Relation between k and UPrime2Mean etc in LES
Like Tree26Likes
Old   January 25, 2012, 12:26
pooyan
sam1364 is on a distinguished road
my Solver is pisoFoam. So, Should I add these new lines to the createFields.H inside the pisoFoam Directory?! Do I need to compile these codes when I add those terms?
in createFields.H inside pisoFoam Directory, I see that it reads U and P fields rather than writing them
Info<< "Reading field U\n" << endl;
volVectorField U
IOobject
"U",
runTime.timeName(),
mesh,
IOobject::MUST_READ,
IOobject::AUTO_WRITE
mesh
are you sure this is the place to create R field?
sam1364 is offline   Reply With Quote
Old   January 25, 2012, 12:32
Gregor Olenik
gregor is on a distinguished road
Yes you would have to recompile your code.
It reads the fields and creates an entry in the object registry, which is needed for the sampling. So its nothing wrong with putting it in there, but you can place it anywhere else where it fits
Gregor
gregor is offline   Reply With Quote
Old   January 25, 2012, 12:36
Dejan Morar
morard is on a distinguished road
...and don't forget to change the name of the solver
morard is offline   Reply With Quote
Old   January 25, 2012, 13:05
pooyan
Ok, thanks guys.
to compile a code, As far as I remember, I should use wmake libso. do I need to make a new library for my new solver let's say pisoFoam2?!
I do not want to change pisoFoam.C. I want to make a copy of that somewhere and then change it.
by the way, by the following command, do you mean that I should use this inside pisoFoam solver?! and what is turbulence?! do you mean RASModel ->R()?!
R_ = turbulence->R()
Old   January 26, 2012, 04:03
Dejan Morar
first, just copy original pisoFoam and change name to, as you said, pisoFoam2 (but, my suggestion is to choose something other like pisoRFoam, because after some tome you will have pisoFoam2, pisoFoam3,... and you will definitely forget what did you change in each of those..). So, you have to change pisoFoam.C to pisoFoam2.C. Than, open Make folder and inside files, you also have to change:
pisoFoam2.C
EXE = $(FOAM_APPBIN)/pisoFoam2
Then navigate your terminal to pisoFoam2 folder and execute:
wclean
wmake
now you have your own solver pisoFoam2. Now do the changes mentioned by Gregor and me.
If you take a look into createFields.H, you will see how pointer is created. At the end of the file it is written:
autoPtr<incompressible::turbulenceModel> turbulence
incompressible::turbulenceModel::New(U, phi, laminarTransport)
so, you'll have to put inside pisoFoam2.C
R_ = turbulence->R();
Put this inside while loop. Between the lines: turbulence->correct(); and runTime.write(); might be a good position. So, at the end you'll have:
runTime.write();
This should wor.
Check this page:
http://openfoamwiki.net/index.php/Ho...ure_to_icoFoam
There you can find a lot of useful things.
ashvinc9 likes this.
Old   January 26, 2012, 10:53
pooyan
Thanks Morad. So nice!
I will try it out!
Old   January 27, 2012, 10:59
pooyan
Hi
I compiled the new pisoFoam solver and I added the following line to the code:
createField.H
Info<< "Reading field R\n" << endl;
volSymmTensorField R
IOobject
"R",
runTime.timeName(),
mesh,
mesh
and to the pisoFoam2 solver,
IOobject
"R",
runTime.timeName(),
mesh,
IOobject::NO_READ,
turbulence->R()
R.write();
This way, the solver reads R field from time 0 and it writes and updates the R field every time step to a directory.
My problem is two things:
1- I want to have R field written in time directories specified in controlDict (specified write intervals). My new solver writes R in each time step and gives it as an output every time.
2- When I do field averaging, I do not receive the old error which was "the Requested R field does not exist". Now, R field is created. But, it seems that for field averaging, the algorithm gets the initial R field and average that during runtime which always gives the same thing for all times.
I would be happy if you can suggest a way to overcome any of the above issues.
Thanks,
Old   January 27, 2012, 11:12
Gregor Olenik
IOobject
"R",
runTime.timeName(),
mesh,
IOobject::NO_READ,
turbulence->R()
R.write();
there you made a mistake
In the pisoFoam2.C a simple
R=turbulence->R();
should be sufficient. You just want to get the R-field every timestep not create it every timestep. Furthermore you don't need a
R.write()
since you have told the objectRegistry to handle it by IOobject::AUTO_WRITE
Gregor
Old   January 27, 2012, 11:18
pooyan
I also tried adding this line instead of R.write(). But, I received an error when compiling the code. I will post the error in an hour or so.
Thanks
Old   January 30, 2012, 12:00
pooyan
hi,
Thanks to your comments, I could get field average of R over time.
Old   January 30, 2012, 12:15
pooyan
I also want to calculate U*U and get the average of this field over time. U is given by OpenFoam. I just need to add some lines to calculate U*U. if U=[1 2 3;4 5 6], by U*U, I mean the result is [1 4 9;16 25 36]. I do not know how openfoam writes U field so that I can write a "for loop" to calculate U*U. do you have any suggestions?
Old   January 30, 2012, 13:17
pooyan
Hi Gregor
I guess Uprime2Mean(0) is also equivalent to the following equation
<UU>-<U><U>, where <> is time averaged value.
since 1/n sum^N (U-<U>)^2= <UU>-2<U><U>+<U><U>=<UU>-<U><U>.
Am I right?
Originally Posted by gregor View Post
Uprime2Mean is simply the variance of the resolved scales. Which is the quadratic value of the standard deviation sigma. Standard deviation gives you an idea on how much your values deviate around a mean value.
var = sigma^2 = 1/(N) sum^N(phi - <phi>)^2, where <.> is a time averaged value
So it is the averaged deviation around a mean value . The definition of Reynoldstresses has nothing to do with how the variances a calculated.
Gregor
Old   January 31, 2012, 04:01
Gregor Olenik
Hi Gregor
Am I right?
correct see http://en.wikipedia.org/wiki/Computa...r_the_variance
but i am a bit confussed by your vector definition in the above post ( U=[1 2 3; 4 5 6] ??)
Gregor
Old   February 1, 2012, 05:48
Eugene de Villiers
eugene is on a distinguished road
You guys are making a mistake. Calling "R()" for an SGS model will not return the total Reynolds stress. It will just return the SGS stress. The only reason it is called "R()" is for compatibility with the RANS model nomenclature.
UPrime2Mean is calculated as:
UPrime2Mean_new = alpha*UPrime2Mean_old + (1-alpha) * sqr(U) - sqr(Umean);
with alpha = (Time - dTime) / Time
If you work it out, this is identical to the definition for Reynolds stress when averaged over a long time (<UU>-<U><U>).
To get the full stresses (resolved + SGS) you thus need UPrime2Mean + RMean. Unfortunately, you will still have to modify a solver to create RMean since the R field is not available by default as noted below.
eugene is offline   Reply With Quote
Old   February 1, 2012, 05:52
Gregor Olenik
I know its confusing to discuss RANs matters in a LES thread but sam1364 is using kEpsilon (according to http://www.cfd-online.com/Forums/ope...tml#post340914).
Gregor
Old   February 1, 2012, 09:26
pooyan
Hi guys,
I have done UPrime2Mean + RMean to get the total Reynolds Stress for RANS simulation. I could get RMean thanks to Gregor suggestions. But I see a big problem when calculating R or Rmean and that is the values of R or RMean at the walls of cavity which are not zero (I am solving the lid driven cavity flow). I am using kqrwallfunction for R but I do not understand why I get non zero values of Reynolds stress at fixed walls. Am I using the right wall function, Should I set the values of R zero at the fixed wall?
Old   February 1, 2012, 10:19
Gregor Olenik
I would assume that you are looking at R in the first cell next to the wall (which isnt zero). R exactly at the wall is zero since your k should be zero.
Gregor
Old   February 1, 2012, 10:38
pooyan
No, I am looking at wall and I am using this initial set up for R
dimensions [0 2 -2 0 0 0 0];
internalField uniform (0 0 0 0 0 0);
boundaryField
movingWall
type kqRWallFunction;
value uniform (0 0 0 0 0 0);
fixedWalls
front
type symmetryPlane;
I guess based on the equation given in Kepsilon.C for R, the values at wall can be non zero.
Old   May 14, 2012, 03:46
Forrest
buct11019 is on a distinguished road
Originally Posted by Tarak View Post
Thanks a lot.
I am using dynamicOneeqEddy model, that's why I am so concerned about it. I am presently simulating the flow over a circular cylinder for Re=3900, but not managing to get an acceptable recirculation length. So, the way you prescribed now may help. If you had any luck with the flow over a circular cylider please do let me know.
Thanks,
Tarak
Nice to meet you , Tarak.
Now I have the same question of you had last year. I am confusing about how to set the k. I had done some work in backward step simulation with oneeqEddy and dynamicOneeqEddy model at the same grid and the same condition. I set k as 1*10-5 in both simulaiton, but the dynamicOneeqEddy model diverge after about 15s, but can go on to compute.Would you please give me some suggestion on it?
buct11019 is offline   Reply With Quote
Old   April 30, 2013, 10:20
Rajesh Kumar
rajeshkunwar is on a distinguished road
Hi Gregor
In my URANS simulation k is not equal to 0.5*(Uprime2MeanXX+Uprime2MeanYY+Uprime2MeanZZ). This is probably because k and epsilon are calculated using evolution equation and R is computed using boussinesq approximation. whereas UPrime2Mean is computed using postprocessing of U field. So I doubt Reynolds stress is UPrime2Mean in URANS simulations.
I will appreciate your comment.
rajeshkunwar is offline   Reply With Quote
Problems sampling UPrime2Mean leonardo.morita OpenFOAM Post-Processing 5 May 10, 2012 04:36
Bug in Dynamic 1Eq Eddy Viscosity LES Model Incompressible flow harishg OpenFOAM Bugs 5 December 2, 2008 18:18
