July 9, 2014, 13:46 |
Wall heat transfer
Rep Power: 11 |
I would like to solve heat transfer from an air flow through a metal wall to surrounding air without modelling the solid wall thickenss (separate mesh). The BC would be set as: Internal wall temperature is calculated Internal heat transfer coefficient is calculated Wall thickens and conductivity are assigned External surrounding temperature is assigned Is it possible to use for this problem BC externalWallHeatFlux or is there some other BC for this propose? Is there some tutorial solving this problem? Thanks |
July 10, 2014, 08:44 |
ashwin
Rep Power: 13 |
Hello Altan,
The externalWallHeatFlux fits perfectly to your description. Code:
wall { type externalWallHeatFluxTemperature; kappa fluidThermo; // fluidThermo, solidThermo //q uniform 1000; // heat flux / [W/m2] Ta uniform 300.0; // ambient temperature /[K] h uniform 10.0; // heat transfer coeff /[W/K/m2] thicknessLayers (0.1); // thickness of layer [m] kappaLayers (0.05); // thermal conductivity of // layer [W/m/K] value uniform 300.0; // initial temperature / [K] kappaName none; } Only supply \c h and \c Ta, or \c q in the dictionary |
July 11, 2014, 11:09 |
Wall heat transfer
Rep Power: 11 |
Thanks for the response. I am now testing this BC with rhoSimpleFoam.
Flow around pipes - heat transfer coefficient on the wall of pipe | doodek | Main CFD Forum | 2 | November 23, 2009 08:48 |
Convective / Conductive Heat Transfer in Hypersonic flows | enigma | Main CFD Forum | 2 | November 1, 2009 22:53 |
how to model heat transfer for the coupled wall | jing113cn | FLUENT | 0 | June 22, 2009 03:56 |
How can I increase Heat Transfer at Domain Interf? | B.Simon | CFX | 3 | October 28, 2008 18:53 |
Concentric tube heat exchanger (Air-Water) | Young | CFX | 5 | October 6, 2008 23:17 |
