September 2, 2014, 16:11 |
Residual fluctuation, cylinder internal flow
Hello everyone,
I am doing simulation for internal laminar flow in a cylinder and I am using simple foam. I got the required results that match with analytical solution. But I have a problem in my residual curve. I get some fluctuation in residual curve (figure is attached), although my results are fine. I want to ask, does this fluctuation matters or not as I get in my case. I mean, the residual curve should be smooth or not. Thank you My fvScheme is as follows divSchemes { default none; div(phi,U) Gauss upwind; div(phi,k) Gauss upwind; div(phi,epsilon) Gauss upwind; div(phi,R) Gauss upwind; div(R) Gauss upwind; div(phi,nuTilda) Gauss upwind; div((nuEff*dev(T(grad(U))))) Gauss linear; } |
September 3, 2014, 07:05 |
joegi
Rep Power: 16 |
Residuals are not your solution. Your solution is the quantity of interest.
Did you get a good agreement with the analytical solution using this numerical scheme? Because you are using a first order scheme, and they are highly diffusive. From your residuals I can see that maybe you were changing some parameter in the numerical scheme, and that is reflected in the jumps in the residuals. jg |
September 3, 2014, 07:18 |
hello Joegi
Yes I am getting good agreement with analytical solution and I didn't change any parameter while solution was running. But I was getting these peaks in residual. What other fcScheme I can try ?? Thank you |
a problem with convergence in buoyantSimpleFoam | skuznet | OpenFOAM Running, Solving & CFD | 6 | November 15, 2017 12:12 |
Micro Scale Pore, icoFoam | gooya_kabir | OpenFOAM Running, Solving & CFD | 2 | November 2, 2013 13:58 |
pimpleFoam: turbulence->correct(); is not executed when using residualControl | hfs | OpenFOAM Running, Solving & CFD | 3 | October 29, 2013 08:35 |
How to write k and epsilon before the abnormal end | xiuying | OpenFOAM Running, Solving & CFD | 8 | August 27, 2013 15:33 |
SLTS+rhoPisoFoam: what is rDeltaT??? | nileshjrane | OpenFOAM Running, Solving & CFD | 4 | February 25, 2013 04:13 |
