Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Verification & Validation
Velocity curve in channel flow by pisoFoam and LES
Like Tree7Likes
  • 2 Post By mxylondon
  • 1 Post By itchy
  • 2 Post By itchy
  • 2 Post By itchy
Old   July 19, 2013, 08:49
Default Velocity curve in channel flow by pisoFoam and LES
X Meng
mxylondon is on a distinguished road
Dear all,
I am struggling with a trouble in pisoFoam using LES for channel flow.
Basically, the velocity curve from experiment has the maximum value of about 1.15 times of inlet uniform velocity, yeah?
But I got much larger max value like 1.4 times of inlet uniform velocity, and it changes sharply from wall to centre.
My question is, what parameters I may make wrong, or anything I can do to develop that?
P.S.
I am using oneEqEddy model. OF version 2.2.0.
Cheers
m.goudarzi and donalder like this.
mxylondon is offline   Reply With Quote
Old   September 23, 2014, 09:14
Florian Ries
itchy is on a distinguished road
that sounds like to coarse mesh. Which LES Model do you use??? Is your case really turbulent in the LES simulation. Is your case statistically stationary. Have you checked this??
kind regards
Florian
m.goudarzi likes this.
itchy is offline   Reply With Quote
Old   May 18, 2015, 08:19
marzieh goodarzi
m.goudarzi is on a distinguished road
hi
I have the same problem but with pimple solver. I used oneEqEddy of LES model, and used mapped inlet Method, but the maximum velocity is 1.4 that exceed the experimental data.
yplus of mesh is under 1 and about 162,000 node
please help me ,I am confused
m.goudarzi is offline   Reply With Quote
Old   May 19, 2015, 00:41
Florian Ries
hi m.goudarzi,
do you use Van Driest damping??? The OneEqModel behaves wrong at the wall. You have to use van Driest damping!! Or you can use dynOneEq (without Van Driest damping!), but there is a bug in this model
Is your domain long enough??? Your domain has to be twice the longest turbulent structures (Nyquist criteria) i.e. in a pipe the largest turbulent structures is about 6-7 times the pipe diameter, this leads to a length of your domain of 16 times the diameter.
Is your averaging time long enough?? How have you checked that??
Is your flow statistically statinoary before you start averaging?? How have you checked that?
kind regards
Florian
m.goudarzi and warnerchang like this.
Old   May 23, 2015, 13:05
marzieh goodarzi
Hi dear Florian
Thank you for the quick reply
yes! i used " delta vanDriest" in LES properties
I have a channel with 3.33 cm aspect ratio. the length of channel is 20 cm.
I am new user of openfoam, excuse me for this simple question. I dont know about these object, can you explain more?
Thank you
marzieh
Old   May 23, 2015, 13:21
marzieh goodarzi
This is my LES properties
| \\ / O peration | Version: 2.3.0 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
location "constant";
object LESProperties;
LESModel oneEqEddy;
printCoeffs on;
delta vanDriest;
cubeRootVolCoeffs
deltaCoeff 1;
PrandtlCoeffs
delta cubeRootVol;
cubeRootVolCoeffs
deltaCoeff 1;
smoothCoeffs
delta cubeRootVol;
cubeRootVolCoeffs
deltaCoeff 1;
maxDeltaRatio 1.1;
Cdelta 0.158;
vanDriestCoeffs
delta cubeRootVol;
cubeRootVolCoeffs
deltaCoeff 1;
smoothCoeffs
delta cubeRootVol;
cubeRootVolCoeffs
deltaCoeff 1;
maxDeltaRatio 1.1;
Aplus 26;
Cdelta 0.158;
smoothCoeffs
delta cubeRootVol;
cubeRootVolCoeffs
deltaCoeff 1;
maxDeltaRatio 1.1;
Old   May 24, 2015, 05:13
Florian Ries
how do you simulate the channel???
I would do it like this:
1. Use pimpleFoam (no relaxation in final iteration, do residualControl with very low values!)
2. use fvOptions with pressureGradientExplicitSource (no mapping method!)
3. initialize your flow with isotropic turbulence (boxTurb) and superimpose a powerlaw profile
4. For LES use Gauss linear (no Upwind!!), corrected (or orthogonal for channel) and backward (ddt)
6. Lets say flowdirection is z and the heigth of the channel is h. As a result of the turbulence structures, the domain has to be: Lz=12h, Lx=4h, Ly=h
7. Run your simulation for 100 flow through domain and then start averaging. (How to average see tutorial channel95)
8. Include a model for your subgrid-stress tensor Tsgs in the oneEq. You need an averaged Tsgs for postprocessing.
How to compare LES data with DNS data:
With LES you simulate a filtered velocity field. The mean value of a filtered signal is equal with the mean value of the unfiltered signal. So you can compare a mean value from a LES with a mean value of a DNS.
This is not true for the RMS value. The RMS value of a LES is smaller then the RMS value of the DNS. To compare this, you have to add the mean subgrid stress tensor TSgs to the covariance matrix of the LES.
Averaging time:
The random error Err of the average depends on the integral time scale Tint. In example, for the mean your random errror is proprtinal:
Err ~ sqrt(2*Tint/tav)
where tav is your averaging time. Tint is a function of space and is much higher near the wall. As a result of this, you have to average much longer at the wall.
You should do a reference simulation with Smagorinsky model. For channel use Smagorinsky parameter Cs=0.05.
kind regards
Florian
Old   June 4, 2015, 14:45
Default LES simulation of curved channel
marjan
mdallali is on a distinguished road
Hi everyone, I model a curved channel with N-S equation in curvilinear coordinates.
I imposed a fix pressure gradient in x- direction which decomposed along the channel in curvilinear coordinate( stream wise and span wise direction) to drive the flow.
So the pressure gradient alter in steam wise and span wise direction along the channel .
But my solution is not stable.
so i Think it s because of unbalance between the body forces.
Does some one has any idea?
Should I use a fixed pressure gradient in stream wise while imposing the centrifugal force as well?
mdallali is offline   Reply With Quote
Old   June 15, 2015, 05:12
Default pisoFoam problems
Gizela
Gizazu is on a distinguished road
Hi everybody, i´ḿ new to openFoam and i´m trying to run pisoFoam for a channel with a pier inside. I received an error (see image) and from that i tried to change somethings in my boundary conditions but still giving the same error.
So, please I need your help to find out what is going wrong, where is my failure and how can I do it right.
it is attached some files (blockMeshDict, U, p, epsilon).
help please.
Kind regards
Gizela
Gizazu is offline   Reply With Quote
Old   June 21, 2015, 07:28
marzieh goodarzi
Thank you very much Florian for your answer
I have done all these steps, but the result did not change
I do not know where is the problem
Friction velocity in Channel flow impecca OpenFOAM Post-Processing 2 April 11, 2014 01:33
setup problems - LES pipe flow with cyclic BC (1) and direct mapped inlet (2) florian_krause OpenFOAM 22 June 13, 2013 21:25
channelFoam for LES of Flow over a Wavy Wall sunliming OpenFOAM 4 May 1, 2013 15:59
unsteady LES pisoFoam questions garrison OpenFOAM Running, Solving & CFD 13 August 17, 2012 20:12
calculating mean streamwise velocity in LES maysmech OpenFOAM 4 September 6, 2010 11:38
