propeller tutorial
Old   February 8, 2012, 04:02
Default propeller tutorial
stephane sanchi
openfoam_user is on a distinguished road
Dear OF users,
I encounter a problem when running the propeller tutorial with the pimpleDyMFoam solver.
When I do the command:
topoSet -dict system/removeRedundantZones.topoSetDict
I get the following error message:
Create time
Create polyMesh for time = 0
Reading topoSetDict
Time = 0
mesh not changed.
--> FOAM FATAL ERROR:
object is not allocated
From function T& Foam::autoPtr<T>:perator()()
in file /shared/OpenFOAM/OpenFOAM-2.1.x/src/OpenFOAM/lnInclude/autoPtrI.H at line 118.
FOAM aborting
#0 Foam::error:rintStack(Foam::Ostream&) in "/shared/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1 Foam::error::abort() in "/shared/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
in "/shared/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/bin/topoSet"
#3 __libc_start_main in "/lib64/libc.so.6"
at /home/abuild/rpmbuild/BUILD/glibc-2.14.1/csu/../sysdeps/x86_64/elf/start.S:116
Abort
Has someone experienced the same kind of error ?
Some days ago I was able to run the tutorial without any errors !
Best regards,
Stephane.
openfoam_user is offline   Reply With Quote
Propeller calculation toil CFX 15 May 22, 2017 04:06
Modelling a propeller tomg STAR-CCM+ 4 April 28, 2011 17:22
Looking for tutorial for rotating propeller for Marine Applications naimishharpal STAR-CCM+ 0 February 7, 2011 22:12
a propeller 2 way fsi kantored CFX 9 April 11, 2007 14:51
Propeller thrust at diff. advance ratio (CFX 5.7) Zoltan CFX 9 April 27, 2005 08:23
