SimpleFoam unable to reach steady state
Old   January 28, 2009, 05:59
Default Hi Foamers, I'm playing wit
Francois Beaubert
francois is on a distinguished road
Hi Foamers,
I'm playing with the simpleFoam solver for a simple open rotor/stator laminar flow configuration but I'm not able to reach the steady state of the flow.
The angular velocity on the rotor is around 300 tr/min so a Reynolds number (based on the rotor radius) around 2.10^5 is expected. According to the literature the flow is still laminar.
So I try simpleFoam with no turbulence models but even if convergence seems ok I'm not able to reach this steady state. Perhaps the flow is locally turbulent or in transition and a RANS model could be the way to go. Some experiences on those kind of flows ?
Here is one of my last iteration output in the log file:
Time = 95000
DILUPBiCG: Solving for Ux, Initial residual = 0.0114524, Final residual = 0.000374143, No Iterations 2
DILUPBiCG: Solving for Uy, Initial residual = 0.00827667, Final residual = 0.000238708, No Iterations 2
DILUPBiCG: Solving for Uz, Initial residual = 0.00574431, Final residual = 0.000142418, No Iterations 2
DICPCG: Solving for p, Initial residual = 0.0246974, Final residual = 0.000246175, No Iterations 54
time step continuity errors : sum local = 7.81603e-05, global = -2.14943e-06, cumulative = 0.07646
ExecutionTime = 182884 s ClockTime = 183024 s
Any advices to get better convergence to reach the steady state of the flow ?
My setup is as follow:
:fvSchemes:
ddtSchemes
default steadyState;
gradSchemes
default Gauss linear;
grad(p) Gauss linear;
grad(U) Gauss linear;
divSchemes
default none;
div(phi,U) Gauss upwind;
div(phi,k) Gauss upwind;
div(phi,epsilon) Gauss upwind;
div(phi,R) Gauss upwind;
div(R) Gauss linear;
div(phi,nuTilda) Gauss upwind;
div((nuEff*dev(grad(U).T()))) Gauss linear;
laplacianSchemes
default none;
laplacian(nuEff,U) Gauss linear corrected;
laplacian((1|A(U)),p) Gauss linear corrected;
laplacian(DkEff,k) Gauss linear corrected;
laplacian(DepsilonEff,epsilon) Gauss linear corrected;
laplacian(DREff,R) Gauss linear corrected;
laplacian(DnuTildaEff,nuTilda) Gauss linear corrected;
interpolationSchemes
default linear;
interpolate(U) linear;
snGradSchemes
default corrected;
fluxRequired
default no;
p;
:fvSolution:
solvers
p PCG
preconditioner DIC;
tolerance 1e-06;
relTol 0.01;
U PBiCG
preconditioner DILU;
tolerance 1e-05;
relTol 0.1;
k PBiCG
tolerance 1e-05;
relTol 0.1;
epsilon PBiCG
tolerance 1e-05;
relTol 0.1;
R PBiCG
tolerance 1e-05;
relTol 0.1;
nuTilda PBiCG
tolerance 1e-05;
relTol 0.1;
SIMPLE
nNonOrthogonalCorrectors 0;
relaxationFactors
p 0.3;
U 0.7;
k 0.7;
epsilon 0.7;
R 0.7;
nuTilda 0.7;
:RASProperties:
RASModel laminar;
turbulence off;
printCoeffs on;
laminarCoeffs
Thank you very much.
Have a nice day
Francois
francois is offline   Reply With Quote
Old   February 25, 2009, 11:33
Default Hi all, Hopefully I have so
Francois Beaubert
Hi all,
Hopefully I have some time to go back on this case ...
My runs don't reach the steady state and convergence is still not achieved with residuals not so low.
I've attached some pictures to better describe my case. It's a simple rotor/stator configuration with a hole in the stator.
I've also attached the distribution of the u,v,w velocity components on a radial line between the rotor and stator.
You can see that steady state is not reach here: one can observe large variation of u,v,w profiles between iteration 80000 and 90000. The behaviour is the same for a greater number of iteration (currently I'm at 120000 iterations).
Below you can see isocontours of the u component around the rotor/stator and one can note a "shear layer" near the rotor which oscillates with iterations (this trend is also observed on the uvw distribution figure just above)
And to conclude below are the evolution of residuals with the iterations for Ux and Uy for example:
So I still have a few questions:
* what is the best procedure to obtain a steady state
* is my computational domain too small (Ddomain = 4rotor and Hdomain = 3Drotor)for this problem with a "feedback" of the outlet boundary condition
I will be very pleased to have some advices/ideas frome somone on those points and forgive me for this long post.
Thanks you very much
Regards
Francois
Old   February 25, 2009, 11:40
Default Oup's sorry for the images Wi
Francois Beaubert
Will try again here :
Computationaldomain:
distribution of the u,v,w velocity components on a radial line between the rotor and stator:
u v w contours:
Residuals:
Old   February 25, 2009, 11:50
Default Humm ... sorry Don't work her
Francois Beaubert
Humm ... sorry
Don't work here with firefox 3.06 on ubuntu 8.10
What the best way to send/attach picture or files on the message board ?
I use:
\ image{foo} or \ attach{foo} with no space between \ and the after word
It seems that I always have to struggle until death to be able to send some files or images here.
Old   February 25, 2009, 22:46
Default I think your syntax is probabl
Andrew King
andersking is on a distinguished road
I think your syntax is probably fine, but there's a very small limit on image sizes, 50K I think. It doesn't stop you from posting, but won't show the images.
Less than 50K is fine.
Cheers
Andrew
Dr Andrew King
Fluid Dynamics Research Group
Curtin University
andersking is offline   Reply With Quote
Old   February 26, 2009, 05:18
Default Thanks Andrew for your advice
Francois Beaubert
But my images sizes are always under 50k and I never saw the dialog for file upload
So the problem seems to be elsewhere ...
Cheers
Francois
Old   February 27, 2009, 00:19
Default Hmmm, hopefully it will all ge
Andrew King
Hmmm, hopefully it will all get betted with the new forum software.
Cheers
Andrew
Dr Andrew King
Curtin University
Old   March 18, 2009, 15:59
Francois Beaubert
I've just modified the first post and was able to include some of the images which could not be posted in the last forum...
Yeah ... the new forum is better
Old   November 19, 2009, 13:33
Default Same problem too...
Valerio Novaresio
novyno is on a distinguished road
I have the same convergence problem... Can someone help us?
...The best way to acquire new knowledge is to share it...
novyno is offline   Reply With Quote
How to reach steady state solution Sally FLUENT 11 July 27, 2018 08:01
Convergence problem using simpleFoam steady state vvqf OpenFOAM Running, Solving & CFD 12 May 18, 2011 07:51
time to reach steady state with transient simulati prabhu CFX 2 April 21, 2008 10:18
What if I use turbfoam instead of simplefoam what is steady turblence lakeat OpenFOAM Running, Solving & CFD 4 January 18, 2008 12:13
Time to reach steady state for cavity flow? Quarkz Main CFD Forum 8 July 15, 2005 21:42
