January 27, 2011, 14:22 |
MRFZone: error or warning? (MRFSimpleFoam)
Rep Power: 17 |
I'm going to simulate an open marine propeller and I set up a case for MRFSimpleFoam solver. There is only rotor, without stator. I create a set of cells called rotor by cellSet and a cellSet dictionary, with cellToBox to include the whole domain. Then I launch setSet -batch setBatch and create sets of faces for cyclicGgi patches. I finally transform the sets into zones with setsToZones -noFlipMap. When I run MRFSimpleFoam the computation starts but I also have the message:
MRFZone rotor : did not find a faceZone; using 904684 faces from the cellZone instead. |
MRFSimpleFoam Tutorial | bastil | OpenFOAM Running, Solving & CFD | 48 | August 1, 2012 10:00 |
GGI implementation in MRFSimpleFoam | amgode | OpenFOAM Running, Solving & CFD | 8 | August 5, 2011 06:03 |
The correction on pressure equation of SIMPLE algorithm in MRFSimpleFOAM solver | renyun0511 | OpenFOAM Running, Solving & CFD | 0 | November 10, 2010 01:47 |
How to add correcting pressure equation in SIMPLE of MRFSimpleFOAM? | renyun0511 | OpenFOAM Programming & Development | 0 | November 4, 2010 01:38 |
Compared MRFSimpleFoam and Fluent in a centrifugal pump! | renyun0511 | OpenFOAM Running, Solving & CFD | 2 | December 12, 2009 21:58 |
