potentialFreeSurfaceFoam parallel run failed?
Old   May 15, 2012, 10:38
Default potentialFreeSurfaceFoam parallel run failed?
ahyangyi is on a distinguished road
Hi, everyone. I was just trying out the ocsillatingBox case in the tutorial directory of OpenFOAM 2.1.0. It ran well, but when I changed it to run in parallel, reconstructPar reported segment fault.
This happens every time I try to run it in parallel, no matter how I decompose the mesh nor how many processors I use.
For your information, the reconstructPar fails when it tries to combine the scalar field p_gh.
Anyone also met this problem? Do you have a solution or any suggestion for this?
Thank you very much in advance!
ahyangyi is offline   Reply With Quote
Old   May 15, 2012, 15:44
Retired Super Moderator
Bruno Santos
Greetings ahyangyi and welcome to the forum!
Well, OpenFOAM 2.1.0 had several bugs and many of them are already fixed in 2.1.x.
If you share the modifications you made to the tutorial case, we (those who go around the forum helping people) can test in 2.1.x and/or check what might be necessary for things to work properly.
Beyond upgrading to 2.1.x, you can also check this thread: http://www.cfd-online.com/Forums/ope...tml#post337003
Best regards,
Bruno
First Parallel Run - need some help Gian Maria OpenFOAM 3 June 17, 2011 12:08
[OpenFOAM] ParaView/Parafoam error when making animation Disco_Caine ParaView 6 September 28, 2010 09:54
Unable to run OF in parallel on a multiple-node cluster quartzian OpenFOAM 3 November 24, 2009 13:37
serial run fine, but parallel run diverged phsieh2005 OpenFOAM Running, Solving & CFD 2 October 6, 2009 08:33
user subroutine error CFDUSER CFX 2 December 9, 2006 06:31
