dangling edges in refined hexahedral grid
Like Tree1Likes
  • 1 Post By 31415
Old   July 23, 2010, 08:09
Default dangling edges in refined hexahedral grid
Lars
31415 is on a distinguished road
dear foamers,
i would like to perform local refinement of hexahedral grid in octtree-like structure. my concern is that this approach generates dangling edges (or faces, in 3d) where a refined cell is adjacent to a coarser cell.
how do i handle the situation in the attached pic? to the right of the coarse face F0, two fine faces F1 and F2 have created an extra vertex V3.
if V3 is not a vertex of F0 this mesh is invalid, isn't it? do i have to replace the quadrilateral F0 with the pentagon V0-V1-V2-V3-V4? then the angle V4-V3-V2 is 180°. does this impose an accuracy or mesh orthogonality problem?
in general, what is the best approach to locally refine hexahedral meshes? this seems to be standard in gerris (see below), but i have no idea how to work with dangling
edges in openfoam.
example from gerris:
mm.abdollahzadeh likes this.
31415 is offline   Reply With Quote
Old   July 23, 2010, 08:41
Sandeep Menon
deepsterblue will become famous soon enough
Well, this isn't exactly a 'dangling' entity. One of the benefits to having polyhedral mesh support is the fact that you can pull-off stunts like this quite easily. It looks like you've already grasped the general idea - the 'pentagon' V0-V1-V2-V3-V4 is exactly how it should be.
In general, finite-volume codes don't have the 180-degree restrictions for adjacent cell-faces. What's important is the mesh-orthogonality. In this case, there might be a slight deviation of the cell-to-cell vector away from the face centroid (like the F0-F2 vector for face V3-V4), but non-orthogonal corrections can account for that.
OpenFOAM already has this capability, using dynamicRefineFvMesh.
Sandeep Menon
University of Massachusetts Amherst
https://github.com/smenon
deepsterblue is offline   Reply With Quote
Old   July 24, 2010, 09:53
Hrvoje Jasak
Heya,
If you actually generated a mesh like this (with dangling edges) and it's causing you trouble, there is a way to fix it.
Ages ago I've written a utility to do just that, when we were moving FOAM onto full polyhedral support. It is called zipUpMesh and works without trouble.
By the bye, this is one of the most complex algorithm I've ever written - there is a special award if you can document how it does the job on the wiki (I'm not sure I would be able to write it down myself)
Enjoy,
Hrv
Hrvoje Jasak
On grid independent solution for pulsatile flow David FLUENT 5 March 25, 2022 03:33
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 08:54
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 19:43
Combustion Convergence problems Art Stretton Phoenics 5 April 2, 2002 05:59
Grid Independent Solution Chuck Leakeas Main CFD Forum 2 May 26, 2000 11:18
