Probe location for moving mesh
Old   May 25, 2011, 06:46
Default Probe location for moving mesh
Neil Southall
NeilCFD is on a distinguished road
I'm running a moving mesh simulation (using InterDyMFoam) and I have a number of probes defined in controlDict to measure pressures during the simulation. The runs are of quite long duration (> 10,000 s) and often they have to be restarted. The problem with this is that the probe locations then have to be recalculated manually to allow for the displacement/rotation of the mesh, which is tedious and can lead to errors. Does anyone know of a way to specify probes in the body coordinate system rather than globally?
I'm using OF 1.7.1. From my controlDict:
application interDyMFoam;
startFrom latestTime;
startTime 500;
stopAt endTime;
endTime 18000;
deltaT 0.01;
writeControl adjustableRunTime;
writeInterval 1.0;
purgeWrite 0;
writeFormat binary;
writePrecision 10;
writeCompression compressed;
timeFormat general;
timePrecision 6;
runTimeModifiable yes;
adjustTimeStep yes;
maxCo 0.5;
maxAlphaCo 0.5;
maxDeltaT 1;
functions
probes
type probes;
functionObjectLibs ( "libsampling.so" );
enabled true;
outputControl timeStep;
outputInterval 1;
probeLocations
#include "$FOAM_CASE/../sensorGrid.long"
fields
p
Hope someone has some ideas!
Neil
NeilCFD is offline   Reply With Quote
Old   September 17, 2012, 12:13
elliot_hfx is on a distinguished road
Hi Neil,
I met similar problems as yours. Did you solve this problem?
Did you find a way to specify probes in the body coordinate system rather than globally?
Thanks.
Elliot
elliot_hfx is offline   Reply With Quote
[ICEM] Unstructure Meshing Around Imported Plot3D Structured Mesh ICEM kawamatt2 ANSYS Meshing & Geometry 17 December 20, 2011 11:45
2d irregular grid Remy Main CFD Forum 1 December 22, 2008 04:49
basic of mesh refinement arya CFX 4 June 19, 2007 12:21
unstructured vs. structured grids Frank Muldoon Main CFD Forum 1 January 5, 1999 10:09
