Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Verification & Validation
simpleFoam Validation in Urban Environment using AIJ guidelines (openCAE)
Like Tree3Likes
Old   October 22, 2013, 06:43
Masashi IMANO
imano is on a distinguished road
Hmm.. It seems that OF-2.1.0 does not have nutkAtmRoughWallFunction
boundary condition.
So I have changed nut wall function from nutkAtmRoughWallFunction
to nutkWallFunction in branches/2.1/CaseA case.
Please see changeset below and exclude "svn update" in that directory!
http://www.opencae.jp/changeset/128/OpenFOAM-VandV-SIG
Masashi
Originally Posted by alvinsim2013 View Post
Dear Masashi-san,
I have changed to OF2.1 and included the boundaryData's points, k, U and epsilon in the constant folder.
All the log files did not show up any error messages, except 'log' file.
| \\ / O peration | Version: 2.1.0 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
Build : 2.1.0-bd7367f93311
Exec : simpleFoam
Date : Oct 22 2013
Time : 12:22:58
Host : "hpclogin2"
PID : 16674
Case : /OpenFOAM-VandV-SIG/AIJ-PWEAB/branches/2.1/CaseA
nProcs : 1
allowSystemOperations : Disallowing user-supplied system call operations
Create time
Create mesh for time = 0
Reading field p
Reading field U
Selecting incompressible transport model Newtonian
Selecting RAS turbulence model kEpsilon
--> FOAM FATAL IO ERROR:
Unknown patchField type nutkAtmRoughWallFunction for patch type wall
Valid patchField types are :
65
advective
atmBoundaryLayerInletEpsilon
buoyantPressure
calculated
codedFixedValue
codedMixed
cyclic
cyclicAMI
cyclicSlip
directionMixed
empty
epsilonWallFunction
fan
fanPressure
fixedFluxPressure
fixedGradient
fixedInternalValue
fixedPressureCompressibleDensity
fixedValue
freestream
freestreamPressure
inletOutlet
inletOutletTotalTemperature
kappatJayatillekeWallFunction
kqRWallFunction
mapped
mappedField
mappedFixedInternalValue
mappedFixedPushedInternalValue
mixed
nonuniformTransformCyclic
nutLowReWallFunction
nutTabulatedWallFunction
nutURoughWallFunction
nutUSpaldingWallFunction
nutUWallFunction
nutkRoughWallFunction
nutkWallFunction
omegaWallFunction
oscillatingFixedValue
outletInlet
outletMappedUniformInlet
partialSlip
processor
processorCyclic
rotatingTotalPressure
sliced
slip
symmetryPlane
syringePressure
timeVaryingMappedFixedValue
totalPressure
totalTemperature
turbulentHeatFluxTemperature
turbulentInlet
turbulentIntensityKineticEnergyInlet
turbulentMixingLengthDissipationRateInlet
turbulentMixingLengthFrequencyInlet
uniformDensityHydrostaticPressure
uniformFixedValue
uniformTotalPressure
waveSurfacePressure
waveTransmissive
wedge
zeroGradient
file: /OpenFOAM-VandV-SIG/AIJ-PWEAB/branches/2.1/CaseA/0/nut::boundaryField::z_ from line 27 to line 30.
From function fvPatchField<Type>::New(const fvPatch&, const DimensionedField<Type, volMesh>&, const dictionary&)
in file /usr/local/OpenFOAM/OpenFOAM-2.1.0/src/finiteVolume/lnInclude/fvPatchFieldNew.C at line 135.
FOAM exiting
Thanks a lot.
imano is offline   Reply With Quote
Old   October 22, 2013, 12:19
Alvin TS
alvinsim2013 is on a distinguished road
I have made the changes, but log.Toposet has errors too.While log.sample has FOAM warning, hope this is okay.
Exec : topoSet
Date : Oct 23 2013
Time : 00:14:06
Host : "hpclogin2"
PID : 6935
Case : /gpfs/home/tssim1/OpenCAE/AIJ-new2/OpenFOAM-VandV-SIG/AIJ-PWEAB/branches/2.1/CaseA
nProcs : 1
Create time
Create polyMesh for time = 0
Reading topoSetDict
cannot open file
file: /gpfs/home/tssim1/OpenCAE/AIJ-new2/OpenFOAM-VandV-SIG/AIJ-PWEAB/branches/2.1/CaseA/system/topoSetDict at line 0.
From function regIOobject::readStream()
in file db/regIOobject/regIOobjectRead.C at line 87.
FOAM exiting
Exec : sample -latestTime
Date : Oct 23 2013
Time : 00:14:16
Host : "hpclogin2"
PID : 7472
nProcs : 1
Create time
Create mesh for time = 200
--> FOAM Warning :
From function sampledSets::combineSampledSets(..)
in file sampledSet/sampledSets/sampledSets.C at line 102
Sample set verx_-075 has zero points.
--> FOAM Warning :
Sample set verx_075 has zero points.
--> FOAM Warning :
Sample set verx_125 has zero points.
--> FOAM Warning :
Sample set verx_200 has zero points.
--> FOAM Warning :
Sample set verx_325 has zero points.
Reading set description:
verx_-075
verx_-050
verx_-025
verx_000
verx_050
verx_075
verx_125
verx_200
verx_325
Time = 200
End
alvinsim2013 is offline   Reply With Quote
Old   October 22, 2013, 12:31
Alvin TS
There should be a 'topoSetDict' file in the 'system' directory, should it?
Old   October 23, 2013, 02:29
Default AIJ Test Case B
  #24
Alex Lee
Alex Lee is on a distinguished road
Originally Posted by wyldckat View Post
Greetings to all!
Looking back at the original problem:
The problem is that this "link" is actually an artificial link created by the SVN mechanism. It actually means that when checking out the source code through SVN, it would automatically interpret the "Allrun" file as a symbolic link pointing to "../share/Allrun", namely this file: http://www.opencae.jp/svn/OpenFOAM-V...B/share/Allrun
To manually fix this, run from the "CaseB" folder the following block of code on the command line:
for model in kEpsilon NonlinearKEShih RNGkEpsilon realizableKE
do
    cd $model
    rm Allrun
    ln -s ../share/Allrun Allrun
done
And that's that! It's ready to be used.
Best regards,
Bruno
Dear all,
I could not resolve the problem using the above tips by Bruno.
I did a ./Allrun in the kEpsilon folder and just to check out what is wrong with the script. Here is the error message during the simpleFoam run:
| \\ / O peration | Version: 2.1.1 |
Build : 2.1.1-221db2718bbb
Exec : simpleFoam
Date : Oct 23 2013
Time : 14:19:00
Host : "judah-Ubuntu"
PID : 23454
Case : /home/alex/OpenFOAM/CaseB-2.1/kEpsilon
nProcs : 1
Create time
--> FOAM FATAL ERROR:
Cannot find file "points" in directory "polyMesh" in times 0 down to constant
From function Time::findInstance(const fileName&, const word&, const IOobject::readOption, const word&)
in file db/Time/findInstance.C at line 188.
FOAM exiting
Alex Lee is offline   Reply With Quote
Old   October 23, 2013, 03:42
Masashi IMANO
Hi Alvin,
Right!
I have added topoSetDict in trunk repository but I forgot to add
it in branches repository, sorry. So I just added it now.
http://www.opencae.jp/changeset/129/OpenFOAM-VandV-SIG
Masashi
Old   October 23, 2013, 04:03
Masashi IMANO
I just removed branches/2.1/Case[B-F] for maintenance.
http://www.opencae.jp/changeset/130/OpenFOAM-VandV-SIG
So please wait for a while until updating these cases for OF version 2.1.x.
BTW as Bruno suggested, symbolic link files in CaseB/[RASModel] directories would not be checked out correctly if you check out on non *nix file system like NTFS or FAT.
So checkout should be done on *nix file system or OS like Linux or Mac OS.
All the Best,
Masashi
JR22 likes this.
Old   October 23, 2013, 09:10
Alvin TS
ありがとう, Masashi san
Old   December 2, 2013, 01:08
Alvin TS
Hi Imano san,
Not sure if there is any update of the cases?
Old   December 16, 2013, 01:25
Default updates on cases on maintenance
  #29
Alvin TS
Originally Posted by imano View Post
All the Best,
Masashi
Hi Masahi, any updates for any of the case taken down for maintenance soon?
Old   January 2, 2014, 03:46
Default comparing timevaryingmappedfixedvalue and setdiscretefield
  #30
Alvin TS
Hi Masashi-san,
1) I would like to ask about your case A on the site
http://www.opencae.jp/wiki/OpenFOAM-VandV-SIG/AIJ-PWEAB
I looked through the '0' folder and it uses 'timevaryingmappedfixedvalue'. I thought you have used setdiscretefield utility since this case A does not use snappyhexmesh. Am I right to say that even for discretesetfield utility, one needs to specify the timevaryingmappedfixedvalue BC in the 0 folder?
2) Since you have done the case A using timevaryingmappedfixedvalue and setdiscretefield, is there any difference in the final results obtained?
Regards
Alvin
Old   July 23, 2014, 09:07
Default AIJ Test Cases OpenFoam Report
  #31
Alex Lee
Dear Imano san,
I am wondering have you ever compiled the AIJ validation results obtained using OpenFoam?
If yes, could i have the privilege to obtain a copy of this report ?
The purpose of this request is to enable me to bring to our building construction authority (BCA) and to convice them that OpenFoam results are as good as Fluent or CFX or Star CCM.
Currently, they are so stiff neck about their decision on not letting people submitting OpenFoam results in building performance analysis submission.
Your help is very much appreciated.
Thank you.
ALEX LEE
buildings, simplefoam, urban wind, validation
CFX problem in ubuntu (linux) Vigneshramaero CFX 0 July 13, 2012 10:22
CFX-Pre problem, pls help!!! cth_yao CFX 0 February 17, 2012 00:52
Porous jump in urban environment samygero FLUENT 0 February 14, 2011 18:26
