nonNewtonianIcoFoam wmake
Old   September 29, 2010, 04:50
Post nonNewtonianIcoFoam wmake
T.D. is on a distinguished road
HI
I copied the nonNewtonianIcoFoam solver from the opt/openfoam main directory, to my user directory
and i changed as usual the "files" file inside Make in order to do wmake
when i do wmake i got this error:
user@king:~/applications/solvers/incompressible/nonNewtonianIcoFoam$ wmake
SOURCE=nonNewtonianIcoFoam.C ; g++ -m32 -Dlinux -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -I/opt/openfoam171/src/finiteVolume/lnInclude -I/opt/openfoam171/src/transportModels -I/opt/openfoam171/src/transportModels/incompressible/singlePhaseTransportModel -IlnInclude -I. -I/opt/openfoam171/src/OpenFOAM/lnInclude -I/opt/openfoam171/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linuxGccDPOpt/nonNewtonianIcoFoam.o
In file included from nonNewtonianIcoFoam.C:43:
createFields.H: In function "int main(int, char**)":
createFields.H:49: error: no matching function for call to "Foam::singlePhaseTransportModel::singlePhaseTrans portModel(Foam::volVectorField&, Foam::volScalarField&, Foam::surfaceScalarField&)"
/opt/openfoam171/src/transportModels/incompressible/singlePhaseTransportModel/singlePhaseTransportModel.H:78: note: candidates are: Foam::singlePhaseTransportModel::singlePhaseTransp ortModel(const Foam::volVectorField&, const Foam::surfaceScalarField&)
/opt/openfoam171/src/transportModels/incompressible/singlePhaseTransportModel/singlePhaseTransportModel.H:67: note: Foam::singlePhaseTransportModel::singlePhaseTransp ortModel(const Foam::singlePhaseTransportModel&)
/opt/openfoam171/src/finiteVolume/lnInclude/readPISOControls.H:8: warning: unused variable "momentumPredictor"
/opt/openfoam171/src/finiteVolume/lnInclude/readPISOControls.H:11: warning: unused variable "transonic"
/opt/openfoam171/src/finiteVolume/lnInclude/readPISOControls.H:14: warning: unused variable "nOuterCorr"
make: *** [Make/linuxGccDPOpt/nonNewtonianIcoFoam.o] Error 1
i don't understand why it tries to go back to /opt/ directories to look for the singlePhaseTransportModel, however this singlePhaseTransportModel i have changed it and put it in my user transportModels directory and compiled the libraries wmake libso and all was ok
but when i go to make my solver by wmake in the user also directory , i always get the previous error. ? !
help please
thanks a lot
T.D.
T.D. is offline   Reply With Quote
Old   November 4, 2010, 11:36
hamdi
hamcer is on a distinguished road
hi,
You have to do some changes in your hidden file .bashrc file
in the end of this file write:
export FOAM_INST_DIR=/home/<name>/OpenFOAM
foamDotFile=$FOAM_INST_DIR/OpenFOAM-1.6/etc/bashrc
[ -f $foamDotFile ] && . $foamDotFile
Note: you should have a OpenFOAM installed in your home.
after, launch a new terminal and compile your utilities
hope that your help.
hamdi
hamcer is offline   Reply With Quote
Patches for OpenFOAM 1.7 on MacOS X gschaider OpenFOAM Installation 101 September 21, 2011 05:37
Problems Installing OF 1.6 32 bit bucksfan OpenFOAM Installation 19 August 4, 2009 01:36
OpenFOAM15 installables are incomplete problem with paraFoam tryingof OpenFOAM Bugs 17 December 7, 2008 04:41
Problem of compilation OF 14Allwmake command not found erik_d OpenFOAM Bugs 13 September 13, 2008 21:45
[OpenFOAM] ParaFoam error message joey ParaView 1 October 2, 2006 13:28
