July 21, 2013, 06:17 |
#161 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Hi Reza,
Sorry about that. It's so much information I'm looking at here in the forum, that I'm failing to notice some details. I don't have access to Pointwise, so I have to ask:
Bruno
July 21, 2013, 06:33 |
#162 |
reza
Brunu,
Would you please specify what you mean clearly. We have run this mesh as self-propelled case, a propeller installed on a ship with hull and rudder. It seems OK and done by my supervisor. |
July 21, 2013, 06:46 |
#163 |
Bruno Santos
Rep Power: 128 |
Hi Reza,
OK, I'll try to be clearer. You have a mesh generated with Pointwise, correct? But how did you get that mesh into a format that OpenFOAM can use? Best regards, Bruno
July 21, 2013, 06:51 |
#164 |
reza
You can export the mesh into 3D-OPenFoam.(Please look at the attachment)
July 21, 2013, 06:52 |
#165 |
Bruno Santos
Rep Power: 128 |
Ah, OK, I didn't know that.
What export options does it give you?
July 21, 2013, 07:00 |
#166 |
reza
For OF just OF3D.
July 21, 2013, 07:05 |
#167 |
Bruno Santos
Rep Power: 128 |
OK, I think I'm getting the idea.
Can you please generate a very small example case in Pointwise, such as having an internal cylinder and an external cylinder, so that the internal one should rotate inside the external one? Then share the two meshes in OpenFOAM format here on the forum or at Dropbox or something like that? Because this way I could see for myself what we're working with.
July 21, 2013, 07:11 |
#168 |
reza
Bruno
I can send my major case includes stator+rotor,Ok? |
July 21, 2013, 07:12 |
#169 |
Bruno Santos
Rep Power: 128 |
If you are allowed to share the case and if the mesh is not too big, I think you can.
July 21, 2013, 07:25 |
#170 |
reza
please give your account in dropB
July 21, 2013, 13:05 |
#171 | |
Bruno Santos
Rep Power: 128 |
Hi Reza,
Only for the last 20 minutes have I managed to look into this with enough attention. I have a question for you... How exactly did you do this step : Quote:
Bruno
July 21, 2013, 13:26 |
#172 |
reza
The interface between Stator and Rotor must be in patch type before merging and then convert to cyclicAMI, and define a tolerance based on tutorial, that is 10-4 , and neighbor for AMI1 and AMI2. The files I sent you must be implemented based on AMI.
July 21, 2013, 13:27 |
#173 |
Bruno Santos
Rep Power: 128 |
Then do you mean that you used "createBafflesDict" and createBaffles?
July 21, 2013, 13:43 |
#174 |
reza
no not at all, please take a look here,
http://143.248.98.6/ExCFD/dynamicMesh.pdf |
July 21, 2013, 14:00 |
#175 |
Bruno Santos
Rep Power: 128 |
Hi Reza,
Mmm... I suspected as much. Well, the trick of editing the file "constant/polyMesh/boundary" sometimes works, other times it doesn't. Or at least, I think it might not work as intended. The reason I say this is because creating baffles requires an indication of "which side is up", or in other words, a reference cell zone for figuring out which side is on the baffle side master and which is on baffle side slave. In theory, incorrectly defining these patches can lead to wrong oriented faces, which could in turn lead to crazy values on the baffle surfaces. I'm going to see if I can still test this today, namely to use createBaffles for producing a proper surface connection... but only after confirming first the quality of the resulting mesh, after editing the "boundary" file directly, namely by running: Code:
checkMesh -allTopology -allGeometry -constant Bruno
July 21, 2013, 14:05 |
#176 |
reza
Thanks so much Bruno ,I am online If you have any question or needs to sent final case that is ready to run.
Furthermore,I run this case with different Inflow . I can sent some pictures from the results. One odd thing is to see sometimes the non-overlapped cells . REGARDS Reza |
July 21, 2013, 14:20 |
log file
#177 | |
reza
July 21, 2013, 14:24 |
#178 | |
Bruno Santos
Rep Power: 128 |
From your log file, this looks like a problem:
OpenFOAM's 2.x paraFoam is able to represent these sets, namely the set in question "twoInternalFacesCells"; search for the "sets" option on the "Object Inspector".
July 21, 2013, 14:33 |
#179 |
reza
i access to OF2.1x 2.2x in Cluster network .would you please specify what you mean
July 21, 2013, 14:34 |
#180 |
Bruno Santos
Rep Power: 128 |
Sorry, I meant 2.x, with x=0,1,2.
In other words, as of OpenFOAM 2.0.0 and beyond, you can use this feature in paraFoam. Therefore, both 2.2.x and 2.1.x should have it.
UDF compiling problem | Wouter | Fluent UDF and Scheme Programming | 6 | June 6, 2012 04:43 |
Gambit - meshing over airfoil wrapping (?) problem | JFDC | FLUENT | 1 | July 11, 2011 05:59 |
natural convection problem for a CHT problem | Se-Hee | CFX | 2 | June 10, 2007 06:29 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 19:13 |
Is this problem well posed? | Thomas P. Abraham | Main CFD Forum | 5 | September 8, 1999 14:52 |
