Variable thermophysical property for incompressible flow
Old   September 1, 2010, 01:21
Default Variable thermophysical property for incompressible flow
Jinbiao Xiong
JinBiao is on a distinguished road
Send a message via MSN to JinBiao
Hi foamers,
I am solving for a water flow through a cooler in which it experiences a large temperature drop. I tried to look for a way to implement the changeable thermophysical property of water. For the viscosity, it seems there is one only viscosity model for water, i.e., Newtonian.
In this forum I could also find some threads which are about to solve it in a compressible way. I am not sure about which way I should follow.
Thanks for any suggestion or discussion.
Jinbiao
JinBiao is offline   Reply With Quote
Old   September 1, 2010, 04:10
akidess's Avatar
Anton Kidess
Did you look at nonNewtonianIcoFoam? There are definitely more viscosity models available.
Old   September 1, 2010, 04:26
Jinbiao Xiong
Akidess, thanks for your reply.
I noticed there are other options also. But these viscosity models are for non-newtonian fluids. I am simulating water flow. So I don't think I can use them. It also seems to me that the viscosity in these model, such as CrossPowerLaw and BirdCarreau, are not related to temperature and pressure, but to the strain rate.
Now I am writing a new viscosity model. Hopefully I can introduce the water properties into the viscosity model. Then I can have a changeable viscosity.
Regards
Jinbiao
Old   September 1, 2010, 04:50
akidess's Avatar
Anton Kidess
Ah yes, sorry about that. I'll guess you'll have to come up with something yourself then, but that shouldn't be the hardest task. It should suffice to run through the viscosity volScalarField once every time step and change the values based on the other parameters.
Old   September 1, 2010, 08:11
Jinbiao Xiong
Yes, I followed that way. I am running the case now. If I am lucky, I can get some results soon. Thanks.
Jinbiao
two-phase flow with variable surface tension yf Main CFD Forum 1 May 19, 2006 09:58
two-phase flow with variable surface tension fatt128@hotmail.com Main CFD Forum 0 May 18, 2006 22:00
Variable mass flow at boundary Dimitrios FLUENT 6 November 27, 2003 02:24
Question on 3D potential flow Adrin Gharakhani Main CFD Forum 13 June 21, 1999 05:18
computation about flow around a yawed cone Tylor Xie Main CFD Forum 0 June 9, 1999 07:33
