Calculation of mass flow rate in OpenFOAM 2.0.1
Like Tree4Likes
  • 2 Post By Aurelien Thinat
  • 1 Post By kripalpariyangat
  • 1 Post By Manojmech
Old   February 23, 2012, 10:19
Default Calculation of mass flow rate in OpenFOAM 2.0.1
rawe666 is on a distinguished road
Hello friends,
After looking around the forums and reading some posts, I am confused with the measurement of mass flow rate in Openfoam. I want to calculate the values of my inlet and outlet patches. Could anybody can show me the proper way in OpenFoam 2.0.1? I am sorry for taking your time with that simple question.
Kind regards
rawe666 is offline   Reply With Quote
Old   February 23, 2012, 10:37
Rob
robbirobocop is on a distinguished road
Here you go...
This is probably one of the easier ways to do so.
robbirobocop is offline   Reply With Quote
Old   February 23, 2012, 10:45
thank you for your reply I saw the post you send me. But still have a doubt are you talking about calcMassFlow utility? It seems to be it is valid for ver. 1.4
Old   February 23, 2012, 10:46
Aurelien Thinat
Aurelien Thinat is on a distinguished road
You can just use the command "patchIntegrate phi patchname", can't you ?
Barbara and utkunun like this.
Aurelien Thinat is offline   Reply With Quote
Old   February 23, 2012, 10:52
Thank you it works!
Old   February 29, 2012, 04:24
Abhinay Kulkarni is on a distinguished road
Hi Aurelien,
I have used the "patchIntergrate phi Patchname" command. I want to calculate the mass flow at my oultet patch and also want to plot it over the time in paraview. I have two questions
1. Is the mass flow calculated by the patchIntergrate command stored somewhere?? or is just shown in the terminal.
2. Do you have an idea on plotting/viewing the mass flow at a particular patch in paraview?
Thank you in advance
Regards
Abhinay
Abhinay Kulkarni is offline   Reply With Quote
Old   February 29, 2012, 08:47
Samuele Z
samiam1000 is on a distinguished road
Dear Abhinay,
I am interested in this feature, too.
Have you solved it, by chance?
If so, what have you done?
Thanks,
Samuele.
samiam1000 is offline   Reply With Quote
Old   February 29, 2012, 11:22
Hi Samuele,
unfortunately i have not found a solution although i did find an interesting discussion on the forum. I did try the way suggested here but have not quite understood the method. Still searching . Here is the link
http://www.cfd-online.com/Forums/ope...-paraview.html
Let me know if you figure it out.
Regards
Abhinay
Old   May 15, 2012, 06:14
Kripal
kripalpariyangat is on a distinguished road
Hi All,
You can save the data into a text file
use
patchIntegrate phi INLET >inletflow
This will create a file named "inletflow" in which the data will be saved at each timestep. Hope this helps
kripalpariyangat is offline   Reply With Quote
Old   May 15, 2012, 06:34
Samuele Z
Hi all,
thanks for help.
Just a question: where should I insert the command
Should I insert it in a control-dict file or something like this?
Thanks a lot,
Samuele.
Old   May 15, 2012, 06:43
Kripal
Hi Samuele,
Get inside the case folder using cd command in command prompt and then used the "patchIntegrate" command.
Note: if the case is a decomposed one, reconstruct it and then use this command
Regards
Kripal
samiam1000 likes this.
Old   May 13, 2014, 04:23
adarsh tiwari's Avatar
adarsh tiwari
adarsh tiwari is on a distinguished road
hi all,
I am relatively new in OpenFOAM and with my observation i can say that patchIntegrate gives the integrated values, but what to do if somebody is interested in calculating the average values for the same
I tried using
patchAverage phi Inlet
but it doesn't works..
Thanks and Regards,
Adarsh
adarsh tiwari is offline   Reply With Quote
Old   December 3, 2015, 15:21
openfoammaofnepo is on a distinguished road
Hi everybody,
I meet a problem with calculating the mass flow rate. I would like to know if mass flow rate for an interior surface, instead of the boundary surfaces. Is this possible? My mesh is 3D and generated by ICEM. Actually I have made an interior surface there, but as you may know, for openfoam, this interior surface does not appear in the boundary list (constant/polymesh/boundary). So it seems that "patchIntegrate phi BC_name" doed not work for this. Anybody has some ideas for this? Thank you so much.
best regards,
OFFO
openfoammaofnepo is offline   Reply With Quote
Old   April 5, 2017, 04:48
Default MFR in interior surfaces
  #14
cfdRocker
Manojmech is on a distinguished road
Hi All,
I have to reopen this thread. I think its been 2 years since the last post. OPenfoam has developed more now. I would like to know if there is anyway to calculate mass flow rate in any of the interior surfaces ?
Regards,
Manoj
sandra92g likes this.
Manojmech is offline   Reply With Quote
Old   November 17, 2017, 11:14
Default MassFlowRate; Inlet and Oulet Patch
  #15
Shafik Walakaka
walakaka is on a distinguished road
Hi guys,
I am also needing to calculate the mass flow rate at the inlet and outlet to ensure that the mass is conserved.
Is there a way to do it on Openfoam4?
Regards
Shaq
walakaka is offline   Reply With Quote
Old   November 21, 2017, 10:18
Robert
RobertHB is on a distinguished road
Have you guys tried flowRateInletVelocity? I found this BC on https://www.openfoam.com/documentati...conditions.php
RobertHB is offline   Reply With Quote
calculation mass fw rate, mass flow rate, mass flow rate inlet
Mass flow rate: calculation v/s computation beguxa FLUENT 5 December 2, 2018 21:02
Calculation of mass flow rate through a plane titio OpenFOAM Post-Processing 2 September 28, 2010 00:28
The reporting of mass flow rate summer FLUENT 1 July 12, 2007 09:35
mass flow rate error Masood FLUENT 0 May 22, 2005 00:32
Target mass flow rate Saturn FLUENT 0 December 10, 2004 04:18
