rhoPimpleFoam aborting with floating point exception (because of wrong bc p?)
Old   August 8, 2011, 14:48
Default rhoPimpleFoam aborting with floating point exception (because of wrong bc p?)
Hauke R.
space is on a distinguished road
Hello everyone,
what I did until now:
3D structure build with ProE --> exported as IGES/STEP
Imported with Netgen-4.9.13 and meshed with option very fine --> exported as Neutral Format
Imported with netgenNeutralToFoam (openfoam-2.0.0)
copied files from ... /compressible/rhoPimpleFoam/ras/angledDuct (edited a little bit the patches and names of the patches)
The way I set up my boundary conditions: (http://netload.in/dateiOF69C1QR0g/20110808r1.tar.gz.htm ~134 KB) (it's a little bit bigger file size than ~97.7 KB because of compatibility with openFOAM 1.7.1 and 2.0.x.)
These are the boundary conditions I want to set:
inlet is open to the atmosphere (athmospheric pressure 101325 Pa, inlet flow 0.000020833 Kg/s)
Outlet0 and 1 are connected to a low pressure pump. The pressure for each outlet is 1000Pa.
Temperature doesn't matter, so I set the inlet entry to 273.15 K and the other ones to zeroGradient.
I've tried it with openfoam-1.7.1, 2.0.0 and 2.0.1, laminar and turbulent settings edited relaxation factors, used rhoSimpleFoam and rhoPimpleFoam --> nothing worked for my case. I got always sooner or later a floating point exception.
My questions are:
1) Is it possible at all to solve low- or high-pressure problems with rhoSimpleFoam, rhoPimpleFoam?
2) What is the problem in my case?
Hope you can help me with my case.
Many thanks for your attention and best regards
Hauke
space is offline   Reply With Quote
Old   August 18, 2011, 16:29
Eric M. Tridas
eric.m.tridas is on a distinguished road
Hello Hauke,
I am working on a similar problem analyzing the air flow into a vacuum chamber through a 20 mil capillary. My inlet and outlet pressures are very similar to yours. I am interested in how this goes for you as I am having similar problems getting my model to work.
-Eric
eric.m.tridas is offline   Reply With Quote
Old   October 5, 2011, 05:44
Muhammad Umer Ijaz Chaudrey
umer.chaudrey is on a distinguished road
Send a message via Skype™ to umer.chaudrey
What is the Courant Number, MaxCo and deltaT (time step) you are using? for rhoPimpleFoam
umer.chaudrey is offline   Reply With Quote
Floating point exception during parallel mode of fluent aamer FLUENT 10 May 16, 2019 09:49
Floating point exception in parallel mode of fluent aamer FLUENT 0 January 11, 2011 13:30
Floating point exception? Alex FLUENT 0 March 23, 2006 14:55
floating point exception (underflow) Prashant Main CFD Forum 0 December 17, 2004 01:54
Floating point exception in 3D (Gambit) natacha FLUENT 0 August 24, 2004 07:28
