Problem when running rhoSonicFoam solver
Old   July 12, 2006, 10:45
Default Hi, I'd like to study what ha
Gabriele Ottino
gaottino is on a distinguished road
I'd like to study what happens in a convergent-divergent tube. So I used the solver "rhoSonicFoam". But, when I run the case, it stops and in the shell these words are shown:
--> FOAM FATAL ERROR :
request for surfaceScalarField phi from objectRegistry region0 failed
available objects of type surfaceScalarField are
4
weightingFactors
limiter
differenceFactors_
phiv
From function objectRegistry::lookupObject<type>(const word&) const
in file /home/dm2/henry/OpenFOAM/OpenFOAM-1.3/src/OpenFOAM/lnInclude/objectRegistryTempl ates.C at line 122.
FOAM aborting
Foam::error::printStack(Foam:stream&)
Foam::error::abort()
Foam::GeometricField<double,> const& Foam::objectRegistry::lookupObject<foam::geometric field<double,> >(Foam::word const&) const
Foam::pressureInletVelocityFvPatchVectorField::upd ateCoeffs()
Foam::GeometricField<foam::vector<double>, Foam::fvPatchField, Foam::volMesh>::GeometricBoundaryField::updateCoef fs()
Foam::fvMatrix<foam::vector<double> >::fvMatrix(Foam::GeometricField<foam::vector<doub le>, Foam::fvPatchField, Foam::volMesh>&, Foam::dimensionSet const&)
Foam::fv::gaussConvectionScheme<foam::vector<doubl e> >::fvmDiv(Foam::GeometricField<double,> const&, Foam::GeometricField<foam::vector<double>, Foam::fvPatchField, Foam::volMesh>&) const
rhoSonicFoam [0x42dd76]
rhoSonicFoam [0x436675]
rhoSonicFoam [0x413a20]
__libc_start_main
__gxx_personality_v0
I suppose that I didn't define one variable, but I don't really understand what does it mean.
Someone could help me, please?
Best regards,
Gabriele
gaottino is offline   Reply With Quote
Old   July 17, 2006, 19:02
Default Hello, I also see the same
munder
I also see the same messages when running rhoSonicFoam but only when doing any "freestream-type" inlet/outlet type boundary conditions. If the boundaries are all fixed, rhoSonicFoam runs fine.
Hope this helps,
Mark
Old   July 19, 2006, 08:11
Default Hi, thanks for your answer.
Gabriele Ottino
But I have the same problem also when I use the other types of boundary conditions at the inlet and at the outlet. In particular, I have a convergent-divergent tube: so I'd like to impose the pressure both at the inlet and at the outlet. So I use the "pressureInlet" and "pressureOutlet" conditions respectively, but FoamX gives always the same error messages.
I don't know why.
Thanks for your patience.
Gabriele
Old   March 1, 2011, 04:59
Samuel ARNAUD
sixwp is on a distinguished road
Hi Gabriele,
I know it's been a long time since you had this problem, but I am wondering if you managed to solve this matter (as I'm almost in the same situation), how did you do?
Best Regards
Sam
sixwp is offline   Reply With Quote
solver not running Karteek Siemens 1 May 9, 2008 22:59
Problem while running solver in star4.0 for linux deisler Siemens 7 March 14, 2007 04:16
PROBLEM IN SOLVER RUNNING PARALLEL Íñigo CFX 3 February 4, 2007 05:08
problem running the solver chotet CFX 1 January 17, 2007 03:59
Running CFD solver on PC Reaz Hasan Main CFD Forum 16 March 14, 2002 05:55
