Extrusion with OpenFoam problem No. Iterations 0
Like Tree2Likes
  • 2 Post By wyldckat
Old   April 12, 2011, 06:50
Lightbulb Extrusion with OpenFoam problem No. Iterations 0
Lord Kelvin's Avatar
Lord Kelvin is on a distinguished road
Send a message via MSN to Lord Kelvin
Hi, I'm trying to simulate a laminar flow in a cylinder (hole of the extrusion die) with inlet and outlet (bases) and wall (lateral). I modeled it with Salome 5 (CAE linux) and exported the mesh in UNV.
I post the files:
RaspProperties
| \\ / O peration | Version: 1.7.0 |
| \\ / A nd | Web: www.OpenFOAM.com |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
location "constant";
object RASProperties;
RASModel laminar;
turbulence off;
printCoeffs on;
transportProperties
FoamFile
version 2.0;
format ascii;
class dictionary;
object transportProperties;
transportModel powerLaw;
nu nu [ 0 2 -1 0 0 0 0 ] 1e-05;
powerLawCoeffs
k k [0 2 -1 0 0 0 0] 2800;
n n [0 0 0 0 0 0 0] 0.4;
nuMin nuMin [0 2 -1 0 0 0 0] .1;
nuMax nuMax [0 2 -1 0 0 0 0] 1000000;
CrossPowerLawCoeffs
nu0 nu0 [ 0 2 -1 0 0 0 0 ] 1e-06;
nuInf nuInf [ 0 2 -1 0 0 0 0 ] 1e-06;
m m [ 0 0 1 0 0 0 0 ] 1;
n n [ 0 0 0 0 0 0 0 ] 1;
BirdCarreauCoeffs
k k [ 0 0 1 0 0 0 0 ] 0;
p
FoamFile
version 2.0;
format ascii;
class volScalarField;
object p;
dimensions [0 2 -2 0 0 0 0];
internalField uniform 0;
boundaryField
inlet
type zeroGradient;
outlet
type fixedValue;
value uniform 0;
wall
type zeroGradient;
U
FoamFile
version 2.0;
format ascii;
class volVectorField;
object U;
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
inlet
type fixedValue;
value uniform (.016 0 0);
outlet
type zeroGradient;
wall
type fixedValue;
value uniform (0 0 0);
fvSchemes
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object fvSchemes;
ddtSchemes
default Euler;
gradSchemes
default Gauss linear;
grad(p) Gauss linear;
grad(U) Gauss linear;
divSchemes
default none;
div(phi,U) Gauss upwind;
div(phi,k) Gauss upwind;
div(phi,epsilon) Gauss upwind;
div(phi,R) Gauss upwind;
div(R) Gauss linear;
div(phi,nuTilda) Gauss upwind;
div((nuEff*dev(grad(U).T()))) Gauss linear;
laplacianSchemes
default none;
laplacian(nuEff,U) Gauss linear corrected;
laplacian((1|A(U)),p) Gauss linear corrected;
laplacian(DkEff,k) Gauss linear corrected;
laplacian(DepsilonEff,epsilon) Gauss linear corrected;
laplacian(DREff,R) Gauss linear corrected;
laplacian(DnuTildaEff,nuTilda) Gauss linear corrected;
interpolationSchemes
default linear;
interpolate(U) linear;
snGradSchemes
default corrected;
fluxRequired
default no;
p ;
then I run simpleFoam in the directory of the simulation that I created and this is the results:
Time = 979
DILUPBiCG: Solving for Ux, Initial residual = 1.23786e-16, Final residual = 1.23786e-16, No Iterations 0
DILUPBiCG: Solving for Uy, Initial residual = 1.12365e-16, Final residual = 1.12365e-16, No Iterations 0
DILUPBiCG: Solving for Uz, Initial residual = 1.22862e-16, Final residual = 1.22862e-16, No Iterations 0
DICPCG: Solving for p, Initial residual = 7.10497e-07, Final residual = 7.10497e-07, No Iterations 0
time step continuity errors : sum local = 3.29168e-12, global = -8.50298e-13, cumulative = -1.30448e-08
ExecutionTime = 4.93 s ClockTime = 9 s
Time = 980
DILUPBiCG: Solving for Ux, Initial residual = 1.26725e-16, Final residual = 1.26725e-16, No Iterations 0
DILUPBiCG: Solving for Uy, Initial residual = 1.12963e-16, Final residual = 1.12963e-16, No Iterations 0
DILUPBiCG: Solving for Uz, Initial residual = 1.21408e-16, Final residual = 1.21408e-16, No Iterations 0
time step continuity errors : sum local = 3.29168e-12, global = -8.50298e-13, cumulative = -1.30457e-08
ExecutionTime = 4.94 s ClockTime = 9 s
Time = 981
DILUPBiCG: Solving for Ux, Initial residual = 1.23068e-16, Final residual = 1.23068e-16, No Iterations 0
DILUPBiCG: Solving for Uy, Initial residual = 1.11831e-16, Final residual = 1.11831e-16, No Iterations 0
DILUPBiCG: Solving for Uz, Initial residual = 1.23645e-16, Final residual = 1.23645e-16, No Iterations 0
time step continuity errors : sum local = 3.29168e-12, global = -8.50298e-13, cumulative = -1.30465e-08
Time = 982
DILUPBiCG: Solving for Ux, Initial residual = 1.26931e-16, Final residual = 1.26931e-16, No Iterations 0
DILUPBiCG: Solving for Uy, Initial residual = 1.0935e-16, Final residual = 1.0935e-16, No Iterations 0
DILUPBiCG: Solving for Uz, Initial residual = 1.22962e-16, Final residual = 1.22962e-16, No Iterations 0
time step continuity errors : sum local = 3.29168e-12, global = -8.50298e-13, cumulative = -1.30474e-08
ExecutionTime = 4.95 s ClockTime = 9 s
Time = 983
DILUPBiCG: Solving for Ux, Initial residual = 1.23579e-16, Final residual = 1.23579e-16, No Iterations 0
DILUPBiCG: Solving for Uy, Initial residual = 1.15394e-16, Final residual = 1.15394e-16, No Iterations 0
DILUPBiCG: Solving for Uz, Initial residual = 1.2132e-16, Final residual = 1.2132e-16, No Iterations 0
time step continuity errors : sum local = 3.29168e-12, global = -8.50298e-13, cumulative = -1.30483e-08
ExecutionTime = 4.96 s ClockTime = 9 s
Time = 984
DILUPBiCG: Solving for Ux, Initial residual = 1.26194e-16, Final residual = 1.26194e-16, No Iterations 0
DILUPBiCG: Solving for Uy, Initial residual = 1.08941e-16, Final residual = 1.08941e-16, No Iterations 0
DILUPBiCG: Solving for Uz, Initial residual = 1.23718e-16, Final residual = 1.23718e-16, No Iterations 0
time step continuity errors : sum local = 3.29168e-12, global = -8.50298e-13, cumulative = -1.30491e-08
Time = 985
DILUPBiCG: Solving for Ux, Initial residual = 1.23803e-16, Final residual = 1.23803e-16, No Iterations 0
DILUPBiCG: Solving for Uy, Initial residual = 1.12121e-16, Final residual = 1.12121e-16, No Iterations 0
DILUPBiCG: Solving for Uz, Initial residual = 1.22867e-16, Final residual = 1.22867e-16, No Iterations 0
time step continuity errors : sum local = 3.29168e-12, global = -8.50298e-13, cumulative = -1.305e-08
Time = 986
DILUPBiCG: Solving for Ux, Initial residual = 1.26728e-16, Final residual = 1.26728e-16, No Iterations 0
DILUPBiCG: Solving for Uy, Initial residual = 1.12798e-16, Final residual = 1.12798e-16, No Iterations 0
DILUPBiCG: Solving for Uz, Initial residual = 1.21437e-16, Final residual = 1.21437e-16, No Iterations 0
time step continuity errors : sum local = 3.29168e-12, global = -8.50298e-13, cumulative = -1.30508e-08
Time = 987
DILUPBiCG: Solving for Ux, Initial residual = 1.23051e-16, Final residual = 1.23051e-16, No Iterations 0
DILUPBiCG: Solving for Uy, Initial residual = 1.11958e-16, Final residual = 1.11958e-16, No Iterations 0
DILUPBiCG: Solving for Uz, Initial residual = 1.23644e-16, Final residual = 1.23644e-16, No Iterations 0
time step continuity errors : sum local = 3.29168e-12, global = -8.50298e-13, cumulative = -1.30517e-08
ExecutionTime = 4.97 s ClockTime = 9 s
Time = 988
DILUPBiCG: Solving for Ux, Initial residual = 1.26928e-16, Final residual = 1.26928e-16, No Iterations 0
DILUPBiCG: Solving for Uy, Initial residual = 1.09385e-16, Final residual = 1.09385e-16, No Iterations 0
DILUPBiCG: Solving for Uz, Initial residual = 1.22949e-16, Final residual = 1.22949e-16, No Iterations 0
time step continuity errors : sum local = 3.29168e-12, global = -8.50298e-13, cumulative = -1.30525e-08
ExecutionTime = 4.98 s ClockTime = 9 s
Time = 989
DILUPBiCG: Solving for Ux, Initial residual = 1.23595e-16, Final residual = 1.23595e-16, No Iterations 0
DILUPBiCG: Solving for Uy, Initial residual = 1.15446e-16, Final residual = 1.15446e-16, No Iterations 0
DILUPBiCG: Solving for Uz, Initial residual = 1.21323e-16, Final residual = 1.21323e-16, No Iterations 0
time step continuity errors : sum local = 3.29168e-12, global = -8.50298e-13, cumulative = -1.30534e-08
Time = 990
DILUPBiCG: Solving for Ux, Initial residual = 1.26196e-16, Final residual = 1.26196e-16, No Iterations 0
DILUPBiCG: Solving for Uy, Initial residual = 1.08924e-16, Final residual = 1.08924e-16, No Iterations 0
DILUPBiCG: Solving for Uz, Initial residual = 1.23746e-16, Final residual = 1.23746e-16, No Iterations 0
time step continuity errors : sum local = 3.29168e-12, global = -8.50298e-13, cumulative = -1.30542e-08
Time = 991
DILUPBiCG: Solving for Ux, Initial residual = 1.23788e-16, Final residual = 1.23788e-16, No Iterations 0
DILUPBiCG: Solving for Uy, Initial residual = 1.12266e-16, Final residual = 1.12266e-16, No Iterations 0
DILUPBiCG: Solving for Uz, Initial residual = 1.22859e-16, Final residual = 1.22859e-16, No Iterations 0
time step continuity errors : sum local = 3.29168e-12, global = -8.50298e-13, cumulative = -1.30551e-08
Time = 992
DILUPBiCG: Solving for Uy, Initial residual = 1.1293e-16, Final residual = 1.1293e-16, No Iterations 0
DILUPBiCG: Solving for Uz, Initial residual = 1.21393e-16, Final residual = 1.21393e-16, No Iterations 0
time step continuity errors : sum local = 3.29168e-12, global = -8.50298e-13, cumulative = -1.30559e-08
ExecutionTime = 4.99 s ClockTime = 9 s
Time = 993
DILUPBiCG: Solving for Ux, Initial residual = 1.23065e-16, Final residual = 1.23065e-16, No Iterations 0
DILUPBiCG: Solving for Uy, Initial residual = 1.11725e-16, Final residual = 1.11725e-16, No Iterations 0
DILUPBiCG: Solving for Uz, Initial residual = 1.23649e-16, Final residual = 1.23649e-16, No Iterations 0
time step continuity errors : sum local = 3.29168e-12, global = -8.50298e-13, cumulative = -1.30568e-08
ExecutionTime = 5 s ClockTime = 9 s
Time = 994
DILUPBiCG: Solving for Ux, Initial residual = 1.26933e-16, Final residual = 1.26933e-16, No Iterations 0
DILUPBiCG: Solving for Uy, Initial residual = 1.09154e-16, Final residual = 1.09154e-16, No Iterations 0
DILUPBiCG: Solving for Uz, Initial residual = 1.22979e-16, Final residual = 1.22979e-16, No Iterations 0
time step continuity errors : sum local = 3.29168e-12, global = -8.50298e-13, cumulative = -1.30576e-08
Time = 995
DILUPBiCG: Solving for Ux, Initial residual = 1.23577e-16, Final residual = 1.23577e-16, No Iterations 0
DILUPBiCG: Solving for Uy, Initial residual = 1.15583e-16, Final residual = 1.15583e-16, No Iterations 0
DILUPBiCG: Solving for Uz, Initial residual = 1.21322e-16, Final residual = 1.21322e-16, No Iterations 0
time step continuity errors : sum local = 3.29168e-12, global = -8.50298e-13, cumulative = -1.30585e-08
ExecutionTime = 5.01 s ClockTime = 9 s
Time = 996
DILUPBiCG: Solving for Ux, Initial residual = 1.26195e-16, Final residual = 1.26195e-16, No Iterations 0
DILUPBiCG: Solving for Uy, Initial residual = 1.09024e-16, Final residual = 1.09024e-16, No Iterations 0
DILUPBiCG: Solving for Uz, Initial residual = 1.2373e-16, Final residual = 1.2373e-16, No Iterations 0
time step continuity errors : sum local = 3.29168e-12, global = -8.50298e-13, cumulative = -1.30593e-08
ExecutionTime = 5.02 s ClockTime = 9 s
Time = 997
DILUPBiCG: Solving for Ux, Initial residual = 1.23799e-16, Final residual = 1.23799e-16, No Iterations 0
DILUPBiCG: Solving for Uy, Initial residual = 1.12231e-16, Final residual = 1.12231e-16, No Iterations 0
DILUPBiCG: Solving for Uz, Initial residual = 1.22866e-16, Final residual = 1.22866e-16, No Iterations 0
time step continuity errors : sum local = 3.29168e-12, global = -8.50298e-13, cumulative = -1.30602e-08
Time = 998
DILUPBiCG: Solving for Ux, Initial residual = 1.2673e-16, Final residual = 1.2673e-16, No Iterations 0
DILUPBiCG: Solving for Uy, Initial residual = 1.12967e-16, Final residual = 1.12967e-16, No Iterations 0
DILUPBiCG: Solving for Uz, Initial residual = 1.21424e-16, Final residual = 1.21424e-16, No Iterations 0
time step continuity errors : sum local = 3.29168e-12, global = -8.50298e-13, cumulative = -1.3061e-08
ExecutionTime = 5.03 s ClockTime = 9 s
Time = 999
DILUPBiCG: Solving for Ux, Initial residual = 1.23049e-16, Final residual = 1.23049e-16, No Iterations 0
DILUPBiCG: Solving for Uy, Initial residual = 1.11804e-16, Final residual = 1.11804e-16, No Iterations 0
DILUPBiCG: Solving for Uz, Initial residual = 1.2364e-16, Final residual = 1.2364e-16, No Iterations 0
time step continuity errors : sum local = 3.29168e-12, global = -8.50298e-13, cumulative = -1.30619e-08
Time = 1000
DILUPBiCG: Solving for Ux, Initial residual = 1.26929e-16, Final residual = 1.26929e-16, No Iterations 0
DILUPBiCG: Solving for Uy, Initial residual = 1.09316e-16, Final residual = 1.09316e-16, No Iterations 0
DILUPBiCG: Solving for Uz, Initial residual = 1.22938e-16, Final residual = 1.22938e-16, No Iterations 0
time step continuity errors : sum local = 3.29168e-12, global = -8.50298e-13, cumulative = -1.30627e-08
ExecutionTime = 5.05 s ClockTime = 10 s
End
I can't find the problem, the issue. Someone can help me?
Thank U!
Lord Kelvin is offline   Reply With Quote
Old   April 12, 2011, 07:14
Martin
MartinB will become famous soon enough
your simulation seems to be fully converged... how does it look like in Paraview?
Martin
MartinB is offline   Reply With Quote
Old   April 12, 2011, 07:19
Originally Posted by MartinB View Post
Martin
Hi Martin, yes it "seems" but the results says "No Iterations 0" and the initial value and the final value for velocity and pressure are THE SAME.
I don't understand this issue. absolutely
Old   April 12, 2011, 07:27
Martin
If you decrease the tolerances for the linear equation solver in system/fvSolution even further to let's say "tolerance 1e-12;", then the initial residual is higher then desired and more iterations will be done...
But it shouldn't be necessary... your simulation results should be fine enough after a few hundred iterations.
You can add "convergence 1e-5;" to the SIMPLE dictionary in the fvSolution. simpleFoam will stop as soon as convergence criteria is reached:
SIMPLE
    nNonOrthogonalCorrectors 0;
    convergence 1.0e-5;
Martin
Old   April 12, 2011, 07:52
SIMPLE
    convergence 1.0e-5;
Martin
Martin, you mean that my cylinder is too simple and banal and so the solver doesn't need to make iterations beacause the value (start-end) are quite the same??
so the problem is in the solid model?
Old   April 12, 2011, 07:58
Martin
If simpleFoam makes 0 iterations for solving the linear equations system in the very first time steps, too, than there is a problem in your case. On the other hand if simpleFoam do make more than 0 iterations in the first time steps, everything is fine: simpleFoam found the correct solution and further iterations are not necessary.
You can send me your case, if you like, so I can have a look at it... my eMail comes via boardmail to prevent spamming...
Martin
Old   April 12, 2011, 11:24
Thumbs up
Martin
I want to underline to the community the great availibility of Martin.
I want to give him REP+
Old   March 27, 2016, 11:26
Default what was the outcome
LeeRuns is on a distinguished road
Thank you for posting all of your code.
Could you please post the changes that you made to make the model run correctly. I would really appreciate it
LeeRuns is offline   Reply With Quote
Old   March 28, 2016, 11:08
Retired Super Moderator
Bruno Santos
Quick answer:
The forum member "Lord Kelvin" hasn't logged in since April 13, 2011. Therefore it's unlikely an answer will be given by that forum member
Nonetheless, all of the critical details and solutions are fully explained by MartinB. If you don't understand the explanations, then please provide information about your own case, namely the problem you're facing.
TENE and sourav90 like this.
icoLagrangianFoam OF1.6 myNewParticleSolver heavy_user OpenFOAM 23 June 2, 2020 02:18
SimpleFoam k and epsilon bounded nedved OpenFOAM Running, Solving & CFD 16 March 4, 2017 08:30
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
Low Mach number Compressible jet flow using LES ankgupta8um OpenFOAM Running, Solving & CFD 7 January 15, 2011 13:38
lift and drag on ship superstructures vaina74 OpenFOAM Running, Solving & CFD 3 June 8, 2010 12:30
