008 10:33
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
Problem in Tutorial problem of fluent Phanindra FLUENT 5 April 17, 2007 09:57
GAMBIT meshing problem Gauthier Lambert Main CFD Forum 1 August 3, 2000 09:22
PISO vs. SIMPLEC Andreas Abdon Main CFD Forum 1 March 4, 2000 02:18
