Problem computing divergence field
Old   April 1, 2012, 07:06
Default Problem computing divergence field
Gilles De Neyer
gdeneyer is on a distinguished road
I'm actually trying to compute the divergence field for a laminar compressible flow on a cylinder and I got weird results around the cylinder. I have a zero divergence field inside the structured grid around cylinder and then some fluctuation in the non structured grid.
The code I used for this was just this at the end of my timeloop
volScalarField divField
IOobject
"divU",
mesh.time().timeName(),
mesh,
IOobject::NO_READ
IOobject::AUTO_WRITE
fvc::div(U)
Note: the flow is laminar with low Mach number 0.05 using rhoPimpleFoam, in attachment the divergence field with and without the mesh
gdeneyer is offline   Reply With Quote
Old   April 2, 2012, 02:34
Alberto Passalacqua
There are a good number of posts explaining that what should be computed is
fvc::div(phi)
and not fvc::div(U).
Best regards,
Alberto Passalacqua
Multiphase phase (gas-solid) flow using Eulerian-Granular medel ( divergence problem) jessie FLUENT 3 May 29, 2014 11:05
Divergence problem for species transport model MY FLUENT 3 January 11, 2014 04:46
Problem while running in Highperformance computing environment Phanipavan STAR-CD 1 September 11, 2013 06:42
problem during my computing oliver FLUENT 0 May 31, 2007 08:35
Divergence Free on the Magnetic Field Valdemir Main CFD Forum 1 March 19, 2003 18:33
