Pressure driven laminar flow simpleFoam pressure higher at the outlet than inlet |
October 23, 2007, 08:04 |
Dear Friends,
I am investi
Gabriel Barroso
Rep Power: 17 |
Dear Friends,
I am investigating a realy difficult, scientific high demanding case :-) I have a pipe and a laminar flow. My boundary conditions are at the inlet velocity (0 0 0.1) and at the outlet pressure 0. I start simulation with simpleFoam and the result is that the pressure at the outlet is higher than at the inlet. Nevetheless the flow streams from the inlet to the outlet. I tried the simulation with OF 1.4 and OF 1.4.1. What is wrong ? And please do not write, that's an easy test case :-), it is not :-() Thanks for any advice. |
October 23, 2007, 08:22 |
I forgot to say, Reynoldsnumbe
Gabriel Barroso
Rep Power: 17 |
I forgot to say, Reynoldsnumber is 3.5.
October 23, 2007, 09:53 |
Can you send (or post your tes
Matvey Kraposhin
Rep Power: 21 |
Can you send (or post your test case)? mkraposhin@inbox.ru
MDPI Fluids (Q2) special issue for OSS software: https://www.mdpi.com/journal/fluids/..._modelling_OSS GitHub: https://github.com/unicfdlab Linkedin: https://linkedin.com/in/matvey-kraposhin-413869163 RG: https://www.researchgate.net/profile/Matvey_Kraposhin |
October 24, 2007, 06:40 |
sure, do you know how i
Gabriel Barroso
Rep Power: 17 |
sure, do you know how i can add a .tar file on this message. So everybody can take this simple case and do his own stuff. Best Gabriel |
October 24, 2007, 08:38 |
Probably, you can"t post tgz:
Matvey Kraposhin
Rep Power: 21 |
Probably, you can"t post tgz: - it will be too big.
October 24, 2007, 08:53 |
Gabriel, see http://www.cfd-on
Ruben I. Mukhamadeev
Rep Power: 17 |
October 25, 2007, 04:39 |
I put here the file. Again, it
Gabriel Barroso
Rep Power: 17 |
I put here the file. Again, its a cylinder with a velocity inlet and a pressure outlet. Its laminar (inlet velocity 0.001 m/s) viscosity 1 and the radius is ca. 0.246 so the Reynoldsnumger is for this case is much below 1. The residuals do not converge.
If you have any suggestion, i think it would be nice for the whole community |
Gabriel Barroso
Rep Power: 17 |
October 25, 2007, 04:47 |
I send the file by email. It i
#9 |
Gabriel Barroso
Rep Power: 17 |
I send the file by email. It is only 1.9Mb but to large to post it.
Every one who wants this case can e-mail me. Again, its a cylinder with a velocity inlet and a pressure outlet. Its laminar (inlet velocity 0.001 m/s) viscosity 1 and the radius is ca. 0.246 so the Reynoldsnumger is for this case is much below 1. The residuals do not converge. If you have any suggestion, i think it would be nice for the whole community, because a flow in a pipe is quite frequent. |
October 25, 2007, 07:12 |
2 Gabriel
I don't understan
#10 |
Rep Power: 17 |
2 Gabriel
I don't understand U=zeroGradient on WALL for gas laminar flow - it should be fixedValue=0.0. And (may be it's not a critical) outlet I would change on pressureOutlet. p should be defined as non-zero - uniform 1e+05 (normal atmospheric pressure) - for pressureOutlet and internalField. R - I think you should to see in the similar cases. |
October 25, 2007, 10:11 |
2 Ruben
Thank you very much
#11 |
Gabriel Barroso
Rep Power: 17 |
2 Ruben
Thank you very much! U=zeroGradient on Wall is exactly the error!!! Pressure does not matter (us much Hrv writes in other sections) because the code is normalized. Pressure is always treated as a relative pressure. If I put 1e5 on the outlet then i get the absolut pressure, if i put 0 i only get the relative pressure. Adding a reference pressure (e.g. 1e5) leads again to the absolute pressure. Again: Thank you very much! Now it looks as a very stupid error, and ... honestly ... it is :-) Bests Gabriel |
October 25, 2007, 10:26 |
Now changing the grid and usin
#12 |
Gabriel Barroso
Rep Power: 17 |
Now changing the grid and using a more sofisticated mesh for mixing purpose, I get the following error message. I have tried to play a little around with tolerances, underrelaxation, etc. Has anybody similar experiences? Is there a solution?
Error message: Reading field U Reading/calculating face flux field phi Selecting incompressible transport model Newtonian Selecting turbulence model laminar Starting time loop Time = 1 DILUPBiCG: Solving for Ux, Initial residual = 1, Final residual = 0.099712, No Iterations 1 DILUPBiCG: Solving for Uy, Initial residual = 1, Final residual = 0.0148155, No Iterations 2 DILUPBiCG: Solving for Uz, Initial residual = 1, Final residual = 0.0852757, No Iterations 1 #0 Foam::error::printStack(Foam:stream&) in "/data/home/bg/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libOpenFOAM.so" #1 Foam::sigFpe::sigFpeHandler(int) in "/data/home/bg/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libOpenFOAM.so" #2 ?? in "/lib64/libc.so.6" #3 Foam::DICPreconditioner::calcReciprocalD(Foam::Fie ld<double>&, Foam::lduMatrix const&) in "/data/home/bg/OpenFOAM/OpenFOAM-1. 4.1/lib/linux64GccDPOpt/libOpenFOAM.so" #4 Foam::DICPreconditioner::DICPreconditioner(Foam::l duMatrix::solver const&, Foam::Istream&) in "/data/home/bg/OpenFOAM/OpenFOA M-1.4.1/lib/linux64GccDPOpt/libOpenFOAM.so" #5 Foam::lduMatrix::preconditioner::addsymMatrixConst ructorToTable<foam::dicprecond itioner>::New(Foam::lduMatrix::solver const&, Foam::Istream&) in "/data/home/bg/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libOpenFOAM.so" #6 Foam::lduMatrix::preconditioner::New(Foam::lduMatr ix::solver const&, Foam::Istream&) in "/data/home/bg/OpenFOAM/OpenFOAM-1.4. 1/lib/linux64GccDPOpt/libOpenFOAM.so" #7 Foam::PCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/data/home/bg/OpenFOAM/OpenFOAM-1 .4.1/lib/linux64GccDPOpt/libOpenFOAM.so" #8 Foam::fvMatrix<double>::solve(Foam::Istream&) in "/data/home/bg/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libfiniteVolume.s o" #9 main in "/data/home/bg/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linux64GccDPOpt/simpleFo am" #10 __libc_start_main in "/lib64/libc.so.6" #11 Foam::regIOobject::readIfModified() in "/data/home/bg/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linux64GccDPOpt/simpleFo am" [2]+ Gleitkomma-Ausnahme simpleFoam /c/home/bg FINE_nu0.007_v0.01 >log |
October 25, 2007, 10:35 |
Congratulations for getting ov
#13 |
Hrvoje Jasak
Rep Power: 33 |
Congratulations for getting over the first stupid mistake. The new one looks like you've got a zero-volume cell in your mesh, which clearly is not allowed. Try running checkMesh and see what it says.
Enjoy, Hrv
Hrvoje Jasak Providing commercial FOAM/OpenFOAM and CFD Consulting: http://wikki.co.uk |
October 26, 2007, 09:49 |
Thanks, I made a complete new
#14 |
Gabriel Barroso
Rep Power: 17 |
Thanks, I made a complete new mesh. It was a mesh with tetras, hexas and prism, and I don't know why, it was not possible to correct it, either smoothing it in ICEM. Now i use a full tetra mesh, and its fine.
Thanks, Gabriel |
May 16, 2008, 05:44 |
Mr. Gabriel my system also giv
#15 |
Mohd Yousuf
Rep Power: 17 |
Mr. Gabriel my system also gives the same error message as yours. Can you please tell me how you resolved the problem .
I checked the mesh everything looks fine. Thanx Yousuf. |
September 30, 2009, 17:43 |
hi to all
#16 |
sarangarajan
Rep Power: 16 |
hey guys I am trying to solve a simple problem. I
--------------------------------------- ____..................._______ inlet |...................| outlet .......|.................. | .......| ..................| .......|. .................| .......|___________| acutally i modified the lid driven cavity problem to create this geometry. i specified velocity in inlet as movingWall (this is my inlet ) { type fixedValue; value uniform (10 0 0); } movingWall1 (this is my oultet) { type zeroGradient; } and pressure values as follows movingWall { type zeroGradient; } movingWall1 { type fixedValue; value uniform 2; } when i run icoFoam i get the following error .. Create time Create mesh for time = 0 Reading transportProperties Reading field p Reading field U Reading/calculating face flux field phi Starting time loop Time = 0.001 Courant Number mean: 0 max: 1 This mesh contains patches of type empty but is not 1D or 2D by virtue of the fact that the number of faces of this empty patch is not divisible by the number of cells. From function emptyFvPatchField<Type>::updateCoeffs() in file fields/fvPatchFields/constraint/empty/emptyFvPatchField.C at line 148. FOAM exiting i am a beginner so sorry if i have made a silly mistake..thanks guys Last edited by sarajags_89; September 30, 2009 at 17:54. Reason: wrong figure |
September 30, 2009, 18:20 |
this is my mesh
#17 |
sarangarajan
Rep Power: 16 |
| ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.6 | | \\ / A nd | Web: http://www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 0.1; vertices ( (0 0 0) (2 0 0) (-1 2 0) (0 2 0) (2 2 0) (3 2 0) (3 3 0) (2 3 0) (0 3 0) (-1 3 0) (0 0 .5 ) (2 0 .5) (-1 2 .5) (0 2 .5) (2 2 .5) (3 2 .5) (-1 3 .5) (0 3 .5) (2 3 .5) (3 3 .5) ); blocks ( hex (0 1 4 3 10 11 14 13) (5 5 1) simpleGrading (1 1 1) hex (3 4 7 8 13 14 18 17) (5 5 1) simpleGrading (1 1 1) hex (2 3 8 9 12 13 17 16) (5 5 1) simpleGrading (1 1 1) hex (4 5 6 7 14 15 19 18) (5 5 1) simpleGrading (1 1 1) ); edges ( ); patches ( wall movingWall1 ( (9 16 12 2) ) wall movingWall ( (6 19 15 5) ) wall fixedWalls ( (12 2 3 13) (13 3 0 10) (5 15 14 4) (4 14 11 1) (9 8 17 16) (7 6 19 18) ) empty frontAndBack ( (18 19 15 14) (14 11 10 13) (13 12 16 17) (17 18 14 13) (7 6 5 4) (4 1 0 3) (3 2 9 8) (8 7 4 3) ) ); mergePatchPairs ( ); // ************************************************** *********************** // |
SimpleFoam pressure driven flow | gzink | OpenFOAM Running, Solving & CFD | 1 | July 2, 2013 14:23 |
PRESSURE INLET & OUTLET BC? | Freeman | FLUENT | 0 | February 28, 2009 12:25 |
Mass flow inlet and pressure outlet BC in star-cd? | sreenivas | Siemens | 4 | February 22, 2008 01:52 |
pressure driven flow by pressure correction method | justentered | Main CFD Forum | 0 | December 29, 2003 23:52 |
How to specify pressure outlet and inlet | Will | FLUENT | 3 | March 31, 2001 18:54 |
