twoPhaseEulerFoam variables
Old   March 31, 2011, 09:51
Default twoPhaseEulerFoam variables
Costas K
thekay is on a distinguished road
Send a message via ICQ to thekay Send a message via MSN to thekay
Hi all
I was going through the code of twoPhaseEulerFoam and I have some questions about the variables in a part of alphaEqn.H and I'd be thankful if anyone could help me identify their use.
What is phic used for? It is initialised as
surfaceScalarField phic = phi;
What about alphaf? It is defined as
surfaceScalarField alphaf = fvc::interpolate(alpha);
And finally I cannot understand what phipp represents and how it is used.
surfaceScalarField phipp = ppMagf*fvc::snGrad(alpha)*mesh.magSf();
Cheers all
thekay is offline   Reply With Quote
Old   April 1, 2011, 02:45
Alberto Passalacqua
phipp is a term used only if the ppMagf model is used. In such case, the momentum equation for phase a has an additional pressure gradient grad(pa). If you proceed as in the derivation of phase a "pressure equation", but keep that equation written in terms of alpha, understand the origin of phipp.
Hint: grad(pa) = G(alpha) * grad(alpha), where G(alpha) = ppMagf = d(pa)/d(alpha).
Best,
Alberto Passalacqua
Old   November 25, 2011, 23:48
Kshitij kunte
k.kshitij is on a distinguished road
Hi Alberto,
I have one question about the ppmagf's usage, according to my understanding the ppmagf model is implemented when the kinetic theory is off, ie when the value of g0 > 0.
Then why does its definition involve the kinetic theory particle pressure "pa". Or I'm wrong in getting this.
I'm a newbee to C++ and have not understood the code yet would you please clarify.
Thanks in advance.
k.kshitij is offline   Reply With Quote
Old   November 26, 2011, 21:00
Alberto Passalacqua
The currently implemented ppMagf does not involve the kinetic theory model. I used "pa" in comment #2 to suggest how to extend the current treatment of the particle pressure in the alpha equation only implemented when the ppMagf model is used also to the case when the kinetic theory is used.
Best,
Alberto Passalacqua
ADDITIONAL VARIABLES LIMITERS N.P CFX 5 December 1, 2011 07:47
$FOAM_USER_APPBIN & LIBBIN variables not set rassilon OpenFOAM Installation 2 February 16, 2010 20:54
Thread Variables in Case File Bernhardt FLUENT 1 June 15, 2007 01:30
PHI file structure Eugene Phoenics 9 November 2, 2001 22:00
Saving variables on a user patch with physical coordinates Zoltan Turzo CFX 2 April 20, 2000 15:05
