RASmodel not detected
Like Tree1Likes
  • 1 Post By romant
Old   January 10, 2012, 08:10
Default RASmodel not detected
Ofc
Ofc is on a distinguished road
Hello Foamers,
I am using the twoPhaseEulerFoam solver. I try to set the RASmodel in the RASproperties. But whatever I write there (e.g. kEpsilon, LaunderSharmaKE or whatModelDoIUse, ...) the solver will always run.
Also I can switch off the turbulence in the file and the solver is still needing a k and epsilon file in the /0 folder. I tried to run the case on different pc's and the error repeats so guess it must be one of my case settings.
I want to change my model to k-omega-SST, but when I do the solver still needs k and epsilon and does not need omega in the /0 file. Any suggestions what might be wrong or how to solve the issue?
Thanks for your help,
Ofc is offline   Reply With Quote
Old   January 11, 2012, 05:11
romant's Avatar
Roman Thiele
romant is on a distinguished road
Hej,
I just checked the files for twoPhaseEulerFoam (something you might wanna do), but it seems that the only model you can use is kEpsilon. There is a special kEpsilon version which calculates the nuEff based on both phases. This is the reason you can't switch. In order to switch, you will have to implement this into the solver by hand.
Ofc likes this.
~roman
romant is offline   Reply With Quote
Old   January 12, 2012, 09:19
Ofc
Thank you,
that explains all. It's a good idea to investigate the solver. I put it on top of my ToDo-list.
Divergence detected in AMG solver: ads-0 Patrino FLUENT 6 May 12, 2022 03:11
Quarter Burner mesh with periosic condition SamCanuck FLUENT 2 August 31, 2011 11:34
Error detected by routine 201 CFX 1 April 19, 2010 16:17
user subroutine error CFDUSER CFX 2 December 9, 2006 06:31
user defined function cfduser CFX 0 April 29, 2006 10:58
