Modelling a Water-Air bubble column
Old   February 27, 2012, 13:21
Default Modelling a Water-Air bubble column
Gerhard Holzinger
GerhardHolzinger will become famous soon enoughGerhardHolzinger will become famous soon enough
Greetings foamers,
I try to simulate a water-air bubble column like the becker test-case (Becker et al. 1999: flat bubble column, single gas-sparger in the centre of the bottom)
The mesh is easily built using blockMesh. I attached a screenshot of the mesh.
The solver I use is twoPhaseEulerFoam.
My questions are:
Which dragModels are recommended for gas bubble - water eulerian simulation?
Are there any changes that have to be made when starting from one of the tutorial cases?
GerhardHolzinger is offline   Reply With Quote
Old   February 28, 2012, 04:12
Alberto Passalacqua
The standard drag model used for that test cases by many authors in the literature is Schiller-Neumann, and the drag phase is the dispersed one (air). OpenFOAM defaults to the "blended" model, which is more stable when phase separation occurs.
Best,
Alberto Passalacqua
Simulating A water bubble in air with periodic boundary condition cubicmatrixist Main CFD Forum 0 October 14, 2010 12:26
Modelling free falling water into a air filled duct? sandmike_83 CFX 4 August 24, 2010 03:27
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
Simulating air jet into 2D & 3D water domain Imran FLUENT 0 June 6, 2006 08:57
three phase modelling (air sand water ) Gunjan kumar FLUENT 0 December 29, 2004 07:55
