timeActivatedExplicitCellSource howto
Old   March 18, 2010, 08:48
Default timeActivatedExplicitCellSource howto
Aniko Rakai
ancsa is on a distinguished road
Dear Foamers,
I was trying to set up a scalar point source to scalarTransportFoam and I found timeActivatedExplicitCellSource which seems to be the perfect tool, but I cannot figure out exactly how to use it. Does someone have experience, or is it used in some of the tutorials? Should I use a cellSetDict to define?
Any guidance is appreciated.
ancsa is offline   Reply With Quote
Old   March 25, 2010, 05:59
Robertas N.
r08n is on a distinguished road
Not sure about timeActivatedExplicitCellSource, but it seems to be similar to timeActivatedExplicitMulticomponentPointSource, which is used in tutorials/lagrangian/porousExplicitSourceReactingParcelFoam solver. There is a tutorial "filter"; you might look there and the source code for this solver. I just started raking through it myself. I suspect that the approach used in this solver and tutorial is described in the thesis http://powerlab.fsb.hr/ped/kturbo/op...olmPhD2008.pdf. Pls correct if I'm wrong, because these explicit sources are important to me too.
(The above apply to OF version 1.6 that I have; I don't know if these are included in other versions.)
r08n is offline   Reply With Quote
Old   March 26, 2010, 05:48
Aniko Rakai
Hi, I'm also having OF1.6 and I have also found this filter tutorial, but meanwhile I created a turbulent transport equation with a source term which seems to be working with a new source variable. I havent tested much yet though. The equation is very simple and it is not coupled but I dont need that so far, if this is enough for you I can send it.
HowTo Make paraFoam from OpenFOAM15 work on OpenSuse11 by installing Qt435 in home directory wenterodt OpenFOAM Installation 52 June 26, 2009 17:01
Howto install OpenFOAM on mandriva2009qt44 with Qt435 in home directory gzy_1228 OpenFOAM Installation 0 November 15, 2008 14:31
A new Howto on the OpenFOAM Wiki Compiling OpenFOAM under Unix mbeaudoin OpenFOAM Installation 2 April 28, 2006 08:54
Howto manually merge a pst-file? DrA Siemens 2 December 6, 2005 08:57
chemical reaction - howto Dan Sorensen Siemens 1 February 21, 2000 09:20
