Cavitating Foam: need a clarification with the thermodynamic properties dictionary |
July 27, 2009, 10:17 |
varun
Rep Power: 16 |
I'm a new user in openfoam and require to work with cavitating foam. My question is very simple, i need a calrification with the thermodynamic properties dictionary. What do the the variables "psiv" and "psil" signify and where are they used in the actual code? Please help! thnX!! |
July 30, 2009, 11:33 |
Gabriela Bracho
Rep Power: 17 |
Hi, I think the answers are in this link:
http://www.cfd-online.com/Forums/ope...psil-psiv.html l = is referred to the liquid v = is referred to the vapor I hope it would work Gaby |
July 31, 2009, 08:59 |
varun
Rep Power: 16 |
Thanks gaby! also i would like to know the value of psiv for a vapour like air. How can it be calculated? thnX! |
May 17, 2010, 09:01 |
Marta Lazzarin
Rep Power: 16 |
Hi Foamers!
I have a problem in running the cavitatingFoam solver in version 1.6 and 1.6.x. It works only if there is no cavitation...as soon as it cavitates (gamma is no longer 0), the pressure becomes negative. Furthermore when the compressibility of the fluid is increased the density appears to burst, as the output indicates non-realistic values. Have you encountered the same problem while running a simulation? I think the problems can be due to the assumption made in the paper describing the solver by Karrholm that the compressibility is constant, but this does not hold when the cavitating parameter(gamma) changes with time. Is my understanding of the assumption true? Thank you ! Marta |
May 13, 2015, 07:27 |
crash in cavitatingFoam tutorial case
alvaro
Rep Power: 11 |
I'm testing the cavitatingFoam(ras) code of version 2.3.0 but it crash when I run it and without make any change in tutorial case. Anyone familiarized with this solver could help me? Thanks in advance. Last edited by alvariten; May 16, 2015 at 13:21. |
May 14, 2015, 04:51 |
Alexander Bartel
Rep Power: 11 |
HI alvaro,
I am not really familiarized with cavitatingFoam, but I tried it myself ashort time ago and experienced the same problems. I think the problem is not stable behaviour when the grid has small cells. You can try the tutorial with commenting out the refinemeshByCellset line from the Allrun script. Or delete just the 2 and 3 in that line... I don't know if LES worked better... Right know I do the mostly same things with InterPhaseChangeFoam, because it works smoother and gives better results. regards Alex
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request. |
May 16, 2015, 15:48 |
alvaro
Rep Power: 11 |
Hi Alex,
Thank you for reply. I solved the problem finally. I just had to low the maxCo and maxAcusticCo and the simulation worked without problem (and more slowly). I tested with different size of cells modifying the Allrun script as you said and you were right, the behaviour si more stable. Now I'm going to try run with my own geometry (axi-symmetry nozzle) with cavitatingFoam and interPhaseChangeFoam and then compare the results. Thanks for your advice. Regards, Alvaro. |
June 10, 2015, 02:59 |
#8 | |
Duong Tung
Rep Power: 11 |
Did you get the results? Could you please share them to me to make me clarified about the differences between two solvers? Thank you and best regards, Tung |
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field | lakeat | OpenFOAM Community Contributions | 58 | December 23, 2021 02:36 |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
[blockMesh] Errors during blockMesh meshing | Madeleine P. Vincent | OpenFOAM Meshing & Mesh Conversion | 51 | May 30, 2016 10:51 |
decomposePar is missing a library | whk1992 | OpenFOAM Pre-Processing | 8 | March 7, 2015 07:53 |
Two-Phase Buoyant Flow Issue | Miguel Baritto | CFX | 4 | August 31, 2006 12:02 |
