February 8, 2011, 09:24 |
PtrList problems
Paweł Kuczyński
Rep Power: 15 |
Dear forumers,
Firstly I will shortly describe my problem. I would like to set up an Array of Arrays (2d array), which is of size: N_boundFaces x N_boundFaces. Such an array will correspond to the coefficients of heat exchange between a given boundary-cell-face and the rest of boundary-cell-faces. Having read some hints in this forum, I came up with an idea of constructing a PtrList. But at the beginning I have problems with setting up a single 1d-PtrList: The code is following...: (...) const int N_boundFaces = mesh.boundaryMesh().size() * mesh.boundaryMesh()[0].size(); //N_boundFaces = N_patches * N_faces_in_patch PtrList< int > D(N_boundFaces); Info << "size of PtrList D = " << D.size() << endl ; for( int i = 0; i != N_boundFaces ; i++ ) { D.set(i, 2); // set all the values in the PtrList to 2 } (...) and the compiling errors are: (...) In file included from /opt/openfoam171/src/OpenFOAM/lnInclude/tmp.H:142, from /opt/openfoam171/src/OpenFOAM/lnInclude/PtrListI.H:29, from /opt/openfoam171/src/OpenFOAM/lnInclude/PtrList.H:311, from /opt/openfoam171/src/OpenFOAM/lnInclude/List.C:30, from /opt/openfoam171/src/OpenFOAM/lnInclude/List.H:262, from /opt/openfoam171/src/OpenFOAM/lnInclude/labelList.H:36, from /opt/openfoam171/src/OpenFOAM/lnInclude/Pstream.H:43, from /opt/openfoam171/src/OpenFOAM/lnInclude/OPstream.H:35, from /opt/openfoam171/src/OpenFOAM/lnInclude/parRun.H:35, from /opt/openfoam171/src/finiteVolume/lnInclude/fvCFD.H:4, from laplacianFoamModifiedRandomNumberV03.C:32: /opt/openfoam171/src/OpenFOAM/lnInclude/tmpI.H: In destructor ‘Foam::tmp<T>::~tmp() [with T = int]’: rayTracing.H:43: instantiated from here /opt/openfoam171/src/OpenFOAM/lnInclude/tmpI.H:76: error: request for member ‘okToDelete’ in ‘*((Foam::tmp<int>*)this)->Foam::tmp<int>:tr_’, which is of non-class type ‘int’ /opt/openfoam171/src/OpenFOAM/lnInclude/tmpI.H:83: error: request for member ‘operator--’ in ‘*((Foam::tmp<int>*)this)->Foam::tmp<int>:tr_’, which is of non-class type ‘int’ /opt/openfoam171/src/OpenFOAM/lnInclude/tmpI.H: In member function ‘T* Foam::tmp<T>:tr() const [with T = int]’: /opt/openfoam171/src/OpenFOAM/lnInclude/PtrListI.H:90: instantiated from ‘Foam::autoPtr<T> Foam::PtrList<T>::set(Foam::label, const Foam::tmp<T>&) [with T = int]’ rayTracing.H:43: instantiated from here /opt/openfoam171/src/OpenFOAM/lnInclude/tmpI.H:127: error: request for member ‘resetRefCount’ in ‘* ptr’, which is of non-class type ‘int’ make: *** [Make/linuxGccDPOpt/laplacianFoamModifiedRandomNumberV03.o] Błąd 1 So my questions are the following: 1. what is the best way to loop over the elements in PtrList? a) use simple for loop with int counter: for( int i = 0; != N_boundFaces; i++ ) b) use iterator: for ( PtrList<int>::iterator i = D.begin(); i != D.end(); ++i) c) use: forAll( D, i ) 2. how successfuly replace a given entity in the PtrList? use D.set(i, 200)?? 3. how print out the value of a given entity, e.g. D[i]? Info << D[i] ;?? I know that some answers to my questions were previously mentioned, but I couldn't manage to solve my problem. Every help would be greatly appreciated. Thanks!
Best regards P. Kuczynski. |
February 10, 2011, 04:14 |
Paweł Kuczyński
Rep Power: 15 |
I'm still tackling the problem, but hopefully I see an end. I will try to post some conclusions from my little experience :-).
Still I really appreciate any help.
February 11, 2011, 05:56 |
Hrvoje Jasak
Rep Power: 33 |
PtrList is a container for pointers to objects and there is a bunch of templates in it. Why don't you just use a labelList?
If you want an example of PtrList, try a PtrList<fvPatch> or similar. Hrv
Hrvoje Jasak Providing commercial FOAM/OpenFOAM and CFD Consulting: http://wikki.co.uk |
February 16, 2011, 07:41 |
Paweł Kuczyński
Rep Power: 15 |
Hello Hrvoje,
Thanks for your suggestions! I have to lean more about them. I'm fresh user of OpenFoam, so for now I managed to solve the problem just by creating a new scalar array. I decided not to use ptrList because the size of the array is constant during the program execution. Once again thanks.
May 18, 2011, 10:44 |
solution to the problems
Paweł Kuczyński
Rep Power: 15 |
Dear forumers,
Finally I succeded in finding out how to do basic operations with ptrList< type >. Below I posted some lines of my code. Hope it will be useful, because previously I searched the forum and didn't find basic info on this subject. Code:
/* Defining pointer list of scalars */ PtrList< scalar > U_ ; scalar A = 3.1415; scalar *Aptr ; Aptr = &A ; U_.setSize( 10 ) ; for (label i = 0; i < 10; i++) { U_.set(i, Aptr) ; // the ptrList can be filled in passing the pointer Aptr to scalar A Info << " if is set U_[i] = " << U_.set(i); //checking if the list element U_[i] is already set --> if not the value of U_.set(i) == 0 ; Info << " U_[i] = " << U_[i] << endl ; // prints out the values of prtList }
May 19, 2011, 03:17 |
#6 | |
Mark Olesen
Rep Power: 40 |
Are you really certain that your code works correctly with PtrList? Have you checked with valgrind that everything actually works properly when the U_ variable is destroyed? I have my doubts. Take a look at the destructor for PtrList and you'll see that it is doing a 'delete'. Your code will not mix well with this at all. |
May 26, 2011, 05:50 |
Paweł Kuczyński
Rep Power: 15 |
Dear olesen, many thanks for pointing out the problem. As I said before I am a beginner in openFoam, so I really appreciate all replies. I tried checking the code with valgrind and it shouts for some errors indeed. You have a valgrind response below:
==4315== Invalid free() / delete / delete[] ==4315== at 0x4C26DCF: operator delete(void*) (vg_replace_malloc.c:387) ==4315== by 0x5445C23: Foam::PtrList<double>::~PtrList() (PtrList.C:133) ==4315== by 0x5442D79: Foam::pkModel::pk::checkDij_reciprocity() ==4315== by 0x44D031: main (hEqn.H:19) ==4315== Address 0x7feffc260 is on thread 1's stack ==4315== ... ... ==4315== ==4315== HEAP SUMMARY: ==4315== in use at exit: 300 bytes in 11 blocks ==4315== total heap usage: 387,720 allocs, 387,719 frees, 41,168,150 bytes allocated ==4315== ==4315== LEAK SUMMARY: ==4315== definitely lost: 60 bytes in 1 blocks ==4315== indirectly lost: 240 bytes in 10 blocks ==4315== possibly lost: 0 bytes in 0 blocks ==4315== still reachable: 0 bytes in 0 blocks ==4315== suppressed: 0 bytes in 0 blocks ==4315== Rerun with --leak-check=full to see details of leaked memory ==4315== ==4315== For counts of detected and suppressed errors, rerun with: -v ==4315== ERROR SUMMARY: 10 errors from 1 contexts (suppressed: 4 from 4) kuczmas.
May 26, 2011, 06:25 |
#8 | |
Mark Olesen
Rep Power: 40 |
// Defining list of scalars List<scalar> U_ ; scalar A = 3.1415; U_.setSize(10) ; forAll(U_, i) { U_[i] = A; Info << " U_[i] = " << U_[i] << endl; } Code:
// Defining list of scalars PtrList<scalar> U_ ; scalar A = 3.1415; U_.setSize(10) ; forAll(U_, i) { U_.set(i, new scalar(A)); Info << " U_[i] = " << U_[i] << endl; } |
May 26, 2011, 08:07 |
#9 |
Paweł Kuczyński
Rep Power: 15 |
Dear Mark,
That was the piece of the code I actually was interested in and it works perfectly without any errors. Thanks a lot !
Display Modes | |
Needed Benchmark Problems for FSI | Mechstud | Main CFD Forum | 4 | July 26, 2011 13:13 |
Two-phase air water flow problems by activating Wall Lubrication Force | challenger85 | CFX | 5 | November 5, 2009 06:44 |
Help required to solve Hydraulic related problems | aero | CFX | 0 | October 30, 2006 12:00 |
Some problems with Star CD | Micha | Siemens | 0 | August 6, 2003 14:55 |
Airpak: Problems with heat flow contour conditions | Ivan de Miguel Urain | FLUENT | 1 | November 16, 2001 10:36 |
