chtMultiRegionFoam
Old   April 6, 2012, 06:56
Default chtMultiRegionFoam
Samuele Z
samiam1000 is on a distinguished road
Dear all,
just a very fast question: what about the changeDictionaryDict dictionary in chtMultiRegionFoam?
Should I edit them on my own or I can use a command that prepares them and then I fix the BC that I want to?
Thanks a lot,
Samuele
samiam1000 is offline   Reply With Quote
Old   April 6, 2012, 17:28
Retired Super Moderator
Bruno Santos
Quick answer: "changeDictionaryDict" exists to make life easier for repetitive or automated dictionary editing.
Example: it's a fast way for reseting multiple boundary fields, after a failed execution of setFields.
Old   April 10, 2012, 04:41
Samuele Z
Dear Bruno, Dear all,
thanks for this answer, too.
Also, sorry if I opened different threads, but I thought it was easier to manage the discussions.
Anyway, I looked at the user guide and I am finding it difficult to understand how to use the chtMultiRegion solver.
Could you give me a very brief explanation of the steps?
Let me explain my case:
1. I import a .msh mesh from Ansys.
2. I have this situation:
- a 0 folder with the following files: epsilon, k, p, p_rgh, T, U, Tchar, Ypmma
- a constant folder with some subfolders and the regionProperties file. The subfolders are the following:
door_and_roof, external_air, internal_air and polyMesh
- the system folder.
3. I now give the fluent3DMeshToFoam command and in the polymesh subfolder some files are created: boundary, cellZones, faces, faceZones, neighbour, owner, points, pointZones
4. the cellZone is the file where I have all the info about the different zones.
5. the topoSetDict (in the system subfolder) is the following:
|  \\    /   O peration     | Version:  dev                                   |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      topoSetDict;
actions
        name    door_and_roof;
        type    cellZoneSet;
        action  new;
        source  zoneToCell;
        sourceInfo
            set door_and_roof;           // name of cellSet
        name    internal_air;
        type    cellZoneSet;
        action  new;
        source  zoneToCell;
        sourceInfo
            set internal_air;           // name of cellSet
        name    external_air;
        type    cellZoneSet;
        action  new;
        source  zoneToCell;
        sourceInfo
            set external_air;           // name of cellSet
Is that correct? What should I do, then?
Thanks for your help,
Samuele
Old   April 11, 2012, 09:36
Samuele Z
Dear All,
I am ready to run my case. There is one more problem. I think it's something linked with the BC.
I get this:
lab@lab-laptop:~/Documenti/cases_OF/OF_case11_test$ chtMultiRegionFoam
|  \\    /   O peration     | Version:  2.1.0                                 |
Build  : 2.1.0-0bc225064152
Exec   : chtMultiRegionFoam
Date   : Apr 11 2012
Time   : 15:23:03
Host   : "lab-laptop"
PID    : 8053
Case   : /home/lab/Documenti/cases_OF/OF_case11_test
nProcs : 1
allowSystemOperations : Disallowing user-supplied system call operations
Create time
Create fluid mesh for region internal_air for time = 0
Create fluid mesh for region external_air for time = 0
Create solid mesh for region door_and_roof for time = 0
*** Reading fluid mesh thermophysical properties for region internal_air
    Adding to thermoFluid
Selecting thermodynamics package hRhoThermo<pureMixture<constTransport<specieThermo<hConstThermo<perfectGas>>>>>
#0  Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam210/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1  Foam::sigFpe::sigHandler(int) in "/opt/openfoam210/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2   in "/lib/libc.so.6"
#3  Foam::hRhoThermo<Foam::pureMixture<Foam::constTransport<Foam::specieThermo<Foam::hConstThermo<Foam::perfectGas> > > > >::calculate() in "/opt/openfoam210/platforms/linux64GccDPOpt/lib/libbasicThermophysicalModels.so"
#4  Foam::hRhoThermo<Foam::pureMixture<Foam::constTransport<Foam::specieThermo<Foam::hConstThermo<Foam::perfectGas> > > > >::hRhoThermo(Foam::fvMesh const&) in "/opt/openfoam210/platforms/linux64GccDPOpt/lib/libbasicThermophysicalModels.so"
#5  Foam::basicRhoThermo::addfvMeshConstructorToTable<Foam::hRhoThermo<Foam::pureMixture<Foam::constTransport<Foam::specieThermo<Foam::hConstThermo<Foam::perfectGas> > > > > >::New(Foam::fvMesh const&) in "/opt/openfoam210/platforms/linux64GccDPOpt/lib/libbasicThermophysicalModels.so"
#6  Foam::basicRhoThermo::New(Foam::fvMesh const&) in "/opt/openfoam210/platforms/linux64GccDPOpt/lib/libbasicThermophysicalModels.so"
 in "/opt/openfoam210/platforms/linux64GccDPOpt/bin/chtMultiRegionFoam"
#8  __libc_start_main in "/lib/libc.so.6"
Floating point exception
What can I do? Are che `changeDictionary' files compulsory?
Thanks a lot,
Samuele
Old   April 11, 2012, 16:42
Bruno Santos
Hi Samuele,
I'll have to be quick... This seems to indicate that there was a division by zero or by infinity or a log(0), when defining the thermodynamic properties:
Originally Posted by samiam1000 View Post
That dictionary can help you quickly re-apply boundary conditions. Read the file "system/changeDictionaryDict" and compare with what you got in the respective dictionaries, right before changeDictionary is called.
Best regards,
Bruno
Old   April 30, 2012, 05:02
Adam Sitko
sitekss is on a distinguished road
Dear colleagues,
I'm trying to run chtMultiRgionHeater tutorial to understand how this stuff works. At first, I ran 'Allrun" but it created a few log files containing the information that changedictionary command were not found. it refeers to certain line in Allrun:
for i in bottomAir topAir heater leftSolig rightSolid
do
changeDictionary -region $i > log.changeDictionary.$i 2>&1
done
What's the problem and what can I do to fix it?
BR
Adam
sitekss is offline   Reply With Quote
Old   May 3, 2012, 03:05
Default Problem setting up chtMultiRegion Case
supercommandodhruv
dhruv is on a distinguished road
Hi Samiam,
I hope you managed to solve your problem and run your case. I am having some problems in running the case with chtMultiRegionFoam too.
I have two independent mesh, both meshed by snappyHexMesh. These two meshes together makes my complete geometry. With these two meshes, I create two cellZones. Now, to make the polyMesh directory of the base mesh, I mergeMesh the two meshes. Then, I use splitMeshRegions -cellZones -overwrite to update my mesh in two zones correctly, solid and fluid. When I run the case, I see that the temperature is not passed from the fluid side to the solid side. I use the standard BCs from the tutorial of chtMultiRegionHeater for the temperature field. When I run checkMesh on the base mesh, I see that it generates a message
The mesh has multiple regions which are not connected by any face.
  <<Writing region information to "0.0038/cellToRegion"
Can this be causing the problem? Or there is a problem in the BCs? Any help is very much appreciated.
Thanks,
Dhruv.
Dear All,
I get this:
Date   : Apr 11 2012
Time   : 15:23:03
Host   : "lab-laptop"
PID    : 8053
nProcs : 1
Create time
Thanks a lot,
Samuele
dhruv is offline   Reply With Quote
Old   May 3, 2012, 11:05
Bernhard Linseisen
Linse is on a distinguished road
I wonder why it would write to a folder 0.0038/cellToRegion. At which timestep do you start?
I would suggest to have a look into your system/controlDict and check if it really works from the correct timestep...
Though I would not know how this problem comes into existence...
Linse is offline   Reply With Quote
Old   May 3, 2012, 11:28
Default checkMesh
supercommandodhruv
Oh.. this is because I used checkMesh -latestTime. Otherwise, I start from 0 timestep.
Old   May 7, 2012, 03:11
supercommandodhruv
Ok... so, I did a little more investigation into the case, and found out that, when the splitMeshRegions is used in the chtMultiRegionFoam tutorial, it generates some intermediate patches at the interface, e.g bottomair_to_heater, etc. However, when I use splitMeshRegions to split my base mesh, it does not generate these patches. I think therein lies the problem. Now, as I understand, in tutorial, the regions are created from a single base mesh, and hence the creation of intermediate patches are necessary. In my case, I have two separate mesh. Is it necessary here too? How can I resolve this? Please, any suggestions.
Thanks,
Dhruv.
Old   May 7, 2012, 14:03
Helmut Roth
helmut is on a distinguished road
What information do you get in "0.0038/cellToRegion"? Could the existence of regions not connected by any faces be caused by the interfaces not being everywhere coincident?
helmut is offline   Reply With Quote
Old   May 8, 2012, 05:03
  #12
supercommandodhruv
Hi Helmut,
Thanks for the response. What do you exactly mean by coincident? I have two regions in my mesh. If I view them in parafoam, they perfectly align over each other.
Old   May 8, 2012, 09:17
Helmut Roth
I was just thinking you might have some small void spaces between the two mesh patches that form the interface. This could happen, for example, if the interface is a curved surface and the two zones have been independently snappyHex'd.
Old   May 9, 2012, 02:43
  #14
supercommandodhruv
Yes, i have meshed the two zones separately by snappy. So, i just made two cases, which have the same geometry and blockMesh, and changed the locationInMesh in both, to generate my solid and fluid region. Thereafter, I created zones in these meshes, and used mergeMesh to create my base mesh for chtMultiRegionFoam. Is there any other way that I can do this? Please suggest me.
Old   June 4, 2012, 10:02
Learner
raghu.tejaswi is on a distinguished road
Dear All,
I get this:
Date   : Apr 11 2012
Time   : 15:23:03
Host   : "lab-laptop"
PID    : 8053
nProcs : 1
Create time
Thanks a lot,
Samuele
Hi samiam1000,
Have you been able to solve your problem. Can you please share the solution too?
I feel there might be a problem in inputting the values in thermophysicalproperties....
Thanks.....
Raghu
raghu.tejaswi is offline   Reply With Quote
Error in chtMultiRegionFoam kirankarki OpenFOAM 6 August 21, 2018 08:00
Altering chtMultiRegionFoam jabecker OpenFOAM Running, Solving & CFD 0 June 30, 2011 09:58
chtmultiregionFoam alvora OpenFOAM 9 February 23, 2011 03:06
Simplifying chtMultiRegionFoam miket OpenFOAM Running, Solving & CFD 0 November 24, 2010 13:36
chtMultiRegionFoam with liquid phsieh2005 OpenFOAM Running, Solving & CFD 0 October 9, 2010 06:07
