pasive particles
Old   June 12, 2020, 05:39
Default pasive particles
mba olufemi
mba_olufemi is on a distinguished road
Dear all,
I think I finally understand all the parameters needed for a successful definition of Lagrangian injector and the corresponding kinematicCloudProperties and run my closed geometries simulation. If there is interest I would post my findings.
Now I need an advice on the solver. What solver would you advice for simulating a cloud of passively dragged scarce particles in a flow impinging on an obstacle? My particles don’t evaporate or burn; the tunnel they fly in is isothermal and the flow is much below sonic speeds.
How to define the interaction properties with the obstacle in a way that that some particles would bounce, some stick and some slip?
Is there an example I could study?
Thanks a lot
Mba
mba_olufemi is offline   Reply With Quote
Old   July 28, 2020, 06:05
oswald is on a distinguished road
I would suggest to build your own solver. Your case description seems as pimpleFoam would be a good base. Include the kinematicCloud-functionality there.
The handling of patch collisions is done by patch interaction models. You can find them in "src/lagrangian/intermediate/submodels/Kinematic/PatchInteractionModel/". Having a look at "StandardWallInteraction.C" gives you an example how to define what is done with particles when they hit a patch. Here it is predefined by a switch in a dictionary. Instead, you could for example define a critical normal velocity, below which particles stick, and above which particles bounce.
oswald is offline   Reply With Quote
how to determine the number of particles injected. welch FLUENT 2 January 18, 2024 04:08
dsmcFoam - micro-hole limiting the number of dsmc particles Araist OpenFOAM Running, Solving & CFD 0 June 25, 2015 06:50
Add lagrangian particles to OpenFoam solver luchen2408 OpenFOAM 0 June 2, 2015 03:10
trying to simulate two-phase jet flow with particles in surface injection ajkratos FLUENT 5 March 3, 2015 21:33
particles model ati_ros61 FLOW-3D 3 December 6, 2009 16:03
