Strange Result for Versteeg Testcase (2D, convection only, steady state)
Old   August 16, 2011, 03:42
Question Strange Result for Versteeg Testcase (2D, convection only, steady state)
Chris
caramelo is on a distinguished road
Hi everybody,
I'm new to OpenFOAM and tried to implement a testcase from the Versteeg and Malalasekera book[1]. GoogleBooks
To solve the problem I used the scalarTransportFoam solver and set DT = 0 as it is a convection only problem. I used the boundary condition from the book except for the two outlet patches, where I used zeroGradient for phi.
The result I get are quite normal as long as I don't reach a certain number of cells. For example if my domain is 1 x 1 m and I use more than 21 cells in the x_1 and the x_2 direction the result is completely instable and has nothing to do with the analytic solution. I solved the div(phi,T) term with Gauss linear. But the solution doesn't converge either if I use QUICK or vanLeer to compute the gradient. Only upwind always give a reasonable but not really accurate solution.
Does anybody have an idea what problem is?
Thanks in advance.
caramelo
caramelo is offline   Reply With Quote
Old   August 16, 2011, 14:16
santiagomarquezd's Avatar
Santiago Marquez Damian
santiagomarquezd will become famous soon enough
Can you post an sketch of the problem and BC's used?
Regards.
Santiago MÁRQUEZ DAMIÁN, Ph.D.
Research Scientist
Research Center for Computational Methods (CIMEC) - CONICET/UNL
Tel: 54-342-4511594 Int. 7032
Colectora Ruta Nac. 168 / Paraje El Pozo
(3000) Santa Fe - Argentina.
http://www.cimec.org.ar
santiagomarquezd is offline   Reply With Quote
Old   August 16, 2011, 15:45
Chris
You can see a sketch in the GoogleBooks links i posted. I just added the whole case as an attachment. With this setting you will get a reasonable result. If you now increase the numbers of cells in the blockMeshDict, no reasonable result will be received any more.
Old   August 16, 2011, 17:17
Laurence R. McGlashan
l_r_mcglashan will become famous soon enough
When you get finer grid cells, I think there's an issue with the Courant number for non-upwind schemes. Try changing ddtSchemes to Euler and make the endTime in controlDict something like 2; I get 'better' results with that.
I note that:
"At the first and last nodes where the diagonal intersects the boundary a value of 50 is assigned to \phi."
Might that be an issue?
Laurence R. McGlashan :: Website
l_r_mcglashan is offline   Reply With Quote
Old   August 17, 2011, 17:55
Alberto Passalacqua
It is simply a question of conditioning of the linear problem you are trying to solve. You would need under-relaxation (have to modified the code adding T.relax()) to use the code as steady state.
Alternatively, simply perform a pseudo-transient simulation, as suggested by Laurence, since the effect is the same as under-relaxing.
P.S. It is not a problem in the schemes ;-)
Best,
Alberto Passalacqua
Time step dependence of convergence behavior of steady state simulations in CFX Chander Main CFD Forum 5 December 23, 2013 05:31
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
regarding steady state discrete phase calculations hajszan_gyula FLUENT 1 February 28, 2006 01:32
About the difference between steady and unsteady problems Lisa Main CFD Forum 11 July 5, 2000 14:37
Steady state formulation of turbulence ?? Jitendra Main CFD Forum 1 June 27, 2000 18:49
