October 20, 2016, 12:44 |
droplet manipulation with EHD in interFoam
mobina.h.miri
Rep Power: 10 |
Hi formers,
I tried to simulate droplet detachment by electric field but when I disconnect the electric field (first the potential was 8.7e3 volte after 2 ms it became 0), after several millisecond the solution is diverged. The amount of the potential increase in top of the domain. I use Of 2.1.1 and my base solver is interfoam and added Maxwell tensor and charge density equation. I have attached geometry and potential contour. Can anyone help me and know what should I do? PLEAS HELP I tried several BCs. But what is your suggestion? with best wishes Ue19.jpg alpha19.jpg Ue215.jpg alpha19[1].png |
2D water droplet fall in InterFoam | muhanad | OpenFOAM Pre-Processing | 3 | May 3, 2019 03:48 |
Falling Droplet using InterFoam | cosbergel | OpenFOAM Running, Solving & CFD | 5 | May 16, 2018 05:21 |
Droplet Falling using interFoam | Cara Gao | OpenFOAM Running, Solving & CFD | 14 | August 24, 2015 21:47 |
Artificial high pressure under an impacting droplet using interFoam | hadisafaei | OpenFOAM Running, Solving & CFD | 4 | November 30, 2014 16:06 |
Interfoam Droplet under shear test case | adona058 | OpenFOAM Running, Solving & CFD | 3 | May 3, 2010 18:46 |
