Pressure driven laminar flow simpleFoam pressure higher at the outlet than inlet
Old   October 23, 2007, 08:04
Default Dear Friends, I am investi
Gabriel Barroso
gabriel is on a distinguished road
Dear Friends,
I am investigating a realy difficult, scientific high demanding case :-) I have a pipe and a laminar flow. My boundary conditions are at the inlet velocity (0 0 0.1) and at the outlet pressure 0.
I start simulation with simpleFoam and the result is that the pressure at the outlet is higher than at the inlet. Nevetheless the flow streams from the inlet to the outlet.
I tried the simulation with OF 1.4 and OF 1.4.1.
What is wrong ?
And please do not write, that's an easy test case :-), it is not :-()
Thanks for any advice.
gabriel is offline   Reply With Quote
Old   October 23, 2007, 08:22
Default I forgot to say, Reynoldsnumbe
Gabriel Barroso
I forgot to say, Reynoldsnumber is 3.5.
Old   October 23, 2007, 09:53
Default Can you send (or post your tes
mkraposhin's Avatar
Matvey Kraposhin
mkraposhin is on a distinguished road
Can you send (or post your test case)? mkraposhin@inbox.ru
mkraposhin is offline   Reply With Quote
Old   October 24, 2007, 06:40
Default Hi, sure, do you know how i
Gabriel Barroso
sure, do you know how i can add a .tar file on this message. So everybody can take this simple case and do his own stuff.
Best Gabriel
Old   October 24, 2007, 08:38
Default Probably, you can"t post tgz:
mkraposhin's Avatar
Matvey Kraposhin
Probably, you can"t post tgz: - it will be too big.
Old   October 24, 2007, 08:53
Default Gabriel, see http://www.cfd-on
Ruben I. Mukhamadeev
benru is on a distinguished road
Gabriel, see http://www.cfd-online.com/cgi-bin/Op...ormatting#text
benru is offline   Reply With Quote
Old   October 25, 2007, 04:39
Default I put here the file. Again, it
Gabriel Barroso
I put here the file. Again, its a cylinder with a velocity inlet and a pressure outlet. Its laminar (inlet velocity 0.001 m/s) viscosity 1 and the radius is ca. 0.246 so the Reynoldsnumger is for this case is much below 1. The residuals do not converge.
If you have any suggestion, i think it would be nice for the whole community
Gabriel Barroso
Old   October 25, 2007, 04:47
Default I send the file by email. It i
Gabriel Barroso
I send the file by email. It is only 1.9Mb but to large to post it.
Every one who wants this case can e-mail me.
If you have any suggestion, i think it would be nice for the whole community, because a flow in a pipe is quite frequent.
Old   October 25, 2007, 07:12
Default 2 Gabriel I don't understan
2 Gabriel
I don't understand U=zeroGradient on WALL for gas laminar flow - it should be fixedValue=0.0. And (may be it's not a critical) outlet I would change on pressureOutlet. p should be defined as non-zero - uniform 1e+05 (normal atmospheric pressure) - for pressureOutlet and internalField. R - I think you should to see in the similar cases.
Old   October 25, 2007, 10:11
Default 2 Ruben Thank you very much
  #11
Gabriel Barroso
2 Ruben
Thank you very much! U=zeroGradient on Wall is exactly the error!!! Pressure does not matter (us much Hrv writes in other sections) because the code is normalized. Pressure is always treated as a relative pressure. If I put 1e5 on the outlet then i get the absolut pressure, if i put 0 i only get the relative pressure. Adding a reference pressure (e.g. 1e5) leads again to the absolute pressure.
Again: Thank you very much! Now it looks as a very stupid error, and ... honestly ... it is :-)
Bests Gabriel
Old   October 25, 2007, 10:26
Default Now changing the grid and usin
  #12
Gabriel Barroso
Now changing the grid and using a more sofisticated mesh for mixing purpose, I get the following error message. I have tried to play a little around with tolerances, underrelaxation, etc. Has anybody similar experiences? Is there a solution?
Error message:
Reading field U
Selecting incompressible transport model Newtonian
Selecting turbulence model laminar
Starting time loop
Time = 1
DILUPBiCG: Solving for Ux, Initial residual = 1, Final residual = 0.099712, No Iterations 1
DILUPBiCG: Solving for Uy, Initial residual = 1, Final residual = 0.0148155, No Iterations 2
DILUPBiCG: Solving for Uz, Initial residual = 1, Final residual = 0.0852757, No Iterations 1
#0 Foam::error::printStack(Foam:stream&) in "/data/home/bg/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libOpenFOAM.so"
#1 Foam::sigFpe::sigFpeHandler(int) in "/data/home/bg/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libOpenFOAM.so"
#2 ?? in "/lib64/libc.so.6"
#3 Foam::DICPreconditioner::calcReciprocalD(Foam::Fie ld<double>&, Foam::lduMatrix const&) in "/data/home/bg/OpenFOAM/OpenFOAM-1.
#4 Foam::DICPreconditioner::DICPreconditioner(Foam::l duMatrix::solver const&, Foam::Istream&) in "/data/home/bg/OpenFOAM/OpenFOA
#5 Foam::lduMatrix::preconditioner::addsymMatrixConst ructorToTable<foam::dicprecond itioner>::New(Foam::lduMatrix::solver const&,
Foam::Istream&) in "/data/home/bg/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libOpenFOAM.so"
#6 Foam::lduMatrix::preconditioner::New(Foam::lduMatr ix::solver const&, Foam::Istream&) in "/data/home/bg/OpenFOAM/OpenFOAM-1.4.
#7 Foam::PCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/data/home/bg/OpenFOAM/OpenFOAM-1
#8 Foam::fvMatrix<double>::solve(Foam::Istream&) in "/data/home/bg/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libfiniteVolume.s
o"
#9 main in "/data/home/bg/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linux64GccDPOpt/simpleFo am"
#10 __libc_start_main in "/lib64/libc.so.6"
#11 Foam::regIOobject::readIfModified() in "/data/home/bg/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linux64GccDPOpt/simpleFo am"
[2]+ Gleitkomma-Ausnahme simpleFoam /c/home/bg FINE_nu0.007_v0.01 >log
Old   October 25, 2007, 10:35
Default Congratulations for getting ov
  #13
Hrvoje Jasak
hjasak will become famous soon enough
Congratulations for getting over the first stupid mistake. The new one looks like you've got a zero-volume cell in your mesh, which clearly is not allowed. Try running checkMesh and see what it says.
Enjoy,
Hrv
Hrvoje Jasak
Providing commercial FOAM/OpenFOAM and CFD Consulting: http://wikki.co.uk
hjasak is offline   Reply With Quote
Old   October 26, 2007, 09:49
Default Thanks, I made a complete new
  #14
Gabriel Barroso
Thanks, I made a complete new mesh. It was a mesh with tetras, hexas and prism, and I don't know why, it was not possible to correct it, either smoothing it in ICEM. Now i use a full tetra mesh, and its fine.
Thanks,
Gabriel
Old   May 16, 2008, 05:44
Default Mr. Gabriel my system also giv
  #15
Mohd Yousuf
yousuf is on a distinguished road
Mr. Gabriel my system also gives the same error message as yours. Can you please tell me how you resolved the problem .
I checked the mesh everything looks fine.
Thanx
Yousuf.
yousuf is offline   Reply With Quote
Old   September 30, 2009, 17:43
Default hi to all
  #16
sarangarajan
sarajags_89 is on a distinguished road
hey guys I am trying to solve a simple problem. I
____..................._______
inlet |...................| outlet
.......|___________|
acutally i modified the lid driven cavity problem to create this geometry.
i specified velocity in inlet as
movingWall (this is my inlet )
type fixedValue;
value uniform (10 0 0);
} movingWall1 (this is my oultet)
type zeroGradient;
and pressure values as follows
movingWall
type zeroGradient;
movingWall1
type fixedValue;
value uniform 2;
when i run icoFoam i get the following error ..
Create time
Create mesh for time = 0
Reading transportProperties
Reading field p
Reading field U
Starting time loop
Time = 0.001
Courant Number mean: 0 max: 1
This mesh contains patches of type empty but is not 1D or 2D
by virtue of the fact that the number of faces of this
empty patch is not divisible by the number of cells.
From function emptyFvPatchField<Type>::updateCoeffs()
in file fields/fvPatchFields/constraint/empty/emptyFvPatchField.C at line 148.
FOAM exiting
i am a beginner so sorry if i have made a silly mistake..thanks guys
sarajags_89 is offline   Reply With Quote
Old   September 30, 2009, 18:20
Default this is my mesh
  #17
sarangarajan
| \\ / O peration | Version: 1.6 |
| \\ / A nd | Web: http://www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
object blockMeshDict;
convertToMeters 0.1;
vertices
(0 0 0)
(2 0 0)
(-1 2 0)
(0 2 0)
(2 2 0)
(3 2 0)
(3 3 0)
(2 3 0)
(0 3 0)
(-1 3 0)
(0 0 .5 )
(2 0 .5)
(-1 2 .5)
(0 2 .5)
(2 2 .5)
(3 2 .5)
(-1 3 .5)
(0 3 .5)
(2 3 .5)
(3 3 .5)
blocks
hex (0 1 4 3 10 11 14 13) (5 5 1) simpleGrading (1 1 1)
hex (3 4 7 8 13 14 18 17) (5 5 1) simpleGrading (1 1 1)
hex (2 3 8 9 12 13 17 16) (5 5 1) simpleGrading (1 1 1)
hex (4 5 6 7 14 15 19 18) (5 5 1) simpleGrading (1 1 1)
edges
patches
wall movingWall1
(9 16 12 2)
wall movingWall
(6 19 15 5)
wall fixedWalls
(12 2 3 13)
(13 3 0 10)
(5 15 14 4)
(4 14 11 1)
(9 8 17 16)
(7 6 19 18)
empty frontAndBack
(18 19 15 14)
(14 11 10 13)
(13 12 16 17)
(17 18 14 13)
(7 6 5 4)
(4 1 0 3)
(3 2 9 8)
(8 7 4 3)
mergePatchPairs
SimpleFoam pressure driven flow gzink OpenFOAM Running, Solving & CFD 1 July 2, 2013 14:23
PRESSURE INLET & OUTLET BC? Freeman FLUENT 0 February 28, 2009 12:25
Mass flow inlet and pressure outlet BC in star-cd? sreenivas Siemens 4 February 22, 2008 01:52
pressure driven flow by pressure correction method justentered Main CFD Forum 0 December 29, 2003 23:52
How to specify pressure outlet and inlet Will FLUENT 3 March 31, 2001 18:54
