Compressible Turbulence Model Implementations
Old   April 17, 2007, 02:50
Default G'day. I am realtively new to
Shaun Darmody
shaun is on a distinguished road
G'day. I am realtively new to OF so please excuse me if this is an ignorant question. Why does the OpenFoam code not include for example the S-A and SST-KW models as options for when wanting to run a compressible flow field solution?
Am I missing something about the difficulty for the implementation of such an option?
I am not trying to criticise the code developers. I am simply curious as to why this (up until now) has not been done. I would have thought this would make OpenFoam extremely competitive amongst the available CFD codes for external aerodynamic applications.
I guess I am just putting this out there and wish to know if anyone has already made available the ability to select S-A or SST-KW for compressible flow fields.
Thanks for your time.
Regards
Shaun.D
shaun is offline   Reply With Quote
Old   April 17, 2007, 04:55
Default Why would you need a compressi
Eugene de Villiers
eugene is on a distinguished road
Why would you need a compressible solver for external aerodynamics? (Ma ~ 0.1 = not compressible)
You are right it wouldn't be very hard to do though.
eugene is offline   Reply With Quote
Old   April 17, 2007, 07:49
Default Eugene, thanks for the reply.
Shaun Darmody
Eugene, thanks for the reply. I am talking about external aerodynamics applications where I would consistently model flows from M0.4 up to M1.2 for instance. Hence the need for a compressible flow field solution.
Can you or anyone else suggest the requirements for implementing a compressible flow compatible S-A and SST-KW model? Or should I simply plug away at this myself, by perhaps looking to the template offered for a compressible model in the source code?
Thanks again for your time.
Regards
Shaun.D
Old   April 17, 2007, 08:28
Default For transonic flows you really
Eugene de Villiers
For transonic flows you really need to incorporate the effect of shocks on turbulence. To my knowledge none of the currently implemented turbulence models do this. Other than this, it should be fairly easy to make the incompressible models compressible by looking at the existing implementations.
Mail me if you have specific queries.
Old   October 21, 2009, 11:55
Nat Trask
natrask is on a distinguished road
This thread was posted a while ago... do any of the newly incorporated turbulence models capture the effect of shocks on the turbulence?
-Nat
natrask is offline   Reply With Quote
Wall functions and turbulence models implementations jposunz OpenFOAM Running, Solving & CFD 2 October 23, 2009 04:02
compressible turbulence model shuo Main CFD Forum 3 December 22, 2007 09:51
Problem with LaunderSharma compressible turbulence model wrong formulation luca OpenFOAM Running, Solving & CFD 4 July 3, 2006 06:24
Problem calculate Y in compressible turbulence model luca OpenFOAM Running, Solving & CFD 5 June 1, 2006 05:53
LES turbulence for compressible flow jana FLUENT 0 June 17, 2005 13:14
