OF 2.x, cyclic boundary and MRFSimpleFoam compatibility
Old   January 8, 2012, 13:34
Default OF 2.x, cyclic boundary and MRFSimpleFoam compatibility
jmf
Jean-Michel FONTAINE
jmf is on a distinguished road
Hello dear forum
Did anybody experiment OF 2.1.0 with cyclicAMI boundaries and MRFSimpleFoam ? Is it supposed to work ?
I used to do that with OF 1.5-dev. I'm testing OF 2.1.0, from RPM packages for SUSE.
I get following error :
Reading field p
Reading field U
AMI: Creating addressing and weights between 10342 source faces and 13525 target faces
AMI: Patch source weights min/max/average = 6.7415422e-14, 1.2787833, 1.0003003
AMI: Patch target weights min/max/average = 0, 1.2746978, 1.0002249
Selecting incompressible transport model Newtonian
Selecting RAS turbulence model kOmegaSST
#0  Foam::error::printStack(Foam::Ostream&) in "/opt/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1  Foam::sigFpe::sigHandler(int) in "/opt/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2   in "/lib64/libc.so.6"
#3  Foam::FaceCellWave<Foam::wallPoint, int>::updateFace(int, Foam::wallPoint const&, double, Foam::wallPoint&) in "/opt/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libmeshTools.so"
#4  Foam::FaceCellWave<Foam::wallPoint, int>::handleAMICyclicPatches() in "/opt/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libmeshTools.so"
#5  Foam::FaceCellWave<Foam::wallPoint, int>::iterate(int) in "/opt/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libmeshTools.so"
#6  Foam::patchWave::correct() in "/opt/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libmeshTools.so"
#7  Foam::patchWave::patchWave(Foam::polyMesh const&, Foam::HashSet<int, Foam::Hash<int> > const&, bool) in "/opt/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libmeshTools.so"
#8  Foam::wallDist::correct() in "/opt/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
#9  Foam::wallDist::wallDist(Foam::fvMesh const&, bool) in "/opt/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
#10  Foam::incompressible::RASModels::kOmegaSST::kOmegaSST(Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::transportModel&, Foam::word const&, Foam::word const&) in "/opt/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libincompressibleRASModels.so"
#11  Foam::incompressible::RASModel::adddictionaryConstructorToTable<Foam::incompressible::RASModels::kOmegaSST>::New(Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::transportModel&, Foam::word const&) in "/opt/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libincompressibleRASModels.so"
#12  Foam::incompressible::RASModel::New(Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::transportModel&, Foam::word const&) in "/opt/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libincompressibleRASModels.so"
#13
 in "/opt/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/bin/MRFSimpleFoam"
#14  __libc_start_main in "/lib64/libc.so.6"
#15
 at /usr/src/packages/BUILD/glibc-2.11.3/csu/../sysdeps/x86_64/elf/start.S:116
Exception en point flottant
Does anybody have a suggestion ?
Thanks in advance, and best wishes
Jean-Michel
PS : many thanks and congratulations to OF maintainers team for the last evolutions of the software : AMI, edges in SHM, packaging
jmf is offline   Reply With Quote
Old   January 9, 2012, 14:24
Michael Ahlmann
danishdude is on a distinguished road
I configured a cyclicAMI case last weekend (using rotationally cyclic boundary conditions), and it seemed to work smoothly. Granted, I'm having convergence issues with MRFSimpleFoam, but I'm fairly certain it's a setup issue and has nothing to do with the AMI implementation (It's looking like the boundary patches need to be further offset from the rotating features).
Can you provide more detail on your case? Perhaps post the case files if they aren't too big?
danishdude is offline   Reply With Quote
Old   January 9, 2012, 15:22
Default [SOLVED] cyclicAMI + MRFSimpleFoam crash
jmf
Hi Mickael
Thanks for your attention. Finally I found the fix on the forum. Running following command did the job :
unset FOAM_SIGFPE
Don't ask me why
This forum is very good. Thanks to everybody
Regards
jean-Michel
Old   May 23, 2012, 10:10
Forrest
buct11019 is on a distinguished road
Originally Posted by jmf View Post
Hi Mickael
unset FOAM_SIGFPE
Don't ask me why
Regards
jean-Michel
It doesen't work...just there was not the warning ,but can't calculate.
buct11019 is offline   Reply With Quote
Old   May 24, 2012, 04:01
Forrest
I think it's because you over estimate the boundary values of k and epsilon
Old   July 29, 2012, 01:51
Default plz tell me it is true???or not???
vahid
vahid.najafi is an unknown quantity at this point
hi Dear Foamers.
I want to add k(kinetic turbulence energy) in one solver.
for this reason added this line in code :
const volScalarField &k=U_.db().lookupObject<volScalarField>("k")
and wmake was Successfully .
but How can I Understand that this k is the same with k(kinetic turbulence energy)???Is it true?????
Because I replase another world in this :
const volScalarField &M=U_.db().lookupObject<volScalarField>("M")
but not error occured!!!!!!??????
vahid.najafi is offline   Reply With Quote
cyclic boundaries, mrfsimplefoam
MRFSimpleFoam: wrong boundary conditions on rotating walls cves OpenFOAM Bugs 3 May 3, 2010 03:38
case with cyclic boundary openfoam_user OpenFOAM Running, Solving & CFD 0 March 26, 2010 07:46
cyclic BC - createPatch AirS OpenFOAM 7 November 12, 2009 10:04
Cyclic boundary conditions axisymmetric gabriel OpenFOAM Running, Solving & CFD 0 July 27, 2007 11:24
[OpenFOAM] View cyclic boundaries using MRFSimpleFoam gabriel ParaView 0 July 27, 2007 08:42
