Parallel run on remote server
Old   February 7, 2012, 12:48
Default Parallel run on remote server
Jordan
OpenFOAM_user87 is on a distinguished road
I am trying to remotely run a parallel OpenFOAM run on a remote server that does not have OpenFOAM installed. My machine has Ubuntu and OpenFOAM 2.1.0 and the server is running CentOS 5.3. I can't find much documentation on this type of run so any help would be appreciated. Thanks.
OpenFOAM_user87 is offline   Reply With Quote
Old   February 8, 2012, 03:01
akidess's Avatar
Anton Kidess
How is the server supposed to run OpenFOAM if it's not installed there?
*On twitter @akidTwit
*Spend as much time formulating your questions as you expect people to spend on their answer.
Old   February 8, 2012, 03:43
Luca Giannelli
voingiappone is on a distinguished road
Of course you have to install OF on the server... otherwise, like akidess said, there is no way.
You indeed can run the remote OF from your pc using mpirun even if it is maybe better to directly ssh to the server and run it from there. If you try to run a parallel (and not only a remote run) you have to keep in mind some points that can save you a lot of hassles later:
- same architecture on both the machines is what you want
- same user on both the pc with the same home dir so you can:
- install all the components in the very same directories
- set you pc (not the server) to static ip... just in case you forget it...
- read the break of a dam tutorial which has all the info for running in parallel well explained
that's all I can recall from my previous experiences for now... without going into more complicated things. Try doing this and it will probably work.
Bye
voingiappone is offline   Reply With Quote
Parallel run of OpenFOAM in linux and windows side by side m2montazari OpenFOAM Running, Solving & CFD 5 June 24, 2011 03:26
Fluent can't run in parallel when hyper threading turning on. field FLUENT 0 May 5, 2011 07:41
parallel run for fsi simulation??? smn CFX 2 July 19, 2009 04:04
Problem on Parallel Run Setup Hamidur Rahman CFX 0 September 23, 2007 17:11
Minimum number of nodes to run CFX in parallel Rui CFX 3 April 11, 2005 20:46
