October 17, 2010, 03:05 |
how to set up wall function in bubbleFoam
trister
Rep Power: 16 |
Hi
I try to calculate turbulent bubbly flow by bubbleFoam. I don't know how to set up wall function in k and epsilon file in 0 folder since "bubbleColumn" tutorial doesn't treat turbulent flow and wall function. I suppose that "zeroGradient" is unreasonable. Can anyone help me? |
October 18, 2010, 14:51 |
Alberto Passalacqua
Rep Power: 36 |
Please, check the code. Wall-functions in bubbleFoam are coded directly in the solver and automatically applied when the turbulence model is active.
Best,
Alberto Passalacqua GeekoCFD - A free distribution based on openSUSE 64 bit with CFD tools, including OpenFOAM. Available as in both physical and virtual formats (current status: http://albertopassalacqua.com/?p=1541) OpenQBMM - An open-source implementation of quadrature-based moment methods. To obtain more accurate answers, please specify the version of OpenFOAM you are using. |
October 24, 2010, 04:16 |
trister
Rep Power: 16 |
Thanks.
I found all files related turbulence e.g. wallfunctions.* are in \applications\solvers\multiohase\bubbleFoam. |
November 4, 2010, 07:18 |
Franz Jacobsen
Rep Power: 16 |
Hi Adouchihihiitoko
Did you manage to get bubbleFoam to solve with turbulence as the RASModel ? I get the following messages, keyword laplacian(DepsilonEff,epsilon) is undefined in dictionary "/home/f/OpenFOAM/f-1.7.0/working2/sludge2D/test2/system/fvSchemes::laplacianSchemes" file: /home/f/OpenFOAM/f-1.7.0/working2/test2/system/fvSchemes::laplacianSchemes from line 42 to line 45. From function dictionary::lookupEntry(const word&, bool, bool) const in file db/dictionary/dictionary.C at line 395. |
November 4, 2010, 07:57 |
Laurence R. McGlashan
Rep Power: 23 |
Just add the entry into system/fvSchemes, and be careful using the turbulence model, it's very basic! Remember it's not using the turbulence libraries that can be used for single phase flows, so the only entry it uses in the RAS dictionary is turbulence on/off.
If you look in kEpsilon.H: Code:
// Dissipation equation fvScalarMatrix epsEqn ( fvm::ddt(beta, epsilon) + fvm::div(phib, epsilon) - fvm::laplacian ( alphaEps*nuEffb, epsilon, "laplacian(DepsilonEff,epsilon)" ) == C1*beta*G*epsilon/k - fvm::Sp(C2*beta*epsilon/k, epsilon) );
Laurence R. McGlashan :: Website |
November 5, 2010, 05:59 |
Franz Jacobsen
Rep Power: 16 |
thanks Laurence
I did that and it's working. Now I'm running some test cases and it crashes after abut 50 time steps, Ur Courant number tends to diverge, but I can fiddle with it, thanks again |
Pneumatic simulation - moving wall as a function of a pressure difference | jbmackay | OpenFOAM | 0 | September 22, 2010 15:51 |
Wall function formulation in CFX and Fluent | gravis | ANSYS | 0 | May 4, 2010 11:03 |
Compilation errors in ThirdPartymallochoard | feng_w | OpenFOAM Installation | 1 | January 25, 2009 06:59 |
Wall function problem in Fluent | mefpz | FLUENT | 1 | October 10, 2007 13:43 |
Env variable not set | gruber2 | OpenFOAM Installation | 5 | December 30, 2005 04:27 |
