January 21, 2010, 02:47 |
NACA - Inclined flow / symmetryPlane
Stefan
Hello folks,
i investigate some elementary hydrodynamics using i.e. NACA profiles. The following illustration shows the case in 2D: Code:
OUTLET _________________________ |domain | | | | | s | | y | #| m | ##| m | ##| e S | ###| t I | ###| r D | ####| y E | ####| P | ####| l | ####| a | ####| n | ####| e | ###| | | |_______________________| INLET / / / / / / / / / / / / inclined flow My question/problem: When i want a specified angle fo attack, what is the direction of the flow on the reflected INLET (domain)? I guess the inclined flow is mirrored, too. Is there a possibility to maintain the inclined flow direction in case of that (e.g. that only the geometry/mesh will be duplicate, not the physical boundaries, maybe the mirrorMesh utility could help)? thx, /Stefan |
airfoil, inclined flow, naca, symmetryplane |
benchmark: flow over a circular cylinder | goodegg | Main CFD Forum | 12 | January 22, 2013 11:47 |
Inclined Open Channel Flow | Abe Gonzalez | FLUENT | 2 | April 15, 2008 12:32 |
reversed flow at velocity inlet / mass flow inlet | ib | FLUENT | 1 | March 26, 2007 13:11 |
How to change from mass flow to volume flow rate | stanley | FLUENT | 1 | February 2, 2007 06:44 |
transform navier-stokes eq. to euler-eq. | pxyz | Main CFD Forum | 37 | July 7, 2006 08:42 |
