Formulation in compressibleInterFoam
Like Tree33Likes
Old   September 24, 2010, 15:36
Default dgdt source term in alpha equation
  #21
Richard Kenny
richpaj is on a distinguished road
Just to recap before I make an observation about the code details we have the
following equations for the 2 phase mixture:
rho (mixture density) = alpha1 * rho1 + alpha2 * rho2 ......(1)
Mass continuity for each phase of the form:
ddt( rho1 * alpha1) + div( rho1 * alpha1 * U ) = 0 ...........(2)
which can be rearranged as
ddt( alpha1) + div( alpha1 * U ) = - ( alpha1 / rho1 ) * DDt( rho1 ) ..........(3)
Then, introducing a compressibility so that rho1 = rho0 + psi1 * p yields
ddt( alpha1) + div( alpha1 * U ) = - ( alpha1 * psi1 / rho1) DDt( p ) .......(4)
A similar equation exists for alpha2 so that by addition we obtain
div( U ) = - { ( alpha1 * psi1 / rho1) + ( alpha2 * psi2 / rho2) } DDt( p ) ......(5)
where alpha1 + alpha2 = 1.
So, (4) can be rewritten with a number of differing possibilities for the RHS e.g
RHS = - ( alpha1 * psi1 / rho1) DDt( p ) (a)
RHS = alpha1 * div( U) + alpha1 * dgdt (b)
where dgdt = { (alpha2 * psi2 / rho2) - (alpha1 * psi1 / rho1) } DpDt cf. pEqn.H i.e.
if (nonOrth == nNonOrthCorr)
dgdt =
(pos(alpha2)*(psi2/rho2) - pos(alpha1)*(psi1/rho1))
*(pEqnComp & p);
(b) appears to be preferred owing to the use of the explicit form for "alpha1 * div(U)"
to balance the convection term in the transport equation (cf. alphaEqn.H).
It remains to treat the term "alpha1 * dgdt" appropriately and this
is handled either implicitly or explicitly
depending on the sign of dgdt. As a result I would anticipate the following:
dgdt < 0 ---> Implicit, SpTerm += dgdt[celli] ( this will appear as fvm::Sp(SpTerm, alpha1)
dgdt > 0 ----> Explicit, SuTerm += dgdt[celli] * alpha1[celli]
It is given that Sp is initialized with 0 and Su with "alpha1 * div(U)" in alphaEqns.H
in which case I'd expect the following:
forAll(dgdt, celli)
if (dgdt[celli] > 0.0 && alpha1[celli] > 0.0)
Su[celli] += dgdt[celli]*alpha1[celli];
else if (dgdt[celli] < 0.0 && alpha1[celli] < 1.0)
Sp[celli] += dgdt[celli];
Instead we find the following in alphaEqns.H i.e.
forAll(dgdt, celli)
Sp[celli] -= dgdt[celli]*alpha1[celli];
Sp[celli] += dgdt[celli]*(1.0 - alpha1[celli]);
which appears to suggest Sp should have been initialized with "alpha1 * dgdt ", or have I missed something here I wonder?
Regards,
Richard K.
Elham, hadisafaei, pfhan and 6 others like this.
richpaj is offline   Reply With Quote
Old   September 24, 2010, 15:55
Scott Miller
scttmllr is on a distinguished road
Hi Richard,
In your eqn (4), you would want the LHS term to be of the form "U * div(alpha1)" in order for alpha1 to remain bounded. If you subtract an "alpha1 * divU" from each side of (4), you should get what is in the code. Note that this change will make your compressible pressure equation come out the same, but the RHS term of the alpha equation will change. You can replace the divU that we just put on the RHS of (4) via use of the pressure equation.
I hope that makes sense, and helps.
-Scott
scttmllr is offline   Reply With Quote
Old   September 25, 2010, 08:14
Richard Kenny
Hello there,
My understanding though is that discretization is applied to
the conserved form of the phase fraction equation for alpha1
in order to permit a conserved representation of interface compression
(not indicated in eqn. (4) but contained in code). Boundedness is then sought by sorting out the RHS
of (4) into explicit and implict terms.
Futhermore, the structure of the eqn being solved is given by MULESTemplates.C
fvScalarMatrix psiConvectionDiffusion
fvm::ddt(rho, psi)
+ fv::gaussConvectionScheme<scalar>(mesh, phi, UDs).fvmDiv(phi, psi)
//- fv::gaussLaplacianScheme<scalar, scalar>(mesh, CDs, snGrads)
//.fvmLaplacian(Dpsif, psi)
- fvm::Sp(Sp, psi)
- Su
where here psi<=>alpha1 with the flux terms generated according to alphaEqns.H
Eventually, I intend to compare (A) (original code) and (B) below to see
if they yield similar results. The related experiments we've done
might also possibly guide the more suitable choice of representation,
(A)
Initialization
Su = alpha1 * div( U)
Sp = 0
forAll(dgdt, celli)
(B)
Initialization
Su = alpha1 * div( U) + alpha1 * dgdt
Sp = 0
forAll(dgdt, celli)
Su[celli] -= dgdt[celli]*alpha1[celli];
Regards,
Richard K.
Old   September 29, 2010, 02:56
Richard Kenny
I see now I made a mistake in the identification of dgdt it should be:
dgdt = { ( psi2 / rho2) - (psi1 / rho1) } DpDt
The RHS of (4) can now be written as:
= - alpha1 * ( div( U) + psi1 / rho1) DDt( p ) ) + alpha1 * div(U)
= alpha1 * alpha2 * dgdt + alpha1 * div( U)
and where the following are noted:
1) treat "alpha1 * div (U)" explicitly to balance the explicit form of the transport equation.
(used to initialize Su)
2) for "dgdt" term
dgdt < 0 ---> Implicit, Sp[celli] += dgdt[celli]*(1.0 - alpha1[celli])
dgdt > 0 ----> Explicit, SuTerm += dgdt[celli] * alpha1[celli],
Implicit, SpTerm -= dgdt[celli] * alpha1[celli]
Regards,
RGK
pfhan, RjwV, YHBen and 1 others like this.
Old   January 24, 2011, 11:57
Illya Shevchuk
linch is on a distinguished road
Sorry for stupid questions, but:
what's the difference between DDt( p ) and DpDt? Both seem to be Lagrangian derivatives of pressure...
why is
- ( alpha1 * psi1 / rho1) DDt( p ) = - alpha1 * ( div( U) + psi1 / rho1) DDt( p ) ) + alpha1 * div(U)
alpha1 * div(U) was added and alpha1 * div(U)DDt(p) substracted
and from the next step it comes out that:
-(div( U) + psi1 / rho1) DDt( p ) = alpha2 * { ( psi2 / rho2) - (psi1 / rho1) } DpDt
could somebody please explain it in detail?
and why there must be a differentiation between dgdt>0 and dgdt<0?
I'll appreciate any help to clarify the derivation.
Regards,
Ilya
linch is offline   Reply With Quote
Old   January 28, 2011, 04:03
Richard Kenny
>what's the difference between DDt( p ) and DpDt? Both seem to be Lagrangian >derivatives of pressure...
DDt is the convective derivative and Ddt is the lagrangian temporal derivative.
one part will be treated explicitly and the other implicitly
take a look at P37 of the programmer's manual which explains
how explicit and implicit source terms work.
Good luck,
RGK
Old   January 28, 2011, 08:26
Illya Shevchuk
Thank you, I'll follow your advices!
Isn't it the same?
best,
Ilya
Old   September 1, 2011, 04:20
Nima Samkhaniani
nimasam is on a distinguished road
hi friends thanks for ur all great discussion!!!
but i still cant understand from where dgdt comes from?
LHS of eq 4 is : - ( alpha1 * psi1 / rho1) DDt( p ) but how we can add alpha*div(U) and subtract alpha*div(U)*ddt(p) ? it would not remain the same!!!!
im totally confused please explain more
nimasam is offline   Reply With Quote
Old   September 1, 2011, 06:11
Richard Kenny
>Isn't it the same?
>>best,
>>Ilya
yes, you're quite right, I should've written "DDt is the convective derivative and Ddt the Eulerian time derivative"
Sorry, there was a "hanging" right ")", the following in (4) namely,
should read:
- alpha1 * ( div( U) + psi1 DDt( p ) / rho1 ) + alpha1 * div(U)
hopefully that clarifies.
Rgds.
pfhan likes this.
Old   September 5, 2011, 14:18
Reza khodadadi
reza_65 is on a distinguished road
Send a message via ICQ to reza_65 Send a message via AIM to reza_65 Send a message via Yahoo to reza_65
Originally Posted by haghajani View Post
Hi there,
I am trying to add energy eq. to compressibleInterFoam.
To do this, enthalpy should be evaluated using T field. Getting inspiration from compressible solvers, thermoType and mixture properties should be given in thermophysicalProperites dictionary; I have no idea how could it be done for multiphase solvers?
I tried to define the enthalpy in createField, i.e. h=Cp.T, but then it throws error; I think it would need default boundary condition, because hEqn is being solved.
Any idea or anyother approach is appreciated?
best regards,
Hamed
i have same problem, too. i have no idea what should i do, for adding energy equation in CompressibleInterFoam solver.
do you solve this problem???
please help me..
with many regards.
Reza khodadadi.
reza_65 is offline   Reply With Quote
Old   September 15, 2011, 16:24
Nima Samkhaniani
hi friends
could you tell me why in the pEqn.H in compressibleInterFoam for calculation of phi , only incompressible part is considered?
phi += pEqnIncomp.flux();
Old   May 21, 2012, 08:13
Illya Shevchuk
RHS =
2) for "dgdt" term
Explicit would be ----> SuTerm += dgdt[celli] * alpha1[celli] * (1.0 - alpha1[celli]) , or am I wrong? Besides of it, there would be no implicit part if the source would be treated explicitly. I still don't understand, where the if dgdt>0 part comes from.
Old   May 21, 2012, 11:01
Richard Kenny
yes, what you write looks correct, must've composed the original in
haste or late at night (!)
dgdt is evaluated in pEqn cf.
dgdt =
*(p_rghEqnComp & p_rgh);
and where the sign variation derives from the coefficients multiplying
'p_rgh' in p_rghEqnComp. If you examine the definition of fvm::Sp(..)
(programmer's manual) you'll see how these terms reinforce the diagonal
coefficients of the fvMatrix.
Rgds,
Richard K.
Old   May 21, 2012, 11:46
Illya Shevchuk
Thanks Richard, but I think we're talking at cross-purposes.
In the source codes (compressibleInterFoam) it is indeed
So it has nothing to do with your haste.
dgdt =
For this one, I wasn't wondering about where dgdt is evaluated. Rather I was wondering about the origin and the meaning of the peace of code quoted above. Sp += foo; Su -= foo; looks "wrong" for me, because Su must be something like Su~Sp*X, where X is the field we're solving for. If alpha1 would have dimensions() different from (0 0 0 0 0 0 0), this wouldn't work. But since alpha1 is dimless, it works.
I hope now you understand my confusion. The quoted code seems to be wrong, but it also seems to perform right. Until this point, I can follow your derivation, but I'm still missing the last step to derive Sp & Su for (dgdt[celli] > 0.0 && alpha1[celli] > 0.0)
Best regards,
Illya
Old   May 21, 2012, 21:27
Richard Kenny
Best regards,
Illya
Ok now I understand, I think you appear to have overlooked the factor "alpha1" that will multiply 'Sp'
in fvm::Sp (Sp, alpha1) cf. MULESTemplates.C where the matrix equation to be solved is:
is the following:
fvm::ddt(rho, psi)
- fvm::Sp(Sp, psi)
- Su
Also,
alpha1 * alpha2 * dgdt = ( alpha1 - alpha1^2 ) *dgdt
so that if dgdt> 0 we get
Sp[celli] -= dgdt[celli]*alpha1[celli]; // "-alpha1^2 *dgdt " contribution
Su[celli] += dgdt[celli]*alpha1[celli]; // alpha1 * dgdt contribution
and where we remember to extract the factor alpha1 from Sp, this is inserted later
in the implicit term "fvm::Sp(Sp, alpha1)". Check out the programmer's manual
for reference to fvm::Sp(..).
Good luck,
Regards,
Richard K.
hwangpo, perao and jameswilson620 like this.
Old   May 22, 2012, 04:35
Illya Shevchuk
Hi Richard,
No, I haven't overlooked it. Moreover, this fact has initiated my doubts. Because(!) Sp is being multiplied with the primary variable we're solving for, I was expecting it to have different form than Su. So don't worry, I know what Su's & Sp's are
Also,
Yes, that's the answer I was looking for! Thanks a lot. alpha1 * alpha2 is a quadratic term, while ( alpha1 - alpha1^2 ) is linear-quadratic. That was the reason for my confusion.
Thank you very much and have a nice day!
Best regards,
Illya
Old   June 4, 2013, 09:03
NaiXian Leslie Lu
LESlie is on a distinguished road
2) for "dgdt" term
Regards,
RGK
Thank you for the discussion! Really beneficial!
I have a confusion about the implicit/explicit treatment of the source discretisation.
As:
ddt(alpha1) + U*div(alpha1) = alpha1*alpha2*dgdt
According to the manual when coefficient is greater than zero it is implicit and vice versa.
So shouldn't it be
dgdt > 0 ---> Implicit
dgdt < 0 ---> Explicit
instead?
Cheers,
Leslie
LESlie is offline   Reply With Quote
Old   June 4, 2013, 21:16
Richard Kenny
As:
So shouldn't it be
instead?
Cheers,
Leslie
By way of example, in
D[ alpha ]/Dt = rho * alpha
rho < 0 : treated implicitly i.e. reinforces diagonal coefficient of alpha,
rho > 0 : treated explicitly
which informs the handling of "ddt(alpha1) + U*div(alpha1) = alpha1*alpha2*dgdt".
I hope this helps,
Rgds,
Richard.
Old   June 5, 2013, 10:09
NaiXian Leslie Lu
I hope this helps,
Rgds,
Richard.
Hi Richard,
This is my confusion, on programmersGuide P-37
"Therefore OpenFOAM provides a mixed source discretisation procedure
that is implicit when the coefficients that are greater than zero, and explicit for the coefficients less than zero."
By the way do you have any idea why they take away the
adjustPhi(phiHbyA, U, p_rgh) in the pEqn.H which for example exists in interFoam? Shouldn't the flux still be adjusted to obey the continuity despite that it's compressible?
Best Regards,
Leslie
Old   June 5, 2013, 21:15
Richard Kenny
Hi Richard,
Best Regards,
Leslie
Hello there,
1) but the source terms it references are located on the RHS of the given
equation in the following canonical manner
L[U] = SP + SU
(where L is some differential operator and SP&SU are implicit and explicit
source terms for example)
so that when you discretize you get something like
Ap * Up = F(Up-1, .. )
and where Ap is the diagonal coefficient.
2) as for adjustPhi(phiHbyA, U, p_rgh)
this is applied in the case of incompressible problems when the pressure
reference (or level) is unknown. If you look in the source code
(src/finiteVolume/cfdTools/general/adjustPhi/adjustPhi.C) you'll find:
if (p.needReference())
By contrast, compressible problems have an equation of state or
compressibility relation which acts to constrain the total pressure.
Hopefully this clarifies,
Regards,
Richard
compressible, compressibleinterfoam, theory
Low Reynolds Number k-epsilon formulation CFX 10.0 Chris CFX 4 December 7, 2009 23:51
Immersed Boundary Formulation Rave Main CFD Forum 0 August 11, 2008 14:55
DPM Steady formulation with collisions kulwinder FLUENT 0 May 22, 2004 18:44
energy equation formulation Pedro Phoenics 1 July 5, 2001 12:17
Compressible vs. Incompressible formulations Fernando Velasco Hurtado Main CFD Forum 3 January 7, 2000 16:51
