Can I specify the write/data output directory?
Old   November 3, 2011, 12:53
Default Can I specify the write/data output directory?
Shawn
Shawn_A is on a distinguished road
Is there any way to specify the data output / write directory? I assume this would be done in controlDict, but I haven't been able to find anything thta will do it. It would be nice if I could create a directory called "Results" or "Solution" or whatever and have all my timesteps, forces, etc. written there instead of into the case directory.
Thanks
Shawn
Shawn_A is offline   Reply With Quote
Old   November 3, 2011, 15:13
David Gaden
marupio is on a distinguished road
You can only specify a subdirectory.
See the wiki: http://openfoamwiki.net/index.php/Op...objectRegistry
The output goes to the IOobject's path, which can is:
instance/local/name
You give it the "instance" and (optionally) "local" when you create the IOobject. name is its name, and that becomes the filename.
instance can only be one of 5 things. See the wiki.
Follow me on twitter @DavidGaden
marupio is offline   Reply With Quote
OpenFoam install script Error during paraFoam installation SePe OpenFOAM Installation 10 June 19, 2010 15:15
critical error during installation of openfoam Fabio88 OpenFOAM Installation 21 June 2, 2010 03:01
Re : Problem Installing OpenFOAM on Centos -5.3 mohanphy OpenFOAM Installation 1 February 7, 2010 19:09
Problem installing on Ubuntu 9.10 -> 'Cannot open : No such file or directory' mfiandor OpenFOAM Installation 2 January 25, 2010 09:50
Compiling OpenFOAM13 on AMD64 with Redhat Enterprise mbeaudoin OpenFOAM Installation 20 June 17, 2008 06:43
