Acoustic in OF
Old   March 15, 2012, 02:57
Default Acoustic in OF
Daniele Vicario
danvica is on a distinguished road
Starting from pisoFoam result (water flow into a valve), is it possible to obtain information regarding acoustic behavior ?
In high level words: how noisy will be the valve ?
Having obtained force data on a patch is it reasonable to look at them and, for example, calculate FFT to have an approximation of the sound spectrum ?
Daniele
danvica is offline   Reply With Quote
Old   March 19, 2012, 08:41
Daniele Vicario
I did what was in the previous post and here attached you can find the result.
I think pisofoam cannot be used to have acoustic information directly because it's an incompressible solver but... is it physically correct, even with this solver, to look at the pressure on an external patch to get some information on the generated noise ?
Or do I have to quit the idea ?
Thanks for any hint.
P.S. The simulation is still running. I need to collect many more force points in order to have a more precise result at low frequencies. But if I have to quit...
Acoustic source term Nico FLUENT 1 October 11, 2012 02:35
FLUENT 6.1.18 does have steady state acoustic mode Gavisiddayya FLUENT 0 October 8, 2007 11:24
Acoustic simulation Hugh FLUENT 0 October 1, 2006 21:54
acoustic analysis,FSI mehul pandya CFX 0 October 12, 2005 05:18
Acoustic pressure larry Main CFD Forum 8 July 19, 2002 03:40
